MacBook Air 11" Mid 2011 Solid-State Drive Replacement
    1. MacBook Air 11" Mid 2011 Solid-State Drive Replacement, Lower Case: step 1, image 1 of 1
      Tool used on this step:
      P5 Pentalobe Screwdriver Retina MacBook Pro and Air
      $5.99
      Buy
      • Before proceeding, close your computer and lay it on a soft surface top-side down.
      • Remove the following ten screws:
      • Two 8 mm 5-point Pentalobe screws
      • Eight 2.5 mm 5-point Pentalobe screws
      • The special screwdriver needed to remove the eight 5-point Pentalobe screws can be found here.
      Ask FixBot
    2. MacBook Air 11" Mid 2011 Solid-State Drive Replacement: step 2, image 1 of 1
      • Wedge your fingers between the display and the lower case and pull upward to pop the lower case off the Air.
      Ask FixBot
    1. MacBook Air 11" Mid 2011 Solid-State Drive Replacement, Battery: step 3, image 1 of 2 MacBook Air 11" Mid 2011 Solid-State Drive Replacement, Battery: step 3, image 2 of 2
      • In this step you will disconnect the battery to help avoid shorting out any components during service.
      • Use the flat end of a spudger to pry both short sides of the battery connector upward to disconnect it from its socket on the logic board.
      • Bend the battery cable slightly away from the logic board so the connector will not accidentally contact its socket.
      Ask FixBot
    1. MacBook Air 11" Mid 2011 Solid-State Drive Replacement, Solid-State Drive: step 4, image 1 of 1
      • Remove the single 2.9 mm T5 Torx screw securing the SSD to the logic board.
      Ask FixBot
    2. MacBook Air 11" Mid 2011 Solid-State Drive Replacement: step 5, image 1 of 2 MacBook Air 11" Mid 2011 Solid-State Drive Replacement: step 5, image 2 of 2
      • Use a spudger to help lift the free end of the SSD just enough to grab it with your other hand.
      • Do not lift the end of the SSD excessively.
      • Pull the drive straight out of its socket and remove it from the logic board.
      • When reinstalling the SSD, be sure it is properly seated before reinstalling its retaining screw.
      Ask FixBot
117 other people completed this guide.
16 Guide Comments
Note: if you're installing a blank SSD, you'll want to format it with Disk Utilities) before the OS X installer will recognize it.
aaronmiller - Reply Share
Could not have been any easier, with this guide.
Thank you very much!
916sp - Reply Share
is it possible to replace an 128 GB Solid State Drive with an 240 GB? (MacBook Air, 11", Mid 2011)
zimmermatthias - Reply Share
Does anyone know if the Samsung 960 pro 512gb m.2 drive is compatible with this machine?
Mark - Reply Share
No, is not, I just bought a 1TB Samsung 960 EVO m.2 and had to return it, for not being compatible. (is smaller and the pin-out is not the same)
fjlbandeira - Reply Share
Past 24 Hours: 8
Past 7 Days: 98
Past 30 Days: 487
All Time: 258,108
