Up to 20% off select tools
Mac mini Late 2012 Bottom Cover Replacement
Views: 16K
View statistics:
Past 24 Hours:
5
Past 7 Days:
29
Past 30 Days:
156
All Time:
15,829
Comments: 18
18 comments on steps.
Completed: 19
19 people have marked this guide "completed." Will you be next?
Favorites: 7
7 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 5 - 20 seconds
Difficulty: Very easy
Introduction
Go to step 1 ↓
Remove the bottom cover to access components inside your Mac mini Mid 2011.
    1. Mac mini Late 2012 Bottom Cover Replacement, Bottom Cover: step 1, image 1 of 2 Mac mini Late 2012 Bottom Cover Replacement, Bottom Cover: step 1, image 2 of 2
      • Place your thumbs in the depressions cut into the bottom cover.
      • Rotate the bottom cover counter-clockwise until the white dot painted on the bottom cover is aligned with the ring inscribed on the outer case.
      • You do not need to apply much downward pressure while turning.
      Ask FixBot
    2. Mac mini Late 2012 Bottom Cover Replacement: step 2, image 1 of 1
      • Tilt the mini enough to allow the bottom cover to fall away from the outer case.
      • Remove the bottom cover and set it aside.
      Ask FixBot
19 other people completed this guide.
Author
with
Andrew Optimus Goldheart
516,610 Reputation
405 Guides authored
iFixit Member of iFixit
Staff
119 Members
72,966 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 29
Past 30 Days: 156
All Time: 15,829
