Mac mini Late 2012 Heat Sink Replacement
    1. Mac mini Late 2012 Heat Sink Replacement, Bottom Cover: step 1, image 1 of 2 Mac mini Late 2012 Heat Sink Replacement, Bottom Cover: step 1, image 2 of 2
      • Place your thumbs in the depressions cut into the bottom cover.
      • Rotate the bottom cover counter-clockwise until the white dot painted on the bottom cover is aligned with the ring inscribed on the outer case.
      • You do not need to apply much downward pressure while turning.
      Ask FixBot
    2. Mac mini Late 2012 Heat Sink Replacement: step 2, image 1 of 1
      • Tilt the mini enough to allow the bottom cover to fall away from the outer case.
      • Remove the bottom cover and set it aside.
      Ask FixBot
    1. Mac mini Late 2012 Heat Sink Replacement, Fan: step 3, image 1 of 1
      • Remove the two 11.3 mm T6 Torx screws securing the fan to the logic board near the antenna plate.
      Ask FixBot
    2. Mac mini Late 2012 Heat Sink Replacement: step 4, image 1 of 1
      • Lift the ear of the fan nearest the RAM up off the standoff secured to the outer case.
      • Removing the standoff screw is not necessary to remove the fan. You need only raise the fan enough to lift it off the standoff screw.
      Ask FixBot
    3. Mac mini Late 2012 Heat Sink Replacement: step 5, image 1 of 3 Mac mini Late 2012 Heat Sink Replacement: step 5, image 2 of 3 Mac mini Late 2012 Heat Sink Replacement: step 5, image 3 of 3
      • Lift the fan out of the mini for enough clearance to access its connector.
      • Grab all the wires at once and gently pull straight up to disconnect the fan from the logic board.
      • Do not pry at the socket, or you may rip it from the logic board.
      • Remove the fan.
      Ask FixBot
    1. Mac mini Late 2012 Heat Sink Replacement, Cowling: step 6, image 1 of 1
      • Remove the single 3.5 mm T6 Torx screw securing the cowling to the heat sink.
      Ask FixBot
    2. Mac mini Late 2012 Heat Sink Replacement: step 7, image 1 of 1
      • Lift the cowling from the end nearest the antenna plate.
      • Rotate the cowling away from the outer case and remove it from the mini.
      Ask FixBot
    1. Mac mini Late 2012 Heat Sink Replacement, Antenna Plate: step 8, image 1 of 1
      • Remove the following screws securing the antenna plate to the mini:
      • Two 6.6 mm T8 Torx screws
      • Two 5.0 mm T8 Torx or 2.0 mm Hex screws (either screwdriver will work)
      • When putting back together:
      • It can be difficult to get the hard drive seated correctly such that the antenna plate fits in place correctly. If the screw holes don't line up with those on the hard drive, make sure that the two pins that are in the back of the hard drive are properly seated in the holes at the back of the case, above the housing for the second hard drive.
      • The antenna attaches directly to the hard drive (red markers), therefore attaching the antenna can move the hard drive around and loosen the connection of the hard drive cable to the logic board.
      Ask FixBot
    2. Mac mini Late 2012 Heat Sink Replacement: step 9, image 1 of 2 Mac mini Late 2012 Heat Sink Replacement: step 9, image 2 of 2
      • Slightly lift the antenna plate from the end closest to the RAM.
      • Carefully pull the antenna plate away from the circular rim of the outer case.
      • Do not remove the antenna plate yet. It is still attached to the AirPort/ Bluetooth board.
      Ask FixBot
    3. Mac mini Late 2012 Heat Sink Replacement: step 10, image 1 of 1
      • Use the tip of a spudger to carefully pry the antenna connector up from its socket on the AirPort/Bluetooth board.
      Ask FixBot
    4. Mac mini Late 2012 Heat Sink Replacement: step 11, image 1 of 1
      • Remove the antenna plate from the mini.
      Ask FixBot
    1. Mac mini Late 2012 Heat Sink Replacement, Logic Board: step 12, image 1 of 2 Mac mini Late 2012 Heat Sink Replacement, Logic Board: step 12, image 2 of 2
      • Use the flat end of a spudger to pry the hard drive connector up from its socket on the logic board.
      Ask FixBot
    2. Mac mini Late 2012 Heat Sink Replacement: step 13, image 1 of 1
      • Use the tip of a spudger to lift the IR sensor connector up and out of its socket on the logic board.
      • Make sure to pry up from beneath the wires and not underneath the socket.
      Ask FixBot
    3. Mac mini Late 2012 Heat Sink Replacement: step 14, image 1 of 1
      • Remove the following three screws:
      • One 5.0 mm T8 Torx or 2.0 mm Hex screw (either screwdriver will work)
      • One 16.2 mm T6 Torx screw
      • One 26 mm T6 Torx standoff
      Ask FixBot
    4. Mac mini Late 2012 Heat Sink Replacement: step 15, image 1 of 3 Mac mini Late 2012 Heat Sink Replacement: step 15, image 2 of 3 Mac mini Late 2012 Heat Sink Replacement: step 15, image 3 of 3
      Tool used on this step:
      Mac mini Logic Board Removal Tool
      Buy
      • To remove the logic board, the two cylindrical rods of the Mac mini Logic Board Removal Tool must be inserted into the holes highlighted in red. Inserting instruments into any logic board holes other than the ones highlighted in red may destroy the logic board.
      • Insert the Mac mini Logic Board Removal Tool into the two holes highlighted in red. Be sure it makes contact with the top side of outer case below the logic board before proceeding.
      • Carefully pull the tool toward the I/O board. The logic board and I/O board assembly should slightly slide out of the outer case.
      • Cease prying when the I/O board is visibly separated from the outer case.
      • Remove the Mac mini Logic Board Removal tool.
      Ask FixBot
    5. Mac mini Late 2012 Heat Sink Replacement: step 16, image 1 of 1
      • Pull the I/O board/logic board assembly out of the outer case enough to access the power connector.
      • Use your fingers to disconnect the DC-In cable from the logic board.
      • Pull the power cable connector toward the front side of the mini.
      Ask FixBot
    6. Mac mini Late 2012 Heat Sink Replacement: step 17, image 1 of 1
      • Carefully slide the logic board assembly out of the mini, minding any cables that may get caught.
      Ask FixBot
    1. Mac mini Late 2012 Heat Sink Replacement, Speaker: step 18, image 1 of 1
      • Remove the following two screws securing the speaker to the logic board assembly:
      • One 3.5 mm T6 Torx screw
      • One 3.7 mm T6 Torx screw
      Ask FixBot
    2. Mac mini Late 2012 Heat Sink Replacement: step 19, image 1 of 2 Mac mini Late 2012 Heat Sink Replacement: step 19, image 2 of 2
      • Lift but do not remove the speaker assembly, as it still remains connected to the logic board via the speaker connector.
      • Carefully lift the speaker wires upward to lift the speaker connector up and out of its socket on the logic board.
      • Lift and remove the speaker away from the logic board.
      Ask FixBot
    1. Mac mini Late 2012 Heat Sink Replacement, Heat Sink: step 20, image 1 of 1
      • Remove the single 5 mm T6 Torx standoff from the heat sink near the edge of the logic board.
      Ask FixBot
    2. Mac mini Late 2012 Heat Sink Replacement: step 21, image 1 of 1
      • Remove the following screws securing the heat sink to the logic board:
      • Four 8.6 mm T8 Torx screws
      • One 2.6 mm T6 Torx screw
      • Keep track of the springs held beneath each of the T8 heat sink screws.
      Ask FixBot
    3. Mac mini Late 2012 Heat Sink Replacement: step 22, image 1 of 1
      • Remove the heat sink from the logic board, minding any cables that may get caught.
      • If the heat sink appears to be stuck to the logic board after removing all screws, it may be helpful to use a spudger to separate the two components.
      • If you need to mount the heat sink back onto the logic board, we have a thermal paste guide that makes replacing the thermal compound easy.
      Ask FixBot
To reassemble your device, follow these instructions in reverse order. Be sure to follow our thermal paste guide to reapply the thermal compound on the CPU.
16 other people completed this guide.
Andrew Optimus Goldheart
515,912 Reputation
406 Guides authored
iFixit Member of iFixit
Staff
122 Members
72,401 Guides authored
5 Guide Comments
When reinstalling the heatsink the Platform controller chip has a huge gap, so you have to either use a thermal pad, ton of thermal paste or shim the gap. I ended up using a shim made out of a soda can. I posted photos here:
https://gist.github.com/victornpb/ae16f3...
Victor - Reply Share
There is no need for the controller to be cooled. It is the same with the MacBooks of that time. The controller chip isnt even covered by the heatsink.
Fred - Reply Share
Hello,
I'll refresh this thread a bit - I replaced the thermal paste on the processor and since then my Mac mini patch 2012 has been raging at tepmperatures between 70 and 100 degrees. What could I have screwed up? The system laughs like crazy, I rebooted and PRAM and SMC and tried with SAFE MODE , changed the paste again and same thing. Do you have any experience with this type of problem?
tom - Reply Share
@tom46654 I'm experiencing exactly the same problem. After replacing the thermal paste on my Late 2012 Mac mini, the CPU temperature is around 70–75 °C at idle and can reach 99–100 °C under heavy load. The room temperature is only about 22 °C.
I've also reapplied the thermal paste, but it made no difference. I'm starting to suspect that the heatsink may not be making proper contact with the CPU, possibly due to one of the four mounting screws/standoffs.
Did you ever find out what was causing the problem in your case?
bognarb90 - Reply Share
@bognarb90 To be honest, I never actually solved that problem; I’ve got a completely different computer now. I managed to bring the temperatures down on my old mini by using a fan from a MacPro 6.1 and a Noctua NA-FC1. The temperatures dropped as low as 20 degrees, but the fan was picking up dust even from the neighbouring houses ;) In my opinion, increasingly demanding operating systems (I was using OCLP) consume more resources and place a greater strain on components that were built for older, less demanding systems. I don’t think there’s a happy medium – it’s DIY all the way.
Nidec fan from Apple Pro 2013 is easy for soldering and converting for that new role as a additional fan.
tom - Reply Share
Past 24 Hours: 9
Past 7 Days: 90
Past 30 Days: 389
All Time: 32,217
