MacBook Air 11" Mid 2011 Heat Sink Replacement
    1. MacBook Air 11" Mid 2011 Heat Sink Replacement, Lower Case: step 1, image 1 of 1
      Tool used on this step:
      P5 Pentalobe Screwdriver Retina MacBook Pro and Air
      $5.99
      Buy
      • Shut down and close your computer. Lay it on a soft surface top-side down.
      • Remove the following ten screws:
      • Two 8 mm 5-point Pentalobe screws
      • Eight 2.5 mm 5-point Pentalobe screws
      • The special screwdriver needed to remove the 5-point Pentalobe screws can be found here.
      Ask FixBot
    2. MacBook Air 11" Mid 2011 Heat Sink Replacement: step 2, image 1 of 1
      • Wedge your fingers between the display and the lower case and pull upward to pop the lower case off the Air.
      Ask FixBot
    1. MacBook Air 11" Mid 2011 Heat Sink Replacement, Battery: step 3, image 1 of 2 MacBook Air 11" Mid 2011 Heat Sink Replacement, Battery: step 3, image 2 of 2
      • In this step you will disconnect the battery to help avoid shorting out any components during service.
      • Use the flat end of a spudger to pry both short sides of the battery connector upward to disconnect it from its socket on the logic board.
      • Bend the battery cable slightly away from the logic board so the connector will not accidentally contact its socket.
      Ask FixBot
    1. MacBook Air 11" Mid 2011 Heat Sink Replacement, Solid-State Drive: step 4, image 1 of 1
      • Remove the single 2.9 mm T5 Torx screw securing the SSD to the logic board.
      Ask FixBot
    2. MacBook Air 11" Mid 2011 Heat Sink Replacement: step 5, image 1 of 2 MacBook Air 11" Mid 2011 Heat Sink Replacement: step 5, image 2 of 2
      • Use a spudger to help lift the free end of the SSD just enough to grab it with your other hand.
      • Do not lift the end of the SSD excessively.
      • Pull the drive straight out of its socket and remove it from the logic board.
      • When reinstalling the SSD, be sure it is properly seated before reinstalling its retaining screw.
      Ask FixBot
    1. MacBook Air 11" Mid 2011 Heat Sink Replacement, I/O Board Cable: step 6, image 1 of 1
      • Use the flat end of a spudger to pry the I/O board cable up from its socket on the I/O board.
      Ask FixBot
    2. MacBook Air 11" Mid 2011 Heat Sink Replacement: step 7, image 1 of 1
      • Peel the I/O board cable up from the adhesive securing it to the fan.
      Ask FixBot
    3. MacBook Air 11" Mid 2011 Heat Sink Replacement: step 8, image 1 of 2 MacBook Air 11" Mid 2011 Heat Sink Replacement: step 8, image 2 of 2
      • Use the flat end of a spudger to lift the I/O board connector up and out of its socket on the logic board
      • Be sure to lift straight up on the connector as you disconnect it from its socket. The socket is very deep on the logic board and prying it from side to side may damage the logic board
      • Remove the I/O board cable.
      Ask FixBot
    1. MacBook Air 11" Mid 2011 Heat Sink Replacement, Fan: step 9, image 1 of 1
      • Use the tip of a spudger to carefully flip up the retaining flap on the fan cable ZIF socket.
      • Be sure you are prying up on the hinged retaining flap, not the socket itself.
      Ask FixBot
    2. MacBook Air 11" Mid 2011 Heat Sink Replacement: step 10, image 1 of 1
      • Remove the following three screws securing the fan to the upper case:
      • Two 5.2 mm T5 Torx screws
      • One 3.6 mm T5 Torx screw
      Ask FixBot
    3. MacBook Air 11" Mid 2011 Heat Sink Replacement: step 11, image 1 of 1
      • Lift the fan out of the upper case and carefully pull the fan ribbon cable out of its socket as you remove it from the Air.
      Ask FixBot
    1. MacBook Air 11" Mid 2011 Heat Sink Replacement, Heat Sink: step 12, image 1 of 1
      • Remove the four 2.5 mm T5 Torx screws securing the heat sink to the logic board.
      Ask FixBot
    2. MacBook Air 11" Mid 2011 Heat Sink Replacement: step 13, image 1 of 1
      • If the heat sink seems to be stuck to the logic board after removing all four screws, use a spudger to carefully separate the heat sink from the faces of the CPU and GPU.
      • Remove the heat sink from the logic board.
      • When reinstalling the heat sink, be sure to apply a new layer of thermal paste. If you have never applied thermal paste before, we have a guide that makes it easy.
      Ask FixBot
21 other people completed this guide.
2 Guide Comments
Great guide. I repasted my Early 2011 15" MBP with the 2.2 QC i7 and my peak load temp is now 87C (it was well over 100, and I was having it shutdown on me sometimes before). Having done this now, I must say I consider this system much more difficult to work inside than HP, Dell, or Lenovo/IBM laptops (having worked on all the others before). If you're patient, take it slow, and are careful though, everything works out. Here's some pictures of parts of the process:
Apple's horrid paste job
After a thorough cleaning with Articlean
My paste job after a test press, good enough
Tristor - Reply Share
Macbook Air 2011...a few things are different on my computer than this guide, but everything is straightforward enough. Here are the differences I found.
1. battery plug is slightly different, but same thing you just pull it out with the plastic tab.
2. Need to unplug the wire underneath the fan to reveal the 3rd screw...it isn't where it's shown on the picture here, that's a screw for the logic board not the fan.
3. There is a 5th screw holding the heatsink in place on the right end under another wire that connects to the hinge & screen. Had to move the wire to the side and remove that extra screw to get the heatsink off.
My Macbook Air 2011 shut off and starting making 3 beeps on attempting startup. Read this 3 beeps on start up and thought it may be the heat sink. Haven't applied new paste yet, but the paste is definitely hardened after following this guide. Plan to reapply and hopefully it works again!
Dylan Harris - Reply Share
Past 24 Hours: 1
Past 7 Days: 12
Past 30 Days: 65
All Time: 16,935
