MacBook Air 11" Mid 2012 Right Speaker Replacement
    1. MacBook Air 11" Mid 2012 Right Speaker Replacement, Lower Case: step 1, image 1 of 1
      Tool used on this step:
      P5 Pentalobe Screwdriver Retina MacBook Pro and Air
      $5.99
      Buy
      • Shut down and close your computer. Lay it on a soft surface top-side down.
      • Remove the following ten screws:
      • Two 8 mm 5-point Pentalobe screws
      • Eight 2.5 mm 5-point Pentalobe screws
      • The special screwdriver needed to remove the 5-point Pentalobe screws can be found here.
      Ask FixBot
    2. MacBook Air 11" Mid 2012 Right Speaker Replacement: step 2, image 1 of 1
      • Wedge your fingers between the display and the lower case and pull upward to pop the lower case off the Air.
      Ask FixBot
    1. MacBook Air 11" Mid 2012 Right Speaker Replacement, Battery: step 3, image 1 of 2 MacBook Air 11" Mid 2012 Right Speaker Replacement, Battery: step 3, image 2 of 2
      • Use the flat end of a spudger to pry both short sides of the battery connector upward to disconnect it from its socket on the logic board.
      • Bend the battery cable slightly away from the logic board so the connector will not accidentally contact its socket.
      Ask FixBot
    2. MacBook Air 11" Mid 2012 Right Speaker Replacement: step 4, image 1 of 1
      • Remove the following five screws securing the battery to the upper case:
      • Two 5.2 mm T5 Torx screws
      • One 6 mm T5 Torx screw
      • Two 2.6 mm T5 Torx screws
      Ask FixBot
    3. MacBook Air 11" Mid 2012 Right Speaker Replacement: step 5, image 1 of 1
      • When handling the battery, avoid squeezing or touching the six exposed lithium polymer cells.
      • Lift the battery from its edge nearest the logic board and remove it from the upper case.
      • If you're installing a new battery, you should calibrate it after installation:
      • Charge it to 100%, and then keep charging it for at least 2 more hours. Next, unplug and use it normally to drain the battery. When you see the low battery warning, save your work, and keep your laptop on until it goes to sleep due to low battery. Wait at least 5 hours, then charge your laptop uninterrupted to 100%.
      • If you notice any unusual behavior or problems after installing your new battery, you may need to reset your MacBook's SMC.
      Ask FixBot
    1. MacBook Air 11" Mid 2012 Right Speaker Replacement, Right Speaker: step 6, image 1 of 1
      • Use the tip of a spudger to de-route the right speaker cable from the channel cut into the logic board.
      Ask FixBot
    2. MacBook Air 11" Mid 2012 Right Speaker Replacement: step 7, image 1 of 1
      • Use the flat end of a spudger to pry the right speaker cable connector up and out of its socket on the logic board.
      • Pry upward from beneath the wires.
      Ask FixBot
    3. MacBook Air 11" Mid 2012 Right Speaker Replacement: step 8, image 1 of 2 MacBook Air 11" Mid 2012 Right Speaker Replacement: step 8, image 2 of 2
      • Use the flat end of a spudger to pry the right speaker off the adhesive securing it to the upper case.
      • Only pry up on the speaker from the areas of bare aluminum on the upper case. Prying up from the keyboard area may damage the keyboard and the speaker itself.
      Ask FixBot
    4. MacBook Air 11" Mid 2012 Right Speaker Replacement: step 9, image 1 of 1
      • Remove the right speaker from the upper case.
      Ask FixBot
12 other people completed this guide.
Andrew Optimus Goldheart
515,547 Reputation
406 Guides authored
iFixit Member of iFixit
Staff
123 Members
84,881 Guides authored
1 Guide Comment
Good directions. Very easy.
rjanak - Reply Share
Past 24 Hours: 0
Past 7 Days: 16
Past 30 Days: 45
All Time: 3,490
