Up to 20% off select tools
Mac mini Mid 2011 Bottom Cover Replacement
Views: 27K
View statistics:
Past 24 Hours:
8
Past 7 Days:
29
Past 30 Days:
148
All Time:
26,596
Comments: 20
18 comments on steps, 2 guide comments.
Go to guide comments
Completed: 17
17 people have marked this guide "completed." Will you be next?
Favorites: 6
6 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 5 seconds
Difficulty: Very easy
Introduction
Go to step 1 ↓
Remove the bottom cover to access components inside your Mac mini Mid 2011.
    1. Mac mini Mid 2011 Bottom Cover Replacement, Bottom Cover: step 1, image 1 of 2 Mac mini Mid 2011 Bottom Cover Replacement, Bottom Cover: step 1, image 2 of 2
      • Place your thumbs in the depressions cut into the bottom cover.
      • Rotate the bottom cover counter-clockwise until the white dot painted on the bottom cover is aligned with the ring inscribed on the outer case.
      • You do not need to apply much downward pressure while turning.
      Ask FixBot
    2. Mac mini Mid 2011 Bottom Cover Replacement: step 2, image 1 of 1
      • Tilt the mini enough to allow the bottom cover to fall away from the outer case.
      • Remove the bottom cover and set it aside.
      Ask FixBot
Finish Line
17 other people completed this guide.
Author
with
Walter Galan
712,028 Reputation
1,203 Guides authored
2 Guide Comments
Nailed it man
Joseph Edwards - Reply Share
The base plate on my MM has no thumb dimples, no “lock dots”, and it won’t budge. I’ve tried everything short of prying it off—light touch, firm touch, thumbs, palm, nothing has worked. Any suggestions?
Jonathan Royce - Reply Share
Past 24 Hours: 8
Past 7 Days: 29
Past 30 Days: 148
All Time: 26,596
