MacBook Air 11" Mid 2012 Solid-State Drive Replacement
    1. MacBook Air 11" Mid 2012 Solid-State Drive Replacement, Lower Case: step 1, image 1 of 1
      Tool used on this step:
      P5 Pentalobe Screwdriver Retina MacBook Pro and Air
      $5.99
      Buy
      • Shut down and close your computer. Lay it on a soft surface top-side down.
      • Remove the following ten screws:
      • Two 8 mm 5-point Pentalobe screws
      • Eight 2.5 mm 5-point Pentalobe screws
      • The special screwdriver needed to remove the 5-point Pentalobe screws can be found here.
      Ask FixBot
    2. MacBook Air 11" Mid 2012 Solid-State Drive Replacement: step 2, image 1 of 1
      • Wedge your fingers between the display and the lower case and pull upward to pop the lower case off the Air.
      Ask FixBot
    1. MacBook Air 11" Mid 2012 Solid-State Drive Replacement, Battery: step 3, image 1 of 2 MacBook Air 11" Mid 2012 Solid-State Drive Replacement, Battery: step 3, image 2 of 2
      • In this step you will disconnect the battery to help avoid shorting out any components during service.
      • Use the flat end of a spudger to pry both short sides of the battery connector upward to disconnect it from its socket on the logic board.
      • Bend the battery cable slightly away from the logic board so the connector will not accidentally contact its socket.
      Ask FixBot
    1. MacBook Air 11" Mid 2012 Solid-State Drive Replacement, Solid-State Drive: step 4, image 1 of 1
      • Remove the single 2.9 mm T5 Torx screw securing the SSD to the logic board.
      Ask FixBot
    2. MacBook Air 11" Mid 2012 Solid-State Drive Replacement: step 5, image 1 of 2 MacBook Air 11" Mid 2012 Solid-State Drive Replacement: step 5, image 2 of 2
      • Use a spudger to help lift the free end of the SSD just enough to grab it with your other hand.
      • Do not lift the end of the SSD excessively.
      • Pull the drive straight out of its socket and remove it from the logic board.
      • When reinstalling the SSD, be sure it is properly seated before reinstalling its retaining screw.
      Ask FixBot
52 other people completed this guide.
Andrew Optimus Goldheart
515,935 Reputation
406 Guides authored
iFixit Member of iFixit
Staff
122 Members
72,401 Guides authored
4 Guide Comments
Excellent instructions. Very easy to do. I used this screwdriver to remove the screws from the bottom of the case: https://www.amazon.com/gp/product/B00N1R...
and I used the Pentalobe-6 from this set to remove the screw holding in the OEM SSD:
https://www.amazon.com/gp/product/B01FE2...
After removing the stock drive, I installed a Samsung M.2 EVO 850 512Gb drive. It is working quite well. I used this adapter so that the M.2 drive fit in my 2012 Macbook Air:
https://www.amazon.com/gp/product/B01NH2...
feinberj - Reply Share
How do we reinstall MacOS?
Philippe Morin - Reply Share
I am 10 years old I fixed the mac I did this even the Geek squad couldn’t do it and now it works! without your guide.
admin free - Reply Share
I have a MBA mid 2012 11” which no longer powers up. The battery has been in bad condition since a while and now the charging indicator remains amber no matter how long I charge it. So I assume it might be a battery issue. Unfortunately, I cannot find a supplier shipping batteries to Hawaii, but I found an identical machine on ebay (that will ship to Hawaii), except that it has 4GB RAM instead of 8GB. Provided my SSD is functional (which I assume) can I simply put my SSD into that 4GB RAM machine, and it will start up without any further modification?
Guido eMail - Reply Share
Past 24 Hours: 9
Past 7 Days: 70
Past 30 Days: 257
All Time: 88,469
