MacBook Air 11" Early 2015 Upper Case Replacement
    1. MacBook Air 11" Early 2015 Upper Case Replacement, Lower Case: step 1, image 1 of 1
      Tool used on this step:
      P5 Pentalobe Screwdriver Retina MacBook Pro and Air
      $5.99
      Buy
      • Shut down and close your computer. Lay it on a soft surface top-side down.
      • Remove the following ten screws:
      • Two 8 mm 5-point Pentalobe screws
      • Eight 2.5 mm 5-point Pentalobe screws
      • The special screwdriver needed to remove the 5-point Pentalobe screws can be found here.
      Ask FixBot
    2. MacBook Air 11" Early 2015 Upper Case Replacement: step 2, image 1 of 1
      • Wedge your fingers between the display and the lower case and pull upward to pop the lower case off the Air.
      Ask FixBot
    1. MacBook Air 11" Early 2015 Upper Case Replacement, Battery Connector: step 3, image 1 of 2 MacBook Air 11" Early 2015 Upper Case Replacement, Battery Connector: step 3, image 2 of 2
      • In this step you will disconnect the battery to help avoid shorting out any components during service.
      • Use the flat end of a spudger to pry both short sides of the battery connector upward to disconnect it from its socket on the logic board.
      • Bend the battery cable slightly away from the logic board so the connector will not accidentally bend back and make contact with its socket.
      Ask FixBot
    1. MacBook Air 11" Early 2015 Upper Case Replacement, I/O Board Cable: step 4, image 1 of 2 MacBook Air 11" Early 2015 Upper Case Replacement, I/O Board Cable: step 4, image 2 of 2
      • Use the flat end of a spudger to pry the left and right I/O board cable connectors up off their respective sockets on the I/O board.
      Ask FixBot
    2. MacBook Air 11" Early 2015 Upper Case Replacement: step 5, image 1 of 1
      • Lift and remove the I/O board cable.
      Ask FixBot
    1. MacBook Air 11" Early 2015 Upper Case Replacement, Fan: step 6, image 1 of 2 MacBook Air 11" Early 2015 Upper Case Replacement, Fan: step 6, image 2 of 2
      • Use the tip of a spudger to carefully push on each side of the iSight camera cable connector to loosen it out of its socket on the logic board.
      • We recommend you gently "walk" the connector out of its socket.
      Ask FixBot
    2. MacBook Air 11" Early 2015 Upper Case Replacement: step 7, image 1 of 2 MacBook Air 11" Early 2015 Upper Case Replacement: step 7, image 2 of 2
      • Peel the iSight camera cable up off the adhesive securing it to the fan.
      Ask FixBot
    3. MacBook Air 11" Early 2015 Upper Case Replacement: step 8, image 1 of 2 MacBook Air 11" Early 2015 Upper Case Replacement: step 8, image 2 of 2
      • Use the tip of a spudger to carefully flip up the retaining flap on the fan cable ZIF socket.
      • Be sure you are prying up on the hinged retaining flap, not the socket itself.
      Ask FixBot
    4. MacBook Air 11" Early 2015 Upper Case Replacement: step 9, image 1 of 1
      • Remove the following three screws securing the fan to the upper case:
      • Two 5.5 mm T5 Torx screws
      • One 4.6 mm T5 Torx screw
      • In some models this is a 3.6 mm T5 Torx screw.
      Ask FixBot
    5. MacBook Air 11" Early 2015 Upper Case Replacement: step 10, image 1 of 3 MacBook Air 11" Early 2015 Upper Case Replacement: step 10, image 2 of 3 MacBook Air 11" Early 2015 Upper Case Replacement: step 10, image 3 of 3
      • Lift, but do not remove the fan out of its recess in the upper case.
      • Carefully pull the fan ribbon cable out of its socket as you remove the fan from the Air.
      Ask FixBot
    1. MacBook Air 11" Early 2015 Upper Case Replacement, Logic Board Assembly: step 11, image 1 of 3 MacBook Air 11" Early 2015 Upper Case Replacement, Logic Board Assembly: step 11, image 2 of 3 MacBook Air 11" Early 2015 Upper Case Replacement, Logic Board Assembly: step 11, image 3 of 3
      • Use the flat end of a spudger to pry both antenna connectors up from their sockets on the AirPort/Bluetooth card, and move them out of the way.
      Ask FixBot
    2. MacBook Air 11" Early 2015 Upper Case Replacement: step 12, image 1 of 1
      • Remove the following five screws securing the battery to the upper case:
      • Two 5.2 mm T5 Torx screws
      • One 6 mm T5 Torx screw
      • Two 2.6 mm T5 Torx screws
      Ask FixBot
    3. MacBook Air 11" Early 2015 Upper Case Replacement: step 13, image 1 of 1
      • When handling the battery, avoid squeezing or touching the six exposed lithium polymer cells.
      • Lift the battery from its edge nearest the logic board and remove it from the upper case.
      Ask FixBot
    4. MacBook Air 11" Early 2015 Upper Case Replacement: step 14, image 1 of 2 MacBook Air 11" Early 2015 Upper Case Replacement: step 14, image 2 of 2
      • Disconnect the I/O board by pulling the power cable away from its socket on the logic board.
      • Pull the cable parallel to the face of the logic board toward the front edge of the Air.
      Ask FixBot
    5. MacBook Air 11" Early 2015 Upper Case Replacement: step 15, image 1 of 3 MacBook Air 11" Early 2015 Upper Case Replacement: step 15, image 2 of 3 MacBook Air 11" Early 2015 Upper Case Replacement: step 15, image 3 of 3
      • Use the tip of a spudger to de-route the antenna cables from their notches in the logic board.
      Ask FixBot
    6. MacBook Air 11" Early 2015 Upper Case Replacement: step 16, image 1 of 3 MacBook Air 11" Early 2015 Upper Case Replacement: step 16, image 2 of 3 MacBook Air 11" Early 2015 Upper Case Replacement: step 16, image 3 of 3
      • Gently push the tip of a spudger under the black plastic flap stuck to the display data cable lock to make the lock pop upward and away from the socket.
      • While holding the lock away from the socket, gently pull the display data cable out of its socket.
      • Do not pull upward on the display data cable as you disconnect it, as its socket may break off the logic board.
      Ask FixBot
    7. MacBook Air 11" Early 2015 Upper Case Replacement: step 17, image 1 of 3 MacBook Air 11" Early 2015 Upper Case Replacement: step 17, image 2 of 3 MacBook Air 11" Early 2015 Upper Case Replacement: step 17, image 3 of 3
      • Use the tip of a spudger to pry under the speaker cable connector, lifting it straight up from its socket.
      • De-route the cable from its notch in the logic board.
      Ask FixBot
    8. MacBook Air 11" Early 2015 Upper Case Replacement: step 18, image 1 of 3 MacBook Air 11" Early 2015 Upper Case Replacement: step 18, image 2 of 3 MacBook Air 11" Early 2015 Upper Case Replacement: step 18, image 3 of 3
      • Use the tip of a spudger or your fingernail to flip up the retaining flap on the trackpad ribbon cable ZIF socket.
      • Pull the trackpad ribbon cable straight out of its socket toward the front edge of the Air.
      Ask FixBot
    9. MacBook Air 11" Early 2015 Upper Case Replacement: step 19, image 1 of 3 MacBook Air 11" Early 2015 Upper Case Replacement: step 19, image 2 of 3 MacBook Air 11" Early 2015 Upper Case Replacement: step 19, image 3 of 3
      • Use the tip of a spudger to flip up the retaining flap on the keyboard backlight ribbon cable ZIF socket.
      • Pull the keyboard backlight ribbon cable out of its socket.
      Ask FixBot
    10. MacBook Air 11" Early 2015 Upper Case Replacement: step 20, image 1 of 1
      • Remove the single 2.9 mm T5 Torx screw securing the AirPort/Bluetooth card to the logic board.
      Ask FixBot
    11. MacBook Air 11" Early 2015 Upper Case Replacement: step 21, image 1 of 3 MacBook Air 11" Early 2015 Upper Case Replacement: step 21, image 2 of 3 MacBook Air 11" Early 2015 Upper Case Replacement: step 21, image 3 of 3
      • Slightly lift the free end of the AirPort/Bluetooth board and pull it out of its socket on the logic board.
      • To avoid damaging its socket on the logic board, do not excessively lift the free end of the AirPort/Bluetooth card.
      Ask FixBot
    12. MacBook Air 11" Early 2015 Upper Case Replacement: step 22, image 1 of 1
      • Remove the three 3.6 mm T5 Torx screws securing the logic board to the upper case.
      • In some models these are 3.1 mm T5 Torx screws.
      Ask FixBot
    13. MacBook Air 11" Early 2015 Upper Case Replacement: step 23, image 1 of 3 MacBook Air 11" Early 2015 Upper Case Replacement: step 23, image 2 of 3 MacBook Air 11" Early 2015 Upper Case Replacement: step 23, image 3 of 3
      • Gently lift the logic board assembly from the heat sink end and pull it away from the port side of the case to remove it from the Air.
      • When replacing the logic board, insert the board's rubber edge under the port-side rubber gasket, then lower the board into place.
      Ask FixBot
    1. MacBook Air 11" Early 2015 Upper Case Replacement, I/O Board: step 24, image 1 of 3 MacBook Air 11" Early 2015 Upper Case Replacement, I/O Board: step 24, image 2 of 3 MacBook Air 11" Early 2015 Upper Case Replacement, I/O Board: step 24, image 3 of 3
      • Remove the small rubber gasket from the corner of the upper case nearest the the I/O board.
      • Remove the gasket from the corner nearest display cable connector.
      Ask FixBot
    2. MacBook Air 11" Early 2015 Upper Case Replacement: step 25, image 1 of 2 MacBook Air 11" Early 2015 Upper Case Replacement: step 25, image 2 of 2
      Buy
      • If necessary, use tweezers to remove any tape covering the microphone cable ZIF connector.
      Ask FixBot
    3. MacBook Air 11" Early 2015 Upper Case Replacement: step 26, image 1 of 3 MacBook Air 11" Early 2015 Upper Case Replacement: step 26, image 2 of 3 MacBook Air 11" Early 2015 Upper Case Replacement: step 26, image 3 of 3
      • Use the tip of a spudger to carefully flip up the retaining flap on the microphone cable ZIF socket.
      • Be sure you are prying up on the retaining flap, not the socket itself.
      • With a pair of tweezers, pull the microphone ribbon cable straight out of its socket.
      Ask FixBot
    4. MacBook Air 11" Early 2015 Upper Case Replacement: step 27, image 1 of 3 MacBook Air 11" Early 2015 Upper Case Replacement: step 27, image 2 of 3 MacBook Air 11" Early 2015 Upper Case Replacement: step 27, image 3 of 3
      • Use the tip of a spudger to pry under the speaker cable near the connector, lifting it straight up from its socket.
      Ask FixBot
    5. MacBook Air 11" Early 2015 Upper Case Replacement: step 28, image 1 of 1
      • Remove the single 3.6 mm T5 Torx screw securing the I/O board to the upper case.
      Ask FixBot
    6. MacBook Air 11" Early 2015 Upper Case Replacement: step 29, image 1 of 3 MacBook Air 11" Early 2015 Upper Case Replacement: step 29, image 2 of 3 MacBook Air 11" Early 2015 Upper Case Replacement: step 29, image 3 of 3
      • Carefully lift the I/O board by its power cable and pull it away from the edge of the case.
      Ask FixBot
    1. MacBook Air 11" Early 2015 Upper Case Replacement, Display Assembly: step 30, image 1 of 3 MacBook Air 11" Early 2015 Upper Case Replacement, Display Assembly: step 30, image 2 of 3 MacBook Air 11" Early 2015 Upper Case Replacement, Display Assembly: step 30, image 3 of 3
      • Peel up the six cable loops securing the antenna cables to the upper case.
      • In some models there are seven cable loops.
      • Gently pull the cable loops slightly out of the channel cut into the upper case one at a time.
      • Use your spudger to open up the plastic loops as you de-route the antenna cables through them.
      • Repeat this for each retaining loop until the antenna cables are free from the upper case.
      Ask FixBot
    2. MacBook Air 11" Early 2015 Upper Case Replacement: step 31, image 1 of 2 MacBook Air 11" Early 2015 Upper Case Replacement: step 31, image 2 of 2
      • Remove the inner 4.9 mm T8 Torx screw securing each display hinge to the upper case (two screws total).
      Ask FixBot
    3. MacBook Air 11" Early 2015 Upper Case Replacement: step 32, image 1 of 1
      • Open the display until it is perpendicular to the upper case and place it on a table as shown.
      • While holding the Air steady, remove the remaining 4.9 mm T8 Torx screw from the lower display bracket.
      Ask FixBot
    4. MacBook Air 11" Early 2015 Upper Case Replacement: step 33, image 1 of 1
      • Before removing the last display screw, be sure to hold the display and upper case steady with your other hand. Failure to do so may allow the components to fall onto the table, causing potentially expensive damage.
      • Remove the last 4.9 mm T8 Torx screw securing the display to the upper case.
      Ask FixBot
    5. MacBook Air 11" Early 2015 Upper Case Replacement: step 34, image 1 of 2 MacBook Air 11" Early 2015 Upper Case Replacement: step 34, image 2 of 2
      • Push the upper case slightly toward the display assembly, then rotate it away from the front of the display assembly.
      • Once the two display hinges have cleared the upper case, remove the display.
      Ask FixBot
    1. MacBook Air 11" Early 2015 Upper Case Replacement, Upper Case: step 35, image 1 of 2 MacBook Air 11" Early 2015 Upper Case Replacement, Upper Case: step 35, image 2 of 2
      • Use the flat end of a spudger to pry the right speaker off the adhesive securing it to the upper case.
      • Only pry up on the speaker from the areas of bare aluminum on the upper case. Prying up from the keyboard area may damage the keyboard and the speaker itself.
      • Remove the right speaker from the upper case.
      Ask FixBot
    2. MacBook Air 11" Early 2015 Upper Case Replacement: step 36, image 1 of 2 MacBook Air 11" Early 2015 Upper Case Replacement: step 36, image 2 of 2
      • Use the flat end of a spudger to pry the left speaker off the adhesive securing it to the upper case.
      • Remove the left speaker from the upper case.
      Ask FixBot
    3. MacBook Air 11" Early 2015 Upper Case Replacement: step 37, image 1 of 2 MacBook Air 11" Early 2015 Upper Case Replacement: step 37, image 2 of 2
      • Use the tip of a spudger to pry the microphone away from the side of the upper case.
      • Remove the microphone from the upper case.
      • Upper case remains.
      Ask FixBot
    1. MacBook Air 11" Early 2015 Upper Case Replacement, Upper Case: step 38, image 1 of 3 MacBook Air 11" Early 2015 Upper Case Replacement, Upper Case: step 38, image 2 of 3 MacBook Air 11" Early 2015 Upper Case Replacement, Upper Case: step 38, image 3 of 3
      • The ZIF connector for the keyboard ribbon cable is hidden under the cable itself.
      • Push/lift the keyboard ribbon cable off of the upper case with one hand.
      • With the other hand, use a spudger to flip up the retaining flap on the ZIF connector.
      • Once the retaining flap has been flipped up, carefully pull the ribbon cable straight out of its socket.
      Ask FixBot
    2. MacBook Air 11" Early 2015 Upper Case Replacement: step 39, image 1 of 2 MacBook Air 11" Early 2015 Upper Case Replacement: step 39, image 2 of 2
      • Use the flat end of a spudger to separate the trackpad ribbon cable from the underside of the keyboard.
      • The cable is held in place with adhesive. Work carefully, and be sure to not let the spudger slip and damage any components.
      Ask FixBot
    3. MacBook Air 11" Early 2015 Upper Case Replacement: step 40, image 1 of 1
      • Remove the six 1.5 mm Phillips #00 screws securing the trackpad to the upper case.
      • Check your replacement upper case—if it doesn't have this wide T5 screw, remove it to transfer into the replacement.
      • This is an adjustment screw to set the distance of the click of the trackpad—on reassembly, test the click and adjust this screw until it feels right.
      Ask FixBot
    4. MacBook Air 11" Early 2015 Upper Case Replacement: step 41, image 1 of 3 MacBook Air 11" Early 2015 Upper Case Replacement: step 41, image 2 of 3 MacBook Air 11" Early 2015 Upper Case Replacement: step 41, image 3 of 3
      • Holding the upper case up off the table with one hand, gently push the trackpad up through the upper case.
      • Remove the trackpad from the upper case.
      Ask FixBot
    5. MacBook Air 11" Early 2015 Upper Case Replacement: step 42, image 1 of 1
      • The upper case remains.
      Ask FixBot
13 other people completed this guide.
Sam Goldheart
477,977 Reputation
538 Guides authored
iFixit Member of iFixit
Staff
123 Members
85,577 Guides authored
8 Guide Comments
I don’t see why steps 20 and 21 would be necessary.
info - Reply Share
Steps 20 and 21 are necessary, as there is a logic board screw slightly hidden underneath the Wireless Card, as you can see in Step 22.
Quinten Kilborn - Reply Share
The isight cable in the top right corner: I don’t think yours is installed right, it shouldn’t be going over that rubber grommet, it should be going to the left. Your cable is all stretched. I don’t see why steps 20 and 21 would be necessary, except temporarily to remove the screw. Step 31: My inners are T9 and my outers are T10. Also, I wouldn’t rate this as a 3-bar difficult. There isn’t even anything glued in, you don’t need a heat gun or adhesive remover, no special tools besides the pentalobe bit are required. Estimated time 30-60 minutes.
info - Reply Share
I completed this process in hopes that I would have repaired a power button problem on this MacBook Air. This didn’t seem to work. Any other suggestions. Could it be the logic board? Just trying to find some answers. Wonderful step by step guide, though…Kudos to all involved.
Jonathan Alexander - Reply Share
Past 24 Hours: 2
Past 7 Days: 10
Past 30 Days: 72
All Time: 12,657
