MacBook Air 13" Early 2015 SSD Replacement
Video Overview
    1. MacBook Air 13" Early 2015 SSD Replacement, Lower Case: step 1, image 1 of 1
      Tool used on this step:
      P5 Pentalobe Screwdriver Retina MacBook Pro and Air
      $5.99
      Buy
      • Before proceeding, power down your MacBook. Close the display and lay it on a soft surface, top-side down.
      • Use a P5 Pentalobe driver to remove ten screws securing the lower case, of the following lengths:
      • Two 9 mm screws
      • Eight 2.6 mm screws
      Ask FixBot
    2. MacBook Air 13" Early 2015 SSD Replacement: step 2, image 1 of 1
      • Wedge your fingers between the display and the lower case and pull upward to pop the lower case off the Air.
      Ask FixBot
    1. MacBook Air 13" Early 2015 SSD Replacement, Battery Connector: step 3, image 1 of 2 MacBook Air 13" Early 2015 SSD Replacement, Battery Connector: step 3, image 2 of 2
      • To ensure that everything is de-energized and won't turn on while you're working, it is recommended that you disconnect the battery.
      • Grab the clear plastic pull tab attached to the battery connector and pull it parallel to the board toward the front edge of the Air.
      • Do not lift upward on the connector as you disconnect it or you risk damage to the connector socket.
      Ask FixBot
    1. MacBook Air 13" Early 2015 SSD Replacement, Solid-State Drive: step 4, image 1 of 1
      • Remove the single 2.9 mm T5 Torx screw securing the SSD to the logic board.
      Ask FixBot
    2. MacBook Air 13" Early 2015 SSD Replacement: step 5, image 1 of 2 MacBook Air 13" Early 2015 SSD Replacement: step 5, image 2 of 2
      • Gently lift the end of the SSD about half an inch and pull it straight out of its socket on the logic board.
      • Don't lift the SSD more than half an inch—doing so may damage the SSD or its socket on the logic board.
      • When reinstalling the SSD, be sure it is properly seated before reinstalling its retaining screw.
      Ask FixBot
216 other people completed this guide.
Sam Goldheart
478,465 Reputation
538 Guides authored
iFixit Member of iFixit
Staff
122 Members
72,401 Guides authored
51 Guide Comments
Great... Now tell me where I can get an SSD for this machine.
Dave - Reply Share
yes) and prompt and appropriate model that was not inferior in speed built.
Thank!
ilyabuhov - Reply Share
Dave, I am sure these are M.2 SSD. I am not sure what apple uses but at least you have somewhere you can start for research
klacorum - Reply Share
That’s indeed an M.2 SSD but you’ll need an adapter as the one that came with the Macbook uses a proprietary connector.
Farie Indriawan - Reply Share
Is there a way to upgrade it ? I cant find a bigger SSD which can be installed on this model.
Any update is welcome.
Max - Reply Share
Past 24 Hours: 33
Past 7 Days: 180
Past 30 Days: 998
All Time: 503,040
