Up to 20% off select tools
Mac mini Late 2012 RAM Replacement
Views: 153K
View statistics:
Past 24 Hours:
9
Past 7 Days:
71
Past 30 Days:
347
All Time:
152,822
Comments: 28
21 comments on steps, 7 guide comments.
Go to guide comments
Completed: 187
187 people have marked this guide "completed." Will you be next?
Favorites: 75
75 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 5 - 15 minutes
Difficulty: Easy
Featured Guide
This guide has been found to be exceptionally cool by the iFixit staff.
Fix Kit
This kit contains all the parts and tools needed to complete this guide.
Parts
Introduction
Go to step 1 ↓
Removing the RAM is an easy task that requires no tools.
    1. Mac mini Late 2012 RAM Replacement, Bottom Cover: step 1, image 1 of 2 Mac mini Late 2012 RAM Replacement, Bottom Cover: step 1, image 2 of 2
      • Place your thumbs in the depressions cut into the bottom cover.
      • Rotate the bottom cover counter-clockwise until the white dot painted on the bottom cover is aligned with the ring inscribed on the outer case.
      • You do not need to apply much downward pressure while turning.
      Ask FixBot
    2. Mac mini Late 2012 RAM Replacement: step 2, image 1 of 1
      • Tilt the mini enough to allow the bottom cover to fall away from the outer case.
      • Remove the bottom cover and set it aside.
      Ask FixBot
    1. Mac mini Late 2012 RAM Replacement, RAM: step 3, image 1 of 2 Mac mini Late 2012 RAM Replacement, RAM: step 3, image 2 of 2
      • Release the tabs on each side of the RAM chip by simultaneously pushing each tab away from the chip.
      • These tabs lock the chip in place and releasing them will cause the chip to "pop" up.
      • After the RAM chip has popped up, pull it straight out of its socket.
      • Repeat this process if a second RAM chip is installed.
      Ask FixBot
187 other people completed this guide.
Author
with
Andrew Optimus Goldheart
516,605 Reputation
405 Guides authored
iFixit Member of iFixit
Staff
119 Members
72,966 Guides authored
7 Guide Comments
So if I were to replace the Ram on my mac mini I would only have the option to choose between the 2 gb chip or the 4gb chip? I know dumb question lol.
Bianca - Reply Share
2x8GB is as much as those motherboards can handle.
Kevin Shaffer - Reply Share
Dear everyone,
Does this mac mini accept :
KINGSTON DDR3 PC3-12800 - 2 x 4 Go (8 Go) 1600 MHZ - CAS 10 - HyperX Fury Black Series
Thank you.
Marouane - Reply Share
I always consult Crucial's memory configuration tool. For a late-2012 Mac mini, see http://www.crucial.com/usa/en/compatible....
According to them, this Mac can go up to 16GB (2 SO-DIMMs of 8GB each). The SO-DIMMs should be DDRL3L-1600 (DDR3L PC3L-12800, CL=11, unbuffered, non-ECC, DDR3L-1600, 1.35v)
The SO-DIMMs you mentioned seem like they should be compatible (CL=10 should work fine in a computer that can accept CL=11). But I would only buy from a vendor that has a compatibility guarantee. If there's a problem, I would want to be able to return them for a refund.
David Charlap - Reply Share
The SODIMMs don't need to be low voltage DDR3L (i.e. 1.35 volt). In fact Apple recommends (https://support.apple.com/en-gb/HT202593) regular 1.5 volt DDR3 and most late 2012 Mac Minis were shipped with it. So is Crucial wrong? The truth is that either will work.
John Morley - Reply Share
Past 24 Hours: 9
Past 7 Days: 71
Past 30 Days: 347
All Time: 152,822
