Up to 20% off select tools
Mac mini Late 2018 Disassembly
Views: 16K
View statistics:
Past 24 Hours:
11
Past 7 Days:
84
Past 30 Days:
470
All Time:
16,247
Comments: 21
15 comments on steps, 6 guide comments.
Go to guide comments
Completed: 15
15 people have marked this guide "completed." Will you be next?
Favorites: 3
3 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 30 minutes - 1 hour
Difficulty: Moderate
Community-Contributed Guide
Tools
    1. Mac mini Late 2018 Disassembly, Out of the box: step 1, image 1 of 2 Mac mini Late 2018 Disassembly, Out of the box: step 1, image 2 of 2
      • So here it is, exactly the same form factor as the previous Mac mini, but now in Space Gray
      Ask FixBot
    2. Mac mini Late 2018 Disassembly, Lets flip it over: step 2, image 1 of 3 Mac mini Late 2018 Disassembly, Lets flip it over: step 2, image 2 of 3 Mac mini Late 2018 Disassembly, Lets flip it over: step 2, image 3 of 3
      • Once flipped over, a familiar black cover is revealed.
      • Pry open the lid to release it from the three large screws
      • The lid had a soft foam inside to dampen the vibrations of the beefed up fan
      Ask FixBot
    3. Mac mini Late 2018 Disassembly, Take off the metal cover: step 3, image 1 of 2 Mac mini Late 2018 Disassembly, Take off the metal cover: step 3, image 2 of 2
      • The lid is secured with the same TR6 screws as the 2014 model
      Ask FixBot
    4. Mac mini Late 2018 Disassembly, Reveal the innards: step 4, image 1 of 2 Mac mini Late 2018 Disassembly, Reveal the innards: step 4, image 2 of 2
      • The antenna cable is very short, so watch out; rotate the cover to reveal the internals
      Ask FixBot
    5. Mac mini Late 2018 Disassembly, Antenna cable: step 5, image 1 of 2 Mac mini Late 2018 Disassembly, Antenna cable: step 5, image 2 of 2
      • The antenna cable is held down with a little TX6 screw
      • It has a tiny washer to make sure no stress is applied to the cable
      Ask FixBot
    6. Mac mini Late 2018 Disassembly, Take off the fan: step 6, image 1 of 3 Mac mini Late 2018 Disassembly, Take off the fan: step 6, image 2 of 3 Mac mini Late 2018 Disassembly, Take off the fan: step 6, image 3 of 3
      • The fan has four identical TX6 screws holding it down
      • The screws go trough a rubber tube to reduce vibration
      Ask FixBot
    7. Mac mini Late 2018 Disassembly, Take the fan out: step 7, image 1 of 3 Mac mini Late 2018 Disassembly, Take the fan out: step 7, image 2 of 3 Mac mini Late 2018 Disassembly, Take the fan out: step 7, image 3 of 3
      • Underneath the fan the connector pops off easilly
      • The fan feels solid. Much better than previous models
      Ask FixBot
    8. Mac mini Late 2018 Disassembly, Next, the motherboard: step 8, image 1 of 3 Mac mini Late 2018 Disassembly, Next, the motherboard: step 8, image 2 of 3 Mac mini Late 2018 Disassembly, Next, the motherboard: step 8, image 3 of 3
      • Now, lets take out the motherboard
      • Massive (for the mini) TX10 screws secure the motherboard to the chassis
      Ask FixBot
    9. Mac mini Late 2018 Disassembly, Unplug some wires: step 9, image 1 of 2 Mac mini Late 2018 Disassembly, Unplug some wires: step 9, image 2 of 2
      Tool used on this step:
      Buy
      • The power supply can be unplugged by as many wires as possible between your iFixit tweezers and pull upwards
      • Also take off the tiny power led connector
      Ask FixBot
    10. Mac mini Late 2018 Disassembly, Motherboard out: step 10, image 1 of 2 Mac mini Late 2018 Disassembly, Motherboard out: step 10, image 2 of 2
      • Slide the motherboard out by gently applying pressure to the heatsink
      Ask FixBot
    11. Mac mini Late 2018 Disassembly, Details on the design: step 11, image 1 of 3 Mac mini Late 2018 Disassembly, Details on the design: step 11, image 2 of 3 Mac mini Late 2018 Disassembly, Details on the design: step 11, image 3 of 3
      • Some interesting design choices made here. A full size CMOS battery
      • The wifi wiring runs underneath the large speaker
      • The power button is attached to a ultra flat cable that runs in an arc along the heatsink
      Ask FixBot
    12. Mac mini Late 2018 Disassembly, Motherboard underside: step 12, image 1 of 3 Mac mini Late 2018 Disassembly, Motherboard underside: step 12, image 2 of 3 Mac mini Late 2018 Disassembly, Motherboard underside: step 12, image 3 of 3
      • We flip over the motherboard to see a massive amount of tiny components
      • Also some familiar pieces of foam all over the place
      Ask FixBot
    13. Mac mini Late 2018 Disassembly, Memory cover: step 13, image 1 of 3 Mac mini Late 2018 Disassembly, Memory cover: step 13, image 2 of 3 Mac mini Late 2018 Disassembly, Memory cover: step 13, image 3 of 3
      • But now what we are all here for. The RAM
      • Four TX5 screws holt it down
      Ask FixBot
    14. Mac mini Late 2018 Disassembly, Slide off the cover: step 14, image 1 of 3 Mac mini Late 2018 Disassembly, Slide off the cover: step 14, image 2 of 3 Mac mini Late 2018 Disassembly, Slide off the cover: step 14, image 3 of 3
      • The memory cover slides off at an angle
      Ask FixBot
    15. Mac mini Late 2018 Disassembly, Rubber spacers: step 15, image 1 of 2 Mac mini Late 2018 Disassembly, Rubber spacers: step 15, image 2 of 2
      • These rubber parts will be a pain to put back on later.
      • There are tiny pieces of rubber in it that need to slide into the metal clips holding the memory in place
      Ask FixBot
    16. Mac mini Late 2018 Disassembly, Memory out: step 16, image 1 of 3 Mac mini Late 2018 Disassembly, Memory out: step 16, image 2 of 3 Mac mini Late 2018 Disassembly, Memory out: step 16, image 3 of 3
      • The memory itself sits upside down in its sockets
      • The springs are very strong and will shoot the memory in your face if you're not careful!
      Ask FixBot
    17. Mac mini Late 2018 Disassembly, Power supply connector: step 17, image 1 of 3 Mac mini Late 2018 Disassembly, Power supply connector: step 17, image 2 of 3 Mac mini Late 2018 Disassembly, Power supply connector: step 17, image 3 of 3
      • The power supply is secured in a similar way as with the previous models
      • A little clip has to be removed, and the connector can be rotated
      Ask FixBot
    18. Mac mini Late 2018 Disassembly, Power supply screws: step 18, image 1 of 3 Mac mini Late 2018 Disassembly, Power supply screws: step 18, image 2 of 3 Mac mini Late 2018 Disassembly, Power supply screws: step 18, image 3 of 3
      • The power supply is held down with three TX6 screws
      • They look just like the fan screws, but they appear just a little bit thicker and with longer thread
      Ask FixBot
    19. Mac mini Late 2018 Disassembly, End of the line: step 19, image 1 of 2 Mac mini Late 2018 Disassembly, End of the line: step 19, image 2 of 2
      • After taking out the power supply we are left with an empty shell
      • I really enjoyed taking this mini apart. My verdict is it's much easier than the 2014 model as cables are in a more logical place
      Ask FixBot
15 other people completed this guide.
Author
with
Wouter de Vries
687 Reputation
1 Guide authored
6 Guide Comments
What happens to the machine if the SSD fails? Will the entire logic board need to be replaced? I have a feeling that the chances of SSD failing would be significantly higher than Ram… So shouldn’t apple make SSD removable as well?
Sam - Reply Share
Failing SSD means a failing motherboard. In my experience, apple ssd-s are very reliable. Upgradable memory allows you to use a device longer. If you configure it with 16GB today, you might want to max out the memory in the future, once prices go down.
Wouter de Vries - Reply Share
What about the CPU, is it in a socket or soldered in?
Steve Seg - Reply Share
I didn’t have the courage to take the heatsink off. So we’ll have to wait for someone who does.
Mich würde interessieren, wie die CMOS Batterie getauscht wird, bzw. welcher Typ es ist.
Sven Arendsen - Reply Share
Past 24 Hours: 11
Past 7 Days: 84
Past 30 Days: 470
All Time: 16,247
