MacBook Air 11" Mid 2013 Fan Replacement
    1. MacBook Air 11" Mid 2013 Fan Replacement, Lower Case: step 1, image 1 of 1
      Tool used on this step:
      P5 Pentalobe Screwdriver Retina MacBook Pro and Air
      $5.99
      Buy
      • Shut down and close your computer. Lay it on a soft surface top-side down.
      • Remove the following ten screws:
      • Two 8 mm 5-point Pentalobe screws
      • Eight 2.5 mm 5-point Pentalobe screws
      • The special screwdriver needed to remove the 5-point Pentalobe screws can be found here.
      Ask FixBot
    2. MacBook Air 11" Mid 2013 Fan Replacement: step 2, image 1 of 1
      • Wedge your fingers between the display and the lower case and pull upward to pop the lower case off the Air.
      Ask FixBot
    1. MacBook Air 11" Mid 2013 Fan Replacement, Battery Connector: step 3, image 1 of 2 MacBook Air 11" Mid 2013 Fan Replacement, Battery Connector: step 3, image 2 of 2
      • In this step you will disconnect the battery to help avoid shorting out any components during service.
      • Use the flat end of a spudger to pry both short sides of the battery connector upward to disconnect it from its socket on the logic board.
      • Bend the battery cable slightly away from the logic board so the connector will not accidentally bend back and make contact with its socket.
      Ask FixBot
    1. MacBook Air 11" Mid 2013 Fan Replacement, I/O Board Cable: step 4, image 1 of 2 MacBook Air 11" Mid 2013 Fan Replacement, I/O Board Cable: step 4, image 2 of 2
      • Use the flat end of a spudger to pry the left and right I/O board cable connectors up off their respective sockets on the I/O board.
      Ask FixBot
    2. MacBook Air 11" Mid 2013 Fan Replacement: step 5, image 1 of 1
      • Lift and remove the I/O board cable.
      Ask FixBot
    1. MacBook Air 11" Mid 2013 Fan Replacement, Fan: step 6, image 1 of 2 MacBook Air 11" Mid 2013 Fan Replacement, Fan: step 6, image 2 of 2
      • Use the tip of a spudger to carefully push on each side of the iSight camera cable connector to loosen it out of its socket on the logic board.
      • We recommend you gently "walk" the connector out of its socket.
      Ask FixBot
    2. MacBook Air 11" Mid 2013 Fan Replacement: step 7, image 1 of 2 MacBook Air 11" Mid 2013 Fan Replacement: step 7, image 2 of 2
      • Peel the iSight camera cable up off the adhesive securing it to the fan.
      Ask FixBot
    3. MacBook Air 11" Mid 2013 Fan Replacement: step 8, image 1 of 2 MacBook Air 11" Mid 2013 Fan Replacement: step 8, image 2 of 2
      • Use the tip of a spudger to carefully flip up the retaining flap on the fan cable ZIF socket.
      • Be sure you are prying up on the hinged retaining flap, not the socket itself.
      Ask FixBot
    4. MacBook Air 11" Mid 2013 Fan Replacement: step 9, image 1 of 1
      • Remove the following three screws securing the fan to the upper case:
      • Two 5.5 mm T5 Torx screws
      • One 4.6 mm T5 Torx screw
      • In some models this is a 3.6 mm T5 Torx screw.
      Ask FixBot
    5. MacBook Air 11" Mid 2013 Fan Replacement: step 10, image 1 of 3 MacBook Air 11" Mid 2013 Fan Replacement: step 10, image 2 of 3 MacBook Air 11" Mid 2013 Fan Replacement: step 10, image 3 of 3
      • Lift, but do not remove the fan out of its recess in the upper case.
      • Carefully pull the fan ribbon cable out of its socket as you remove the fan from the Air.
      Ask FixBot
15 other people completed this guide.
Sam Goldheart
478,462 Reputation
538 Guides authored
iFixit Member of iFixit
Staff
122 Members
72,401 Guides authored
1 Guide Comment
I have error PPF004.
Liviolog4 - Reply Share
Past 24 Hours: 4
Past 7 Days: 32
Past 30 Days: 128
All Time: 7,621
