Mac mini Late 2014 Logic Board Replacement
    1. Mac mini Late 2014 Logic Board Replacement, Bottom Cover: step 1, image 1 of 1
      • The bottom cover is clipped onto three screw posts.
      • Pry near, but not right on the screw posts.
      Ask FixBot
    2. Mac mini Late 2014 Logic Board Replacement: step 2, image 1 of 3 Mac mini Late 2014 Logic Board Replacement: step 2, image 2 of 3 Mac mini Late 2014 Logic Board Replacement: step 2, image 3 of 3
      • Use the plastic opening tool to pry the bottom cover up off of the Mac mini.
      Ask FixBot
    3. Mac mini Late 2014 Logic Board Replacement: step 3, image 1 of 2 Mac mini Late 2014 Logic Board Replacement: step 3, image 2 of 2
      • Lift and remove the bottom cover.
      Ask FixBot
    1. Mac mini Late 2014 Logic Board Replacement, Antenna Plate: step 4, image 1 of 1
      • Remove the following TR6 screws from the antenna plate:
      • Three 4.1 mm screws
      • Three 1.9 mm screws
      Ask FixBot
    2. Mac mini Late 2014 Logic Board Replacement: step 5, image 1 of 2 Mac mini Late 2014 Logic Board Replacement: step 5, image 2 of 2
      • Do not completely remove the antenna plate; it is still connected to the Mac mini by an antenna cable.
      • With the I/O ports facing you, flip the antenna plate to the right to allow access to the antenna cable connector.
      Ask FixBot
    3. Mac mini Late 2014 Logic Board Replacement: step 6, image 1 of 1
      • Remove the single 3.4 mm T6 screw and washer from the antenna cable.
      • Be careful not to lose the washer when removing the screw.
      Ask FixBot
    4. Mac mini Late 2014 Logic Board Replacement: step 7, image 1 of 2 Mac mini Late 2014 Logic Board Replacement: step 7, image 2 of 2
      • Use the point of a spudger to lift the antenna connector straight up off its socket on the airport card.
      Ask FixBot
    5. Mac mini Late 2014 Logic Board Replacement: step 8, image 1 of 2 Mac mini Late 2014 Logic Board Replacement: step 8, image 2 of 2
      • Carefully pull the antenna cable out from the gap between the power supply and case.
      Ask FixBot
    6. Mac mini Late 2014 Logic Board Replacement: step 9, image 1 of 1
      • Remove the antenna plate from the Mac mini.
      Ask FixBot
    1. Mac mini Late 2014 Logic Board Replacement, Fan Assembly: step 10, image 1 of 1
      • Remove the two 12 mm T6 screws from the fan.
      • Loosen the 27 mm T6 captive screw–it will get removed with the fan assembly.
      Ask FixBot
    2. Mac mini Late 2014 Logic Board Replacement: step 11, image 1 of 3 Mac mini Late 2014 Logic Board Replacement: step 11, image 2 of 3 Mac mini Late 2014 Logic Board Replacement: step 11, image 3 of 3
      • The fan connector is trapped under the edge of the fan and cannot be disconnected until the fan is moved.
      • Do not attempt to remove the fan entirely.
      • Lift the fan straight up to free the captive screw from its hole in the logic board.
      • Pull the fan away from the SSD until you can easily access the fan connector.
      Ask FixBot
    3. Mac mini Late 2014 Logic Board Replacement: step 12, image 1 of 2 Mac mini Late 2014 Logic Board Replacement: step 12, image 2 of 2
      • Use the point of a spudger to lift the fan connector straight up out of its socket on the logic board.
      Ask FixBot
    4. Mac mini Late 2014 Logic Board Replacement: step 13, image 1 of 1
      • Remove the fan from the Mac mini.
      Ask FixBot
    1. Mac mini Late 2014 Logic Board Replacement, Logic Board Assembly: step 14, image 1 of 1
      • Remove the 2.6 mm T6 screw securing the SATA cable connector bracket.
      Ask FixBot
    2. Mac mini Late 2014 Logic Board Replacement: step 15, image 1 of 2 Mac mini Late 2014 Logic Board Replacement: step 15, image 2 of 2
      • Remove the SATA cable connector bracket.
      Ask FixBot
    3. Mac mini Late 2014 Logic Board Replacement: step 16, image 1 of 2 Mac mini Late 2014 Logic Board Replacement: step 16, image 2 of 2
      • Use the flat end of a spudger to lift the SATA cable connector up off of its socket on the logic board.
      Ask FixBot
    4. Mac mini Late 2014 Logic Board Replacement: step 17, image 1 of 2 Mac mini Late 2014 Logic Board Replacement: step 17, image 2 of 2
      • Use the tip of a spudger to disconnect the IR sensor cable connector by prying it straight up from its socket.
      Ask FixBot
    5. Mac mini Late 2014 Logic Board Replacement: step 18, image 1 of 1
      • The following three steps only apply to Mac minis equipped with a PCIe SSD. Skip the next three steps if your Mac mini only has a hard drive.
      • Remove the two 2.6 mm T6 screws securing the PCIe SSD cable bracket.
      Ask FixBot
    6. Mac mini Late 2014 Logic Board Replacement: step 19, image 1 of 2 Mac mini Late 2014 Logic Board Replacement: step 19, image 2 of 2
      • Remove the PCIe SSD cable bracket.
      Ask FixBot
    7. Mac mini Late 2014 Logic Board Replacement: step 20, image 1 of 2 Mac mini Late 2014 Logic Board Replacement: step 20, image 2 of 2
      • Lift the PCIe SSD connector up off its socket.
      Ask FixBot
    8. Mac mini Late 2014 Logic Board Replacement: step 21, image 1 of 1
      • Remove the single 16 mm T6 screw securing the logic board.
      Ask FixBot
    9. Mac mini Late 2014 Logic Board Replacement: step 22, image 1 of 1
      Tool used on this step:
      Mac mini Logic Board Removal Tool
      Buy
      • To remove the logic board, the two cylindrical rods of the Mac mini Logic Board Removal Tool must be inserted into the holes highlighted in red. Inserting instruments into any logic board holes other than the ones highlighted in red may destroy the logic board.
      • Insert the Mac mini Logic Board Removal Tool into the two holes highlighted in red. Be sure the rods make contact with the case under the logic board before proceeding.
      Ask FixBot
    10. Mac mini Late 2014 Logic Board Replacement: step 23, image 1 of 3 Mac mini Late 2014 Logic Board Replacement: step 23, image 2 of 3 Mac mini Late 2014 Logic Board Replacement: step 23, image 3 of 3
      • Carefully pull the tool toward the I/O board. The logic board and I/O board assembly should slightly slide out of the outer case.
      • Cease prying when the removal tool makes contact with the opening in the rear case.
      • Remove the Mac mini Logic Board Removal tool.
      Ask FixBot
    11. Mac mini Late 2014 Logic Board Replacement: step 24, image 1 of 2 Mac mini Late 2014 Logic Board Replacement: step 24, image 2 of 2
      • Pull the DC-In cable connector straight out of its socket on the logic board.
      Ask FixBot
    12. Mac mini Late 2014 Logic Board Replacement: step 25, image 1 of 2 Mac mini Late 2014 Logic Board Replacement: step 25, image 2 of 2
      • Carefully slide the logic board assembly out of the Mac mini, minding any cables that may get caught.
      Ask FixBot
    1. Mac mini Late 2014 Logic Board Replacement, Heat Sink: step 26, image 1 of 2 Mac mini Late 2014 Logic Board Replacement, Heat Sink: step 26, image 2 of 2
      • Remove the following screws securing the heat sink to the logic board:
      • Four 8.6 mm T8 Torx screws
      • One 2.9 mm T6 Torx screw
      • Be careful not to lose the springs held beneath each of the T8 heat sink screws, they may fall off of the screws as you remove them.
      • During reassembly, tighten these screws evenly to ensure the heat sink stays flat against the CPU.
      Ask FixBot
    2. Mac mini Late 2014 Logic Board Replacement: step 27, image 1 of 3 Mac mini Late 2014 Logic Board Replacement: step 27, image 2 of 3 Mac mini Late 2014 Logic Board Replacement: step 27, image 3 of 3
      • Remove the heat sink from the logic board.
      • If the heat sink appears to be stuck to the logic board after removing all screws, it may be helpful to use a spudger to separate the two components.
      • Don't reassemble your Mac mini without applying a new layer of thermal paste.We have a thermal paste guide to show you how.
      Ask FixBot
    1. Mac mini Late 2014 Logic Board Replacement, I/O Bezel: step 28, image 1 of 1
      • Remove the following T6 Torx screws from the I/O port antenna cables:
      • Three 2.8 mm screws with washers
      • One 3.4 mm screw
      • One 2.7 mm screw
      Ask FixBot
    2. Mac mini Late 2014 Logic Board Replacement: step 29, image 1 of 2 Mac mini Late 2014 Logic Board Replacement: step 29, image 2 of 2
      • Use the point of a spudger to lift the power switch cable connector straight up out of its socket on the logic board.
      Ask FixBot
    3. Mac mini Late 2014 Logic Board Replacement: step 30, image 1 of 3 Mac mini Late 2014 Logic Board Replacement: step 30, image 2 of 3 Mac mini Late 2014 Logic Board Replacement: step 30, image 3 of 3
      • Use the point of a spudger to lift the antenna connectors up off of their sockets on the AirPort card.
      Ask FixBot
    4. Mac mini Late 2014 Logic Board Replacement: step 31, image 1 of 1
      • Remove the four 2.7 mm T6 Torx screws holding the I/O bezel to the logic board.
      Ask FixBot
    5. Mac mini Late 2014 Logic Board Replacement: step 32, image 1 of 2 Mac mini Late 2014 Logic Board Replacement: step 32, image 2 of 2
      • Remove the foam bumper from between the I/O bezel and USB ports.
      Ask FixBot
    6. Mac mini Late 2014 Logic Board Replacement: step 33, image 1 of 2 Mac mini Late 2014 Logic Board Replacement: step 33, image 2 of 2
      • Pull the I/O bezel off of the logic board, minding any cables that may get caught.
      • Try not to handle the small steel tabs on the logic board and I/O bezel, as oils from your fingers may cause interference issues. Before installing the logic board assembly, clean the metal tabs to remove any oils transferred during the removal process.
      Ask FixBot
    1. Mac mini Late 2014 Logic Board Replacement, Logic Board: step 34, image 1 of 1
      • Remove the following T6 Torx screws securing the speaker to the logic board:
      • One 3.6 mm screw
      • One 3.6 mm large headed screw
      Ask FixBot
    2. Mac mini Late 2014 Logic Board Replacement: step 35, image 1 of 2 Mac mini Late 2014 Logic Board Replacement: step 35, image 2 of 2
      • Do not attempt to remove the speaker entirely as it is still attached to the logic board.
      • Nudge the speaker gently out of the way to allow access to the speaker's connector.
      Ask FixBot
    3. Mac mini Late 2014 Logic Board Replacement: step 36, image 1 of 3 Mac mini Late 2014 Logic Board Replacement: step 36, image 2 of 3 Mac mini Late 2014 Logic Board Replacement: step 36, image 3 of 3
      • Use the flat end of a spudger to carefully lift the speaker connector up out of its socket on the logic board.
      • Remove the speaker from the logic board.
      Ask FixBot
    4. Mac mini Late 2014 Logic Board Replacement: step 37, image 1 of 1
      • Remove the 2.7 mm T5 screw securing the AirPort card.
      Ask FixBot
    5. Mac mini Late 2014 Logic Board Replacement: step 38, image 1 of 3 Mac mini Late 2014 Logic Board Replacement: step 38, image 2 of 3 Mac mini Late 2014 Logic Board Replacement: step 38, image 3 of 3
      • Lift the free end of the AirPort card enough to grasp it by the edges.
      • Pull the AirPort card straight out of its socket on the logic board and remove it from the Mac Mini.
      Ask FixBot
18 other people completed this guide.
Sam Goldheart
478,462 Reputation
538 Guides authored
iFixit Member of iFixit
Staff
122 Members
72,401 Guides authored
4 Guide Comments
is there any internal battery on the logic board..
sokratis162 - Reply Share
Are all Mac Mini cases the same from 2011 on? Could I take out my 2011 guts and put in one from 2014?
jbasa - Reply Share
hello a question as it is called the piece that contains the hard disk?
Miguel - Reply Share
It is called a hard drive tray or hard drive carrier. You can find the guide to remove it here.
Arthur Shi - Reply Share
Past 24 Hours: 5
Past 7 Days: 66
Past 30 Days: 276
All Time: 53,615
