Mac mini Late 2014 AirPort Card Replacement
    1. Mac mini Late 2014 AirPort Card Replacement, Bottom Cover: step 1, image 1 of 1
      • The bottom cover is clipped onto three screw posts.
      • Pry near, but not right on the screw posts.
      Ask FixBot
    2. Mac mini Late 2014 AirPort Card Replacement: step 2, image 1 of 3 Mac mini Late 2014 AirPort Card Replacement: step 2, image 2 of 3 Mac mini Late 2014 AirPort Card Replacement: step 2, image 3 of 3
      • Use the plastic opening tool to pry the bottom cover up off of the Mac mini.
      Ask FixBot
    3. Mac mini Late 2014 AirPort Card Replacement: step 3, image 1 of 2 Mac mini Late 2014 AirPort Card Replacement: step 3, image 2 of 2
      • Lift and remove the bottom cover.
      Ask FixBot
    1. Mac mini Late 2014 AirPort Card Replacement, Antenna Plate: step 4, image 1 of 1
      • Remove the following TR6 screws from the antenna plate:
      • Three 4.1 mm screws
      • Three 1.9 mm screws
      Ask FixBot
    2. Mac mini Late 2014 AirPort Card Replacement: step 5, image 1 of 2 Mac mini Late 2014 AirPort Card Replacement: step 5, image 2 of 2
      • Do not completely remove the antenna plate; it is still connected to the Mac mini by an antenna cable.
      • With the I/O ports facing you, flip the antenna plate to the right to allow access to the antenna cable connector.
      Ask FixBot
    3. Mac mini Late 2014 AirPort Card Replacement: step 6, image 1 of 1
      • Remove the single 3.4 mm T6 screw and washer from the antenna cable.
      • Be careful not to lose the washer when removing the screw.
      Ask FixBot
    4. Mac mini Late 2014 AirPort Card Replacement: step 7, image 1 of 2 Mac mini Late 2014 AirPort Card Replacement: step 7, image 2 of 2
      • Use the point of a spudger to lift the antenna connector straight up off its socket on the airport card.
      Ask FixBot
    5. Mac mini Late 2014 AirPort Card Replacement: step 8, image 1 of 2 Mac mini Late 2014 AirPort Card Replacement: step 8, image 2 of 2
      • Carefully pull the antenna cable out from the gap between the power supply and case.
      Ask FixBot
    6. Mac mini Late 2014 AirPort Card Replacement: step 9, image 1 of 1
      • Remove the antenna plate from the Mac mini.
      Ask FixBot
    1. Mac mini Late 2014 AirPort Card Replacement, AirPort Card: step 10, image 1 of 1
      Ask FixBot
    2. Mac mini Late 2014 AirPort Card Replacement: step 11, image 1 of 3 Mac mini Late 2014 AirPort Card Replacement: step 11, image 2 of 3 Mac mini Late 2014 AirPort Card Replacement: step 11, image 3 of 3
      • Use the point of a spudger to lift the antenna connectors up off their sockets.
      Ask FixBot
    3. Mac mini Late 2014 AirPort Card Replacement: step 12, image 1 of 1
      • Remove the 2.7 mm T5 screw securing the AirPort card.
      Ask FixBot
    4. Mac mini Late 2014 AirPort Card Replacement: step 13, image 1 of 3 Mac mini Late 2014 AirPort Card Replacement: step 13, image 2 of 3 Mac mini Late 2014 AirPort Card Replacement: step 13, image 3 of 3
      • Lift the free end of the AirPort card enough to grasp it by the edges.
      Ask FixBot
    5. Mac mini Late 2014 AirPort Card Replacement: step 14, image 1 of 2 Mac mini Late 2014 AirPort Card Replacement: step 14, image 2 of 2
      • Pull the AirPort card straight out of its socket on the logic board and remove it from the Mac mini.
      Ask FixBot
16 other people completed this guide.
Sam Goldheart
478,462 Reputation
538 Guides authored
iFixit Member of iFixit
Staff
122 Members
72,401 Guides authored
4 Guide Comments
Thanks. Took all of 20 minutes start to finish to upgrade my broken NIC.
Erik Westlund - Reply Share
Hmm, look like an M.2 interface, could an M.2 SSD be installed instead?
The Bionic Cyclist - Reply Share
Can confirm that the airport card for the 2015 Macbook Pro fits and functions perfectly as a replacement if you can’t find the mac mini one.
Sam Goddard - Reply Share
If something wrong with my bluetooth, is it also replace this logic board ?
Gordon Lee - Reply Share
Past 24 Hours: 6
Past 7 Days: 48
Past 30 Days: 190
All Time: 25,428
