Mac mini Late 2018 Antenna Plate Replacement
    1. Mac mini Late 2018 Antenna Plate Replacement, Bottom Cover: step 1, image 1 of 1
      • Power off and unplug your Mac mini before you begin.
      • Use an opening tool to pry the bottom cover up off of the Mac mini.
      Ask FixBot
    2. Mac mini Late 2018 Antenna Plate Replacement: step 2, image 1 of 2 Mac mini Late 2018 Antenna Plate Replacement: step 2, image 2 of 2
      • Lift and remove the bottom cover.
      • To reinstall the cover:
      • Align it carefully so that the words "Mac mini" can be read when the ports are facing you.
      • Then, press down on the cover to snap its three hidden clips into place.
      Ask FixBot
    1. Mac mini Late 2018 Antenna Plate Replacement, Antenna Plate: step 3, image 1 of 1
      Tool used on this step:
      Magnetic Project Mat
      $19.95
      Buy
      • Remove six TR6 Torx security screws securing the antenna plate, of the following lengths:
      • Three 4.1 mm shoulder screws
      • Three 1.8 mm screws
      • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your Mac.
      Ask FixBot
    2. Mac mini Late 2018 Antenna Plate Replacement: step 4, image 1 of 2 Mac mini Late 2018 Antenna Plate Replacement: step 4, image 2 of 2
      • Do not completely remove the antenna plate; it is still connected to the Mac mini by an antenna cable.
      • With the Mac mini's ports facing you, carefully lift the antenna plate and slide it about an inch to the right.
      Ask FixBot
    3. Mac mini Late 2018 Antenna Plate Replacement: step 5, image 1 of 2 Mac mini Late 2018 Antenna Plate Replacement: step 5, image 2 of 2
      • Use a T6 Torx driver to remove the 2.8 mm screw securing the antenna cable to the Mac mini's logic board.
      Ask FixBot
    4. Mac mini Late 2018 Antenna Plate Replacement: step 6, image 1 of 3 Mac mini Late 2018 Antenna Plate Replacement: step 6, image 2 of 3 Mac mini Late 2018 Antenna Plate Replacement: step 6, image 3 of 3
      Buy
      • The antenna cable connector and socket are fragile.
      • Use the point of a spudger or fine tweezers to gently pry the antenna cable connector straight up off its socket on the logic board.
      • To reconnect the cable, use tweezers to position it carefully over its socket on the logic board, and then press it straight down until it snaps into place.
      • If you need more slack in the cable, you can temporarily pry it from the clips securing it to the antenna plate.
      Ask FixBot
    5. Mac mini Late 2018 Antenna Plate Replacement: step 7, image 1 of 1
      • Remove the antenna plate from the Mac mini.
      Ask FixBot
6 other people completed this guide.
Jeff Suovanen
455,054 Reputation
259 Guides authored
iFixit Member of iFixit
Staff
122 Members
72,401 Guides authored
5 Guide Comments
Wow, I have no problem doing this, but I walked my parents through a RAM upgrade on their 2014 Mac Mini when all you to do is remove the bottom cover and pull the modules out. I’ve already told them to skip this model. Great guide, I have the board in front of me and waiting for Amazon to deliver the new RAM today. Thanks!
willg - Reply Share
“a RAM upgrade on their 2014 Mac Mini” should be “a RAM upgrade on their 2012 Mac Mini”
willg - Reply Share
What’s the antenna cable for? My WiFi works without connecting it
Achyuta A - Reply Share
Me too.It just works without plate. Not sure whether it’s assistant antenna for further and reliable signal… or just fake parts to check whether users tried to tear down and give Apple chance to reject customer service…you know it’s quite fragile part.
Joon - Reply Share
Broke the female connector in the process of replacing the ram. It detached from the board. It's there a way to fix it? Wifi signal is still working but not as strong. Everything else working. Thanks
Ignacio Sala - Reply Share
Past 24 Hours: 7
Past 7 Days: 32
Past 30 Days: 118
All Time: 13,217
