MacBook Air 11" Early 2015 SSD Replacement
    1. MacBook Air 11" Early 2015 SSD Replacement, Lower Case: step 1, image 1 of 1
      Tool used on this step:
      P5 Pentalobe Screwdriver Retina MacBook Pro and Air
      $5.99
      Buy
      • Shut down and close your computer. Lay it on a soft surface top-side down.
      • Remove the following ten screws:
      • Two 8 mm 5-point Pentalobe screws
      • Eight 2.5 mm 5-point Pentalobe screws
      • The special screwdriver needed to remove the 5-point Pentalobe screws can be found here.
      Ask FixBot
    2. MacBook Air 11" Early 2015 SSD Replacement: step 2, image 1 of 1
      • Wedge your fingers between the display and the lower case and pull upward to pop the lower case off the Air.
      Ask FixBot
    1. MacBook Air 11" Early 2015 SSD Replacement, Battery Connector: step 3, image 1 of 2 MacBook Air 11" Early 2015 SSD Replacement, Battery Connector: step 3, image 2 of 2
      • In this step you will disconnect the battery to help avoid shorting out any components during service.
      • Use the flat end of a spudger to pry both short sides of the battery connector upward to disconnect it from its socket on the logic board.
      • Bend the battery cable slightly away from the logic board so the connector will not accidentally bend back and make contact with its socket.
      Ask FixBot
    1. MacBook Air 11" Early 2015 SSD Replacement, SSD: step 4, image 1 of 1
      • Remove the single 2.9 mm T5 Torx screw securing the SSD to the logic board.
      Ask FixBot
    2. MacBook Air 11" Early 2015 SSD Replacement: step 5, image 1 of 3 MacBook Air 11" Early 2015 SSD Replacement: step 5, image 2 of 3 MacBook Air 11" Early 2015 SSD Replacement: step 5, image 3 of 3
      • Lift the free end of the SSD just enough to get a good hold of it.
      • Do not excessively lift the end of the SSD.
      • Pull the drive straight out of its socket and remove it from the logic board.
      • When reinstalling the SSD, be sure it is properly seated before reinstalling its retaining screw.
      Ask FixBot
64 other people completed this guide.
Sam Goldheart
478,549 Reputation
538 Guides authored
iFixit Member of iFixit
Staff
121 Members
72,871 Guides authored
10 Guide Comments
It is possible to upgrade the 128GB ssd to a larger one for this Macbook Air model?
dgoteixeira - Reply Share
Absolutely. Just click the parts link at the top of the page, and choose your size.
Jeff Suovanen - Reply Share
I bought the below model SSD by mistake for my Apple 11" Early 2015 model. Could you please suggest whether it will be compatible.
"Samsung 256GB Flash SSD SSUBX/655-1858K w/ Heatsink for Mac Pro 6,1 JPV256R/0A1"
Ramkumar Sundar - Reply Share
Hi, I am desperately trying to understand how to repair my macbook air 11 inch early 2015. The internal Hd broke. I would like to repair my macbook mounting the SSD suggested by Ifixit but unfortunately the last upgrade of the system was El capitan so, if I understood correctly, I don’t have the right EFI. What can I do? Is there a procedure to install the EFI the SSD owc aura needs? Or should I buy another SSD? Could you suggest me a solution? Thank you in advance for your time
francesca - Reply Share
You should be able to reinstall or restore everything via macOS recovery. Your Mac should support that:
https://support.apple.com/en-us/HT204904
Just boot up and either reinstall from scratch or follow the instructions to restore from a backup (or the old HD if it still turns on)
Barry K - Reply Share
Past 24 Hours: 9
Past 7 Days: 89
Past 30 Days: 348
All Time: 78,040
