Up to 20% off select tools
Mac mini Mid 2010 RAM Replacement
Views: 75K
View statistics:
Past 24 Hours:
5
Past 7 Days:
28
Past 30 Days:
165
All Time:
74,708
Comments: 18
3 comments on steps, 15 guide comments.
Go to guide comments
Completed: 101
101 people have marked this guide "completed." Will you be next?
Favorites: 23
23 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 5 - 10 minutes
Difficulty: Easy
Featured Guide
This guide has been found to be exceptionally cool by the iFixit staff.
Fix Kit
This kit contains all the parts and tools needed to complete this guide.
Parts
Introduction
Go to step 1 ↓
Removing the RAM on the mid 2010 Mac mini is an easy task that requires no tools.
    1. Mac mini Mid 2010 RAM Replacement, Bottom Cover: step 1, image 1 of 2 Mac mini Mid 2010 RAM Replacement, Bottom Cover: step 1, image 2 of 2
      • Place your thumbs in the depressions cut into the bottom cover.
      • Rotate the bottom cover counter-clockwise until the white dot painted on the bottom cover is aligned with the ring inscribed on the outer case.
      Ask FixBot
    2. Mac mini Mid 2010 RAM Replacement: step 2, image 1 of 1
      • Tilt the mini enough to allow the bottom cover to fall away from the outer case.
      • Remove the bottom cover and set it aside.
      Ask FixBot
    1. Mac mini Mid 2010 RAM Replacement, RAM: step 3, image 1 of 2 Mac mini Mid 2010 RAM Replacement, RAM: step 3, image 2 of 2
      • Release the tabs on each side of the RAM chip by simultaneously pushing each tab away from the RAM.
      • These tabs lock the chip in place and releasing them will cause the chip to "pop" up.
      • After the RAM chip has popped up, pull it straight out of its socket.
      • Repeat this process if a second RAM chip is installed.
      Ask FixBot
101 other people completed this guide.
Author
with
15 Guide Comments
Do the RAM chips have to be paired, or could I replace a one gig bar with a 4 gig bar?
Thanks for any hints!
Hansen - Reply Share
They don't need to be paired, although that is the optimum. Just remember, it is best to make sure they are the same speed, or the Mac will just operate both RAMs at the speed of the slowest stick. For example, if you have 2x 1GB PC8500 sticks in there, and you replace one of them with a 4GB PC10600 stick (fastest speed this Mac Mini will run) you will get a benefit form the extra memory, but not the full speed upgrade as both RAMs will operate at the speed of the 8500 stick. Does that make sense? So replacing both with 2x 2GB PC10600 will give you better performance.
Mike Haines - Reply Share
This Mac Mini will run PC10600 RAM sticks, although I believe only 4GB per slot.
This Mac can run 16GB of RAM, mine does. Just FYI.
Greg Martin - Reply Share
Interesting. I want to try that.
seaniepie - Reply Share
Past 24 Hours: 5
Past 7 Days: 28
Past 30 Days: 165
All Time: 74,708
