Tools
Introduction
Go to step 1 ↓Use this guide to remove the small molded plastic cowl used to direct cool air toward the heat sink.
Place your thumbs in the depressions cut into the bottom cover.
Rotate the bottom cover counter-clockwise until the white dot painted on the bottom cover is aligned with the ring inscribed on the outer case.
Remove the two 11.3 mm T6 Torx screws securing the fan to the logic board near the antenna plate.
9 other people completed this guide.
