Up to 20% off select tools
Mac mini (PowerPC) Upper Case Replacement
Views: 13K
View statistics:
Past 24 Hours:
3
Past 7 Days:
24
Past 30 Days:
119
All Time:
13,422
Comments: 9
7 comments on steps, 2 guide comments.
Go to guide comments
Completed: 12
12 people have marked this guide "completed." Will you be next?
Favorites: 4
4 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: No estimate
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
How to remove the upper case.
    1. Mac mini (PowerPC) Upper Case Replacement, Top Housing: step 1, image 1 of 2 Mac mini (PowerPC) Upper Case Replacement, Top Housing: step 1, image 2 of 2
      • Power down your Mac mini, disconnect all of the cables, and flip it over.
      • Insert the Jimmy into the crack between the aluminum top housing and the plastic lower housing.
      • The Jimmy should reach a stop about 3/8" down.
      Ask FixBot
    2. Mac mini (PowerPC) Upper Case Replacement: step 2, image 1 of 3 Mac mini (PowerPC) Upper Case Replacement: step 2, image 2 of 3 Mac mini (PowerPC) Upper Case Replacement: step 2, image 3 of 3
      • Gently bend the Jimmy outwards to pry the crack open a little larger and lift the lower housing up a small amount.
      • There are several plastic clips on the lower housing that fit into a channel in the aluminum top housing. Your goal is to use the Jimmy to push these clips inward enough to free them from the channel, while gently pulling up on the lower housing.
      Ask FixBot
    3. Mac mini (PowerPC) Upper Case Replacement: step 3, image 1 of 2 Mac mini (PowerPC) Upper Case Replacement: step 3, image 2 of 2
      • Once you have the first side free, rotate the Mac mini and start prying up on the front edge.
      • Use the same prying motion to both bend the clips inward and lift the lower housing up out of the top housing.
      Ask FixBot
    4. Mac mini (PowerPC) Upper Case Replacement: step 4, image 1 of 2 Mac mini (PowerPC) Upper Case Replacement: step 4, image 2 of 2
      • You may need to move the Jimmy along the edge to pry up all of the clips. Be patient and do a little bit at a time.
      Ask FixBot
    5. Mac mini (PowerPC) Upper Case Replacement: step 5, image 1 of 2 Mac mini (PowerPC) Upper Case Replacement: step 5, image 2 of 2
      • Keep working around the perimeter, freeing the clips along the final edge.
      Ask FixBot
    6. Mac mini (PowerPC) Upper Case Replacement: step 6, image 1 of 2 Mac mini (PowerPC) Upper Case Replacement: step 6, image 2 of 2
      • Flip the Mac mini back over and lift the top housing off of the lower housing.
      Ask FixBot
12 other people completed this guide.
Attached Documents
Author
with
iRobot
1 Reputation
632 Guides authored
2 Guide Comments
those Putty Knifes are:
too smal
too sharp
too expensive.
Better use a 100mm broad Spatula; (opens all the claws in on step)
out of plastic is good enough and cheap.
And use two of them at one time.
spatula - Reply Share
No, I didn’t think the Jimmy is expensive or too small.
And the Jimmy didn’t break something so it is the best solution I think!
Toni Makkaroni - Reply Share
Past 24 Hours: 3
Past 7 Days: 24
Past 30 Days: 119
All Time: 13,422
