Mac mini Model A1283 Top Housing Replacement
    1. Mac mini Model A1283 Top Housing Replacement, Top Housing: step 1, image 1 of 2 Mac mini Model A1283 Top Housing Replacement, Top Housing: step 1, image 2 of 2
      • Power down your Mac mini, disconnect all of the cables, and flip it over.
      • Insert the Jimmy into the crack between the aluminum top housing and the plastic lower housing.
      • The Jimmy should reach a stop about 3/8" down.
      Ask FixBot
    2. Mac mini Model A1283 Top Housing Replacement: step 2, image 1 of 3 Mac mini Model A1283 Top Housing Replacement: step 2, image 2 of 3 Mac mini Model A1283 Top Housing Replacement: step 2, image 3 of 3
      • Gently bend the Jimmy outwards to pry the crack open a little larger and lift the lower housing up a small amount.
      • There are several plastic clips on the lower housing that fit into a channel in the aluminum top housing. Your goal is to use the Jimmy to push these clips inward enough to free them from the channel, while gently pulling up on the lower housing.
      Ask FixBot
    3. Mac mini Model A1283 Top Housing Replacement: step 3, image 1 of 2 Mac mini Model A1283 Top Housing Replacement: step 3, image 2 of 2
      • Once you have the first side free, rotate the Mac mini and start prying up on the front edge.
      • Use the same prying motion to both bend the clips inward and lift the lower housing up out of the top housing.
      Ask FixBot
    4. Mac mini Model A1283 Top Housing Replacement: step 4, image 1 of 2 Mac mini Model A1283 Top Housing Replacement: step 4, image 2 of 2
      • You may need to move the Jimmy along the edge to pry up all of the clips. Be patient and do a little bit at a time.
      Ask FixBot
    5. Mac mini Model A1283 Top Housing Replacement: step 5, image 1 of 2 Mac mini Model A1283 Top Housing Replacement: step 5, image 2 of 2
      • Keep working around the perimeter, freeing the clips along the final edge.
      Ask FixBot
    6. Mac mini Model A1283 Top Housing Replacement: step 6, image 1 of 2 Mac mini Model A1283 Top Housing Replacement: step 6, image 2 of 2
      • Flip the Mac mini back over and lift the top housing off of the lower housing.
      Ask FixBot
20 other people completed this guide.
0 Guide Comments
Past 24 Hours: 10
Past 7 Days: 39
Past 30 Days: 134
All Time: 21,040
