Mac mini Mid 2011 Hard Drive Cable Replacement
    1. Mac mini Mid 2011 Hard Drive Cable Replacement, Bottom Cover: step 1, image 1 of 2 Mac mini Mid 2011 Hard Drive Cable Replacement, Bottom Cover: step 1, image 2 of 2
      • Place your thumbs in the depressions cut into the bottom cover.
      • Rotate the bottom cover counter-clockwise until the white dot painted on the bottom cover is aligned with the ring inscribed on the outer case.
      • You do not need to apply much downward pressure while turning.
      Ask FixBot
    2. Mac mini Mid 2011 Hard Drive Cable Replacement: step 2, image 1 of 1
      • Tilt the mini enough to allow the bottom cover to fall away from the outer case.
      • Remove the bottom cover and set it aside.
      Ask FixBot
    1. Mac mini Mid 2011 Hard Drive Cable Replacement, Fan: step 3, image 1 of 1
      • Remove the two 11.3 mm T6 Torx screws securing the fan to the logic board near the antenna plate.
      Ask FixBot
    2. Mac mini Mid 2011 Hard Drive Cable Replacement: step 4, image 1 of 1
      • Lift the ear of the fan nearest the RAM up off the standoff secured to the outer case.
      • Removing the standoff screw is not necessary to remove the fan. You need only raise the fan enough to lift it off the standoff screw.
      Ask FixBot
    3. Mac mini Mid 2011 Hard Drive Cable Replacement: step 5, image 1 of 3 Mac mini Mid 2011 Hard Drive Cable Replacement: step 5, image 2 of 3 Mac mini Mid 2011 Hard Drive Cable Replacement: step 5, image 3 of 3
      • Lift the fan out of the mini for enough clearance to access its connector.
      • Grab all the wires at once and gently pull straight up to disconnect the fan from the logic board.
      • Do not pry at the socket, or you may rip it from the logic board.
      • Remove the fan.
      Ask FixBot
    1. Mac mini Mid 2011 Hard Drive Cable Replacement, Cowling: step 6, image 1 of 1
      • Remove the single 3.5 mm T6 Torx screw securing the cowling to the heat sink.
      Ask FixBot
    2. Mac mini Mid 2011 Hard Drive Cable Replacement: step 7, image 1 of 1
      • Lift the cowling from the end nearest the antenna plate.
      • Rotate the cowling away from the outer case and remove it from the mini.
      Ask FixBot
    1. Mac mini Mid 2011 Hard Drive Cable Replacement, Antenna Plate: step 8, image 1 of 1
      • Remove the following screws securing the antenna plate to the mini:
      • Two 6.6 mm T8 Torx screws
      • Two 5.0 mm T8 Torx or 2.0 mm Hex screws (either screwdriver will work)
      • When putting back together:
      • It can be difficult to get the hard drive seated correctly such that the antenna plate fits in place correctly. If the screw holes don't line up with those on the hard drive, make sure that the two pins that are in the back of the hard drive are properly seated in the holes at the back of the case, above the housing for the second hard drive.
      • The antenna attaches directly to the hard drive (red markers), therefore attaching the antenna can move the hard drive around and loosen the connection of the hard drive cable to the logic board.
      Ask FixBot
    2. Mac mini Mid 2011 Hard Drive Cable Replacement: step 9, image 1 of 2 Mac mini Mid 2011 Hard Drive Cable Replacement: step 9, image 2 of 2
      • Slightly lift the antenna plate from the end closest to the RAM.
      • Carefully pull the antenna plate away from the circular rim of the outer case.
      • Do not remove the antenna plate yet. It is still attached to the AirPort/ Bluetooth board.
      Ask FixBot
    3. Mac mini Mid 2011 Hard Drive Cable Replacement: step 10, image 1 of 1
      • Use the tip of a spudger to carefully pry the antenna connector up from its socket on the AirPort/Bluetooth board.
      Ask FixBot
    4. Mac mini Mid 2011 Hard Drive Cable Replacement: step 11, image 1 of 1
      • Remove the antenna plate from the mini.
      Ask FixBot
    1. Mac mini Mid 2011 Hard Drive Cable Replacement, Hard Drive: step 12, image 1 of 1
      • Use the flat end of a spudger to pry the hard drive connector up from its socket on the logic board.
      Ask FixBot
    2. Mac mini Mid 2011 Hard Drive Cable Replacement: step 13, image 1 of 1
      • Use the tip of a spudger to lift the IR sensor connector up and out of its socket on the logic board.
      • This connector can be very fragile—lift gently and evenly.
      Ask FixBot
    3. Mac mini Mid 2011 Hard Drive Cable Replacement: step 14, image 1 of 1
      • Remove the following three screws:
      • One 5.0 mm T8 Torx or 2.0 mm Hex screw (either screwdriver will work)
      • One 16.2 mm T6 Torx screw
      • One 26 mm T6 Torx standoff
      Ask FixBot
    4. Mac mini Mid 2011 Hard Drive Cable Replacement: step 15, image 1 of 3 Mac mini Mid 2011 Hard Drive Cable Replacement: step 15, image 2 of 3 Mac mini Mid 2011 Hard Drive Cable Replacement: step 15, image 3 of 3
      Tool used on this step:
      Mac mini Logic Board Removal Tool
      Buy
      • To remove the logic board, the two cylindrical rods of the Mac mini Logic Board Removal Tool must be inserted into the holes highlighted in red. Inserting instruments into any logic board holes other than the ones highlighted in red may destroy the logic board.
      • Insert the Mac mini Logic Board Removal Tool into the two holes highlighted in red. Be sure it makes contact with the top side of outer case below the logic board before proceeding.
      • Carefully pull the tool toward the I/O board. The logic board and I/O board assembly should slightly slide out of the outer case.
      • Cease prying when the I/O board is visibly separated from the outer case.
      • Remove the Mac mini Logic Board Removal tool.
      Ask FixBot
    5. Mac mini Mid 2011 Hard Drive Cable Replacement: step 16, image 1 of 1
      • Simultaneously push the two plastic clips on the far left and right sides of the I/O board toward the middle of the I/O board and pull the I/O board away from the outer case.
      • Only pull the logic board assembly out of the outer case until the edge of the I/O board is about .5" away from the edge of the aluminum outer case.
      Ask FixBot
    6. Mac mini Mid 2011 Hard Drive Cable Replacement: step 17, image 1 of 2 Mac mini Mid 2011 Hard Drive Cable Replacement: step 17, image 2 of 2
      • Pull the hard drive away from the front edge of the mini and remove it from the outer case.
      Ask FixBot
    1. Mac mini Mid 2011 Hard Drive Cable Replacement, Hard Drive Cable: step 18, image 1 of 2 Mac mini Mid 2011 Hard Drive Cable Replacement, Hard Drive Cable: step 18, image 2 of 2
      • Remove the strip of tape connecting the hard drive cable to the hard drive.
      • Remove the hard drive cable by pulling its connector straight away from the hard drive.
      Ask FixBot
17 other people completed this guide.
3 Guide Comments
Where do you get the hard drive replacement cable? Thanks
brussell21 - Reply Share
Where can I get the hard drive replacement cable?
Past 24 Hours: 4
Past 7 Days: 32
Past 30 Days: 132
All Time: 24,882
