Up to 20% off select tools
MacBook Air 11" Mid 2012 Microphone Replacement
Views: 4.5K
View statistics:
Past 24 Hours:
8
Past 7 Days:
23
Past 30 Days:
104
All Time:
4,483
Comments: 36
34 comments on steps, 2 guide comments.
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 5
5 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 15 - 20 minutes
Difficulty: Moderate
Parts
Tools
Introduction
Go to step 1 ↓
Screaming at your MacBook Air might not hurt its feelings, but it could go deaf. Use this guide to replace a blown-out microphone. This is a relatively easy process. Take your time and don't force anything.
    1. MacBook Air 11" Mid 2012 Microphone Replacement, Lower Case: step 1, image 1 of 1
      Tool used on this step:
      P5 Pentalobe Screwdriver Retina MacBook Pro and Air
      $5.99
      Buy
      • Shut down and close your computer. Lay it on a soft surface top-side down.
      • Remove the following ten screws:
      • Two 8 mm 5-point Pentalobe screws
      • Eight 2.5 mm 5-point Pentalobe screws
      • The special screwdriver needed to remove the 5-point Pentalobe screws can be found here.
      Ask FixBot
    2. MacBook Air 11" Mid 2012 Microphone Replacement: step 2, image 1 of 1
      • Wedge your fingers between the display and the lower case and pull upward to pop the lower case off the Air.
      Ask FixBot
    1. MacBook Air 11" Mid 2012 Microphone Replacement, Battery: step 3, image 1 of 2 MacBook Air 11" Mid 2012 Microphone Replacement, Battery: step 3, image 2 of 2
      • Use the flat end of a spudger to pry both short sides of the battery connector upward to disconnect it from its socket on the logic board.
      • Bend the battery cable slightly away from the logic board so the connector will not accidentally contact its socket.
      Ask FixBot
    2. MacBook Air 11" Mid 2012 Microphone Replacement: step 4, image 1 of 1
      • Remove the following five screws securing the battery to the upper case:
      • Two 5.2 mm T5 Torx screws
      • One 6 mm T5 Torx screw
      • Two 2.6 mm T5 Torx screws
      Ask FixBot
    3. MacBook Air 11" Mid 2012 Microphone Replacement: step 5, image 1 of 1
      • When handling the battery, avoid squeezing or touching the six exposed lithium polymer cells.
      • Lift the battery from its edge nearest the logic board and remove it from the upper case.
      • If you're installing a new battery, you should calibrate it after installation:
      • Charge it to 100%, and then keep charging it for at least 2 more hours. Next, unplug and use it normally to drain the battery. When you see the low battery warning, save your work, and keep your laptop on until it goes to sleep due to low battery. Wait at least 5 hours, then charge your laptop uninterrupted to 100%.
      • If you notice any unusual behavior or problems after installing your new battery, you may need to reset your MacBook's SMC.
      Ask FixBot
    1. MacBook Air 11" Mid 2012 Microphone Replacement, Left Speaker: step 6, image 1 of 1
      • Use the flat end of a spudger to pry the I/O board cable connector up off its socket on the I/O board.
      • Bend the cable away from the I/O board.
      Ask FixBot
    2. MacBook Air 11" Mid 2012 Microphone Replacement: step 7, image 1 of 1
      • Use the tip of a spudger to de-route the left speaker cable from the notch cut into the edge of the I/O board.
      Ask FixBot
    3. MacBook Air 11" Mid 2012 Microphone Replacement: step 8, image 1 of 1
      • Use the flat end of a spudger to pry the left speaker connector up and out of its socket on the I/O board.
      • Make sure to pry upward from beneath the wires.
      Ask FixBot
    4. MacBook Air 11" Mid 2012 Microphone Replacement: step 9, image 1 of 2 MacBook Air 11" Mid 2012 Microphone Replacement: step 9, image 2 of 2
      • Use the flat end of a spudger to pry the left speaker off the adhesive securing it to the upper case.
      • Only pry up on the speaker from the areas of bare aluminum on the upper case. Prying up from the keyboard area may damage the keyboard and the speaker itself.
      Ask FixBot
    5. MacBook Air 11" Mid 2012 Microphone Replacement: step 10, image 1 of 1
      • Remove the left speaker from the upper case.
      Ask FixBot
    1. MacBook Air 11" Mid 2012 Microphone Replacement, Microphone: step 11, image 1 of 2 MacBook Air 11" Mid 2012 Microphone Replacement, Microphone: step 11, image 2 of 2
      • Use the tip of a spudger to flip up the retaining flap on the microphone ribbon cable ZIF socket.
      • Be sure you are prying up on the hinged retaining flap, not the socket itself.
      • Use the tip of a spudger to pull the microphone ribbon cable out of its socket.
      Ask FixBot
    2. MacBook Air 11" Mid 2012 Microphone Replacement: step 12, image 1 of 2 MacBook Air 11" Mid 2012 Microphone Replacement: step 12, image 2 of 2
      • Use the tip of a spudger to pry the microphone away from the side of the upper case.
      • Remove the microphone from the upper case.
      Ask FixBot
To reassemble your device, follow these instructions in reverse order. Take note of microphone position before removal so you can position the replacement accurately in place.
2 other people completed this guide.
Author
with
Andrew Optimus Goldheart
516,617 Reputation
405 Guides authored
iFixit Member of iFixit
Staff
119 Members
72,966 Guides authored
2 Guide Comments
Very straightforward replacement.
Take special care when removing the microphone and speaker connectors from their respective sockets. Just be gentle and methodical.
Ensure you press down firmly, but not hard, after microphone replacement when reconnecting the battery connector to the motherboard.
pohutukawa - Reply Share
When re-attaching the speaker connector, also pay special attention to pushing down firmly on this to ensure a connection is made. Again, not too hard, but it is easy to push down enough to think it is connected but it can easily not be.
Past 24 Hours: 8
Past 7 Days: 23
Past 30 Days: 104
All Time: 4,483
