Mac mini (2024) Speaker Replacement
    1. Mac mini (2024) Speaker Replacement, Before you begin: step 1, image 1 of 2 Mac mini (2024) Speaker Replacement, Before you begin: step 1, image 2 of 2
      • Fully shut down your Mac mini and unplug all cables from it.
      • Flip over your Mac mini and place it on a clean, flat surface to avoid scratching the chassis.
      Ask FixBot
    1. Mac mini (2024) Speaker Replacement, Create a gap: step 2, image 1 of 3 Mac mini (2024) Speaker Replacement, Create a gap: step 2, image 2 of 3 Mac mini (2024) Speaker Replacement, Create a gap: step 2, image 3 of 3
      • Using the Jimmy or other metal tools during this step could scratch the aluminum chassis; however, it's the simplest way to perform this step. Follow the alternate instructions to avoid scratching the aluminum.
      • Insert a Jimmy into the gap between the bottom cover and the chassis.
      • Pry up the bottom cover to create a gap.
      • Alternatively, you can insert the point of a spudger into one of the plastic vent holes and pry up to create a gap big enough to insert an opening pick into.
      • Keep the Jimmy inserted under the bottom cover.
      Ask FixBot
    2. Mac mini (2024) Speaker Replacement, Insert an opening pick: step 3, image 1 of 3 Mac mini (2024) Speaker Replacement, Insert an opening pick: step 3, image 2 of 3 Mac mini (2024) Speaker Replacement, Insert an opening pick: step 3, image 3 of 3
      • Insert an opening pick into the gap created by the Jimmy.
      • Remove the Jimmy.
      Ask FixBot
    3. Mac mini (2024) Speaker Replacement, Release the pins: step 4, image 1 of 3 Mac mini (2024) Speaker Replacement, Release the pins: step 4, image 2 of 3 Mac mini (2024) Speaker Replacement, Release the pins: step 4, image 3 of 3
      • Slide the opening pick along the bottom cover until you feel it snag on a pin.
      • There are four pins total—one at each corner of the bottom cover.
      • Twist the pick to lift the pin out of its slot.
      Ask FixBot
    4. Mac mini (2024) Speaker Replacement: step 5, image 1 of 3 Mac mini (2024) Speaker Replacement: step 5, image 2 of 3 Mac mini (2024) Speaker Replacement: step 5, image 3 of 3
      • Continue sliding and prying with the pick along the perimeter of the bottom cover to release the remaining pins.
      • Don't insert the pick more than an inch when sliding near the power button, as you risk damaging the cable.
      • During reassembly, press along the perimeter of the bottom until you hear and feel all four pins click back into place.
      Ask FixBot
    5. Mac mini (2024) Speaker Replacement: step 6, image 1 of 2 Mac mini (2024) Speaker Replacement: step 6, image 2 of 2
      • Don't remove the bottom cover, as it's still connected to the Mac mini with a cable.
      • Lift the edge of the bottom cover opposite the power button and flip it over to expose the power button cable.
      Ask FixBot
    6. Mac mini (2024) Speaker Replacement, Disconnect the power button: step 7, image 1 of 2 Mac mini (2024) Speaker Replacement, Disconnect the power button: step 7, image 2 of 2
      • The power button cable is very fragile! You don't have to disconnect it to access the internals— but it will require you to keep the bottom cover propped up.
      • To disconnect the cable and remove the bottom cover, follow the next two steps.
      • If you don't disconnect the cable, prop up the bottom cover to prevent straining the cable and skip the next two steps.
      • Grip the power button cable close to the head and pull it away from its socket to disconnect it.
      Ask FixBot
    7. Mac mini (2024) Speaker Replacement, Remove the bottom cover: step 8, image 1 of 1
      • Remove the bottom cover.
      Ask FixBot
    1. Mac mini (2024) Speaker Replacement, Remove the inner plate screws: step 9, image 1 of 2 Mac mini (2024) Speaker Replacement, Remove the inner plate screws: step 9, image 2 of 2
      Tool used on this step:
      FixMat
      $36.95
      Buy
      • While the Mac mini uses Torx Plus screws, standard Torx bits work. Make sure to apply constant, downward force to prevent stripping.
      • Use a T5 Torx screwdriver to remove the twelve screws securing the inner plate:
      • Eight 3.4 mm‑long screws
      • Four 2.4 mm‑long screws
      Ask FixBot
    2. Mac mini (2024) Speaker Replacement, Separate the inner plate: step 10, image 1 of 3 Mac mini (2024) Speaker Replacement, Separate the inner plate: step 10, image 2 of 3 Mac mini (2024) Speaker Replacement, Separate the inner plate: step 10, image 3 of 3
      • Insert the point of a spudger into one of the clips' slots on the inner plate.
      • Pry up the inner plate enough so you can grip the edge along the same side as the headphone jack.
      Ask FixBot
    3. Mac mini (2024) Speaker Replacement: step 11, image 1 of 2 Mac mini (2024) Speaker Replacement: step 11, image 2 of 2
      • Pull the inner plate away from the chassis to slide it out from under the lip on the heat sink.
      • During reassembly, slide the inner plate back under the heat sink and press along its edges to secure it in the chassis.
      Ask FixBot
    4. Mac mini (2024) Speaker Replacement: step 12, image 1 of 3 Mac mini (2024) Speaker Replacement: step 12, image 2 of 3 Mac mini (2024) Speaker Replacement: step 12, image 3 of 3
      • Don't remove the inner plate yet, as it's still connected to the Mac mini by a cable.
      • Lift the inner plate and flip it over to expose the wireless module cable.
      Ask FixBot
    5. Mac mini (2024) Speaker Replacement, Remove the wireless module cover: step 13, image 1 of 3 Mac mini (2024) Speaker Replacement, Remove the wireless module cover: step 13, image 2 of 3 Mac mini (2024) Speaker Replacement, Remove the wireless module cover: step 13, image 3 of 3
      • Use one hand to secure the wireless module during this step.
      • Use a Torx Plus 5IP screwdriver to remove the four 2.5 mm‑long screws securing the wireless module cover.
      Ask FixBot
    6. Mac mini (2024) Speaker Replacement, Remove the cover: step 14, image 1 of 2 Mac mini (2024) Speaker Replacement, Remove the cover: step 14, image 2 of 2
      • Remove the wireless module cover.
      • During reassembly, look the bottom of the cover to find the foam rectangle. Align the foam rectangle over the wireless module press connector to find the proper orientation for the cover.
      Ask FixBot
    7. Mac mini (2024) Speaker Replacement, Disconnect the wireless module: step 15, image 1 of 2 Mac mini (2024) Speaker Replacement, Disconnect the wireless module: step 15, image 2 of 2
      • Insert the point of a spudger under one of the short edges of the wireless module press connector.
      • Don't insert your spudger anywhere else, as you risk dislodging surface-mounted components.
      • Pry up to disconnect the wireless module.
      Ask FixBot
    8. Mac mini (2024) Speaker Replacement, Remove the inner plate: step 16, image 1 of 1
      • Remove the inner plate.
      Ask FixBot
    1. Mac mini (2024) Speaker Replacement, Remove the fan screws: step 17, image 1 of 2 Mac mini (2024) Speaker Replacement, Remove the fan screws: step 17, image 2 of 2
      • If you're following this guide to clean your fan, this is a good time to do so.
      • Remove the four screws securing the fan:
      • Two 2.4 mm‑long Torx Plus 3IP screws
      • Two 7.9 mm‑long Torx Plus 5IP screws
      Ask FixBot
    2. Mac mini (2024) Speaker Replacement, Reposition the fan: step 18, image 1 of 3 Mac mini (2024) Speaker Replacement, Reposition the fan: step 18, image 2 of 3 Mac mini (2024) Speaker Replacement, Reposition the fan: step 18, image 3 of 3
      • Lift the fan out of its recess in the chassis and flip it over to expose its wire and connector.
      • Let the fan rest on the chassis and heat sink.
      Ask FixBot
    3. Mac mini (2024) Speaker Replacement, Disconnect the fan: step 19, image 1 of 3 Mac mini (2024) Speaker Replacement, Disconnect the fan: step 19, image 2 of 3 Mac mini (2024) Speaker Replacement, Disconnect the fan: step 19, image 3 of 3
      • Use tweezers to peel back the tape covering the fan ZIF connector.
      Ask FixBot
    4. Mac mini (2024) Speaker Replacement: step 20, image 1 of 2 Mac mini (2024) Speaker Replacement: step 20, image 2 of 2
      • Use the point of a spudger, or your fingernail, to flip up the locking tab on the fan ZIF connector.
      Ask FixBot
    5. Mac mini (2024) Speaker Replacement: step 21, image 1 of 2 Mac mini (2024) Speaker Replacement: step 21, image 2 of 2
      • Use tweezers, or your fingers, to slide the ZIF connector straight out of its socket.
      Ask FixBot
    6. Mac mini (2024) Speaker Replacement, Remove the fan: step 22, image 1 of 1
      • Remove the fan.
      Ask FixBot
    1. Mac mini (2024) Speaker Replacement, Remove the speaker screws: step 23, image 1 of 2 Mac mini (2024) Speaker Replacement, Remove the speaker screws: step 23, image 2 of 2
      • Use a Torx Plus 5IP screwdriver to remove the three screws securing the speaker:
      • Two 4.1 mm‑long screws
      • One 3.7 mm‑long screw
      Ask FixBot
    2. Mac mini (2024) Speaker Replacement, Reposition the speaker: step 24, image 1 of 3 Mac mini (2024) Speaker Replacement, Reposition the speaker: step 24, image 2 of 3 Mac mini (2024) Speaker Replacement, Reposition the speaker: step 24, image 3 of 3
      Ask FixBot
    3. Mac mini (2024) Speaker Replacement: step 25, image 1 of 2 Mac mini (2024) Speaker Replacement: step 25, image 2 of 2
      • Pull the speaker over the edge of the chassis to expose its cable and its connector.
      • Rest the speaker on the edge of the chassis.
      Ask FixBot
    4. Mac mini (2024) Speaker Replacement, Disconnect the speaker: step 26, image 1 of 3 Mac mini (2024) Speaker Replacement, Disconnect the speaker: step 26, image 2 of 3 Mac mini (2024) Speaker Replacement, Disconnect the speaker: step 26, image 3 of 3
      • Grip the speaker cable close to the head and pull it away from its socket to disconnect it.
      Ask FixBot
    5. Mac mini (2024) Speaker Replacement, Remove the speaker: step 27, image 1 of 1
      • Remove the speaker.
      Ask FixBot
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Mac mini (2024) Answers Community for help.
Alex Diaz-Kokaisl
247,759 Reputation
1,203 Guides authored
iFixit Member of iFixit
Staff
123 Members
85,453 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 20
Past 30 Days: 110
All Time: 2,153
