Introduction
Go to step 1 ↓Replace a faulty fan to keep temperatures low.
Power down your Mac mini, disconnect all of the cables, and flip it over.
Insert the Jimmy into the crack between the aluminum top housing and the plastic lower housing.
The Jimmy should reach a stop about 3/8" down.
Slightly squeeze the two retaining arms toward each other and lift the AirPort antenna off its post.
Tool used on this step:Tweezers$4.99
Disconnect the following connectors from the interconnect board:
IR board cable.
Fan cable.
18 other people completed this guide.
