Up to 20% off select tools
Mac mini Late 2014 SSD Replacement
Views: 201K
View statistics:
Past 24 Hours:
20
Past 7 Days:
144
Past 30 Days:
640
All Time:
201,131
Comments: 110
78 comments on steps, 32 guide comments.
Go to guide comments
Completed: 114
114 people have marked this guide "completed." Will you be next?
Favorites: 32
32 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 15 minutes
Difficulty: Moderate
Featured Guide
This guide has been found to be exceptionally cool by the iFixit staff.
Parts
Tools
Introduction
Go to step 1 ↓
Use this guide to replace the SSD stick in an SSD only, or Fusion Drive model of the Mac mini Late 2014.
    1. Mac mini Late 2014 SSD Replacement, Bottom Cover: step 1, image 1 of 1
      • The bottom cover is clipped onto three screw posts.
      • Pry near, but not right on the screw posts.
      Ask FixBot
    2. Mac mini Late 2014 SSD Replacement: step 2, image 1 of 3 Mac mini Late 2014 SSD Replacement: step 2, image 2 of 3 Mac mini Late 2014 SSD Replacement: step 2, image 3 of 3
      • Use the plastic opening tool to pry the bottom cover up off of the Mac mini.
      Ask FixBot
    3. Mac mini Late 2014 SSD Replacement: step 3, image 1 of 2 Mac mini Late 2014 SSD Replacement: step 3, image 2 of 2
      • Lift and remove the bottom cover.
      Ask FixBot
    1. Mac mini Late 2014 SSD Replacement, Antenna Plate: step 4, image 1 of 1
      • Remove the following TR6 screws from the antenna plate:
      • Three 4.1 mm screws
      • Three 1.9 mm screws
      Ask FixBot
    2. Mac mini Late 2014 SSD Replacement: step 5, image 1 of 2 Mac mini Late 2014 SSD Replacement: step 5, image 2 of 2
      • Do not completely remove the antenna plate; it is still connected to the Mac mini by an antenna cable.
      • With the I/O ports facing you, flip the antenna plate to the right to allow access to the antenna cable connector.
      Ask FixBot
    3. Mac mini Late 2014 SSD Replacement: step 6, image 1 of 1
      • Remove the single 3.4 mm T6 screw and washer from the antenna cable.
      • Be careful not to lose the washer when removing the screw.
      Ask FixBot
    4. Mac mini Late 2014 SSD Replacement: step 7, image 1 of 2 Mac mini Late 2014 SSD Replacement: step 7, image 2 of 2
      • Use the point of a spudger to lift the antenna connector straight up off its socket on the airport card.
      Ask FixBot
    5. Mac mini Late 2014 SSD Replacement: step 8, image 1 of 2 Mac mini Late 2014 SSD Replacement: step 8, image 2 of 2
      • Carefully pull the antenna cable out from the gap between the power supply and case.
      Ask FixBot
    6. Mac mini Late 2014 SSD Replacement: step 9, image 1 of 1
      • Remove the antenna plate from the Mac mini.
      Ask FixBot
    1. Mac mini Late 2014 SSD Replacement, SSD: step 10, image 1 of 1
      • Remove the 5 mm T5 screw securing the SSD.
      Ask FixBot
    2. Mac mini Late 2014 SSD Replacement: step 11, image 1 of 3 Mac mini Late 2014 SSD Replacement: step 11, image 2 of 3 Mac mini Late 2014 SSD Replacement: step 11, image 3 of 3
      • Lift the free end of the SSD up slightly and pull it out of its socket.
      Ask FixBot
    3. Mac mini Late 2014 SSD Replacement: step 12, image 1 of 3 Mac mini Late 2014 SSD Replacement: step 12, image 2 of 3 Mac mini Late 2014 SSD Replacement: step 12, image 3 of 3
      • Carefully lift the SSD out of the case without scratching or touching the gold contacts.
      Ask FixBot
114 other people completed this guide.
Author
with
Sam Goldheart
478,973 Reputation
538 Guides authored
iFixit Member of iFixit
Staff
119 Members
72,966 Guides authored
32 Guide Comments
If I have a Mac Mini without SSD, only with normal Hard Drive (NO Fusion). Can I install a new one SSD like on this tutorial?. Thanks!
Juan Miguel Ramirez - Reply Share
Please see my comment later in the thread.
Thomas Hall - Reply Share
Si, yo lo hice y la diferencia es abismal. Necesitaras un adaptador y por supuesto el SSD. Yes, I did it and the difference is abysmal. You will need an adapter and of course the SSD.
Manuel Jesús Flores Jiménez - Reply Share
Yes, but you need to add a cable to connect it. If you buy the SSD from OWC, they sell a kit which includes the cable and tools (for an extra $20-40, depending on what size/model SSD you get).
shamino - Reply Share
I have the same question as Juan
Cronan McNamara - Reply Share
Past 24 Hours: 20
Past 7 Days: 144
Past 30 Days: 640
All Time: 201,131
