This translation was generated by a machine and has not been reviewed by a person yet. Speak this language? Review it.
Introduction
This guide shows how to remove and replace the keyboard of a MacBook Air 13" Early 2017. The procedure requires disconnecting several ribbon cables and wires, removing the logic board, and then unscrewing the 40 screws that secure the keyboard.
Tool used on this step:P5 Pentalobe Screwdriver Retina MacBook Pro and Air$5.99
Use a P5 Pentalobe driver to remove ten screws securing the lower case, of the following lengths:
Two 9 mm screws
Eight 2.6 mm screws
Grab the clear plastic pull tab attached to the battery connector and pull it parallel to the board toward the front edge of the Air.
Use the flat end of a spudger to pry the I/O board cable connector up out of its socket on the I/O board.
Use the tip of a spudger to carefully flip up the retaining flap on the fan cable ZIF socket.
Disconnect the I/O board by pulling its power cable away from its socket on the logic board.
Use the flat end of a spudger to pry the right speaker connector up and out of its socket on the logic board.
Use the flat end of a spudger to pry the left speaker cable connector up and out of its socket on the I/O board.
Lift the retaining flap on the display cable connector. You can lift it using a spudger, or by pulling on the black tape attached to it (using your fingers or tweezers).
Pull the cable horizontally to disconnect it. There is no latch or flap on this connector.
Flip up the retaining flap on the back of the trackpad connector with the tip of a spudger.
Flip up the retaining flap on the back of the power button connector with the tip of a spudger.
While carefully lifting the keyboard cable with one hand, use the tip of a spudger or your fingernail to flip up the retaining flap on the keyboard cable's ZIF socket.
Pull the keyboard cable straight out of its socket, towards the front edge of the Air.
Start at a corner, then work along an edge and pull gently to avoid damaging the backlight if you intend to reuse it.
Unscrew the 40 (!) Phillips screws using a Phillips 000 screwdriver that hold the keyboard in place.
Remove the two 4.9 mm Torx screws securing the antenna wire retainer for the left display clutch hinge to the upper housing.
Move the antenna wire retainer out of the way and remove the single 3 mm Torx screw securing the end of the heat sink to the upper housing.
Unscrew the 6 Torx screws securing the motherboard.
It is now easy to remove the motherboard. Be careful to clear the Wi-Fi antenna cables from their notches.
To reassemble your device, follow the instructions in reverse order.
