Up to 20% off select tools
Mac mini (2024) Fan Replacement
Views: 12K
View statistics:
Past 24 Hours:
26
Past 7 Days:
167
Past 30 Days:
820
All Time:
12,312
Comments: 56
56 comments on steps.
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 2
2 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 20 - 35 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
Use this guide to replace or clean the fan in your Mac mini (2024).
This guide was written with a baseline M4 Mac mini. Although the internals for the M4 Pro version are slightly different, the disassembly procedure is the same.
Before buying a replacement fan, use this guide to clean your fan to confirm that dirt or dust isn't your issue.
    1. Mac mini (2024) Fan Replacement, Before you begin: step 1, image 1 of 2 Mac mini (2024) Fan Replacement, Before you begin: step 1, image 2 of 2
      • Fully shut down your Mac mini and unplug all cables from it.
      • Flip over your Mac mini and place it on a clean, flat surface to avoid scratching the chassis.
      Ask FixBot
    1. Mac mini (2024) Fan Replacement, Create a gap: step 2, image 1 of 3 Mac mini (2024) Fan Replacement, Create a gap: step 2, image 2 of 3 Mac mini (2024) Fan Replacement, Create a gap: step 2, image 3 of 3
      • Using the Jimmy or other metal tools during this step could scratch the aluminum chassis; however, it's the simplest way to perform this step. Follow the alternate instructions to avoid scratching the aluminum.
      • Insert a Jimmy into the gap between the bottom cover and the chassis.
      • Pry up the bottom cover to create a gap.
      • Alternatively, you can insert the point of a spudger into one of the plastic vent holes and pry up to create a gap big enough to insert an opening pick into.
      • Keep the Jimmy inserted under the bottom cover.
      Ask FixBot
    2. Mac mini (2024) Fan Replacement, Insert an opening pick: step 3, image 1 of 3 Mac mini (2024) Fan Replacement, Insert an opening pick: step 3, image 2 of 3 Mac mini (2024) Fan Replacement, Insert an opening pick: step 3, image 3 of 3
      • Insert an opening pick into the gap created by the Jimmy.
      • Remove the Jimmy.
      Ask FixBot
    3. Mac mini (2024) Fan Replacement, Release the pins: step 4, image 1 of 3 Mac mini (2024) Fan Replacement, Release the pins: step 4, image 2 of 3 Mac mini (2024) Fan Replacement, Release the pins: step 4, image 3 of 3
      • Slide the opening pick along the bottom cover until you feel it snag on a pin.
      • There are four pins total—one at each corner of the bottom cover.
      • Twist the pick to lift the pin out of its slot.
      Ask FixBot
    4. Mac mini (2024) Fan Replacement: step 5, image 1 of 3 Mac mini (2024) Fan Replacement: step 5, image 2 of 3 Mac mini (2024) Fan Replacement: step 5, image 3 of 3
      • Continue sliding and prying with the pick along the perimeter of the bottom cover to release the remaining pins.
      • Don't insert the pick more than an inch when sliding near the power button, as you risk damaging the cable.
      • During reassembly, press along the perimeter of the bottom until you hear and feel all four pins click back into place.
      Ask FixBot
    5. Mac mini (2024) Fan Replacement: step 6, image 1 of 2 Mac mini (2024) Fan Replacement: step 6, image 2 of 2
      • Don't remove the bottom cover, as it's still connected to the Mac mini with a cable.
      • Lift the edge of the bottom cover opposite the power button and flip it over to expose the power button cable.
      Ask FixBot
    6. Mac mini (2024) Fan Replacement, Disconnect the power button: step 7, image 1 of 2 Mac mini (2024) Fan Replacement, Disconnect the power button: step 7, image 2 of 2
      • The power button cable is very fragile! You don't have to disconnect it to access the internals— but it will require you to keep the bottom cover propped up.
      • To disconnect the cable and remove the bottom cover, follow the next two steps.
      • If you don't disconnect the cable, prop up the bottom cover to prevent straining the cable and skip the next two steps.
      • Grip the power button cable close to the head and pull it away from its socket to disconnect it.
      Ask FixBot
    7. Mac mini (2024) Fan Replacement, Remove the bottom cover: step 8, image 1 of 1
      • Remove the bottom cover.
      Ask FixBot
    1. Mac mini (2024) Fan Replacement, Remove the inner plate screws: step 9, image 1 of 2 Mac mini (2024) Fan Replacement, Remove the inner plate screws: step 9, image 2 of 2
      Tool used on this step:
      FixMat
      $31.41
      Buy
      • While the Mac mini uses Torx Plus screws, standard Torx bits work. Make sure to apply constant, downward force to prevent stripping.
      • Use a T5 Torx screwdriver to remove the twelve screws securing the inner plate:
      • Eight 3.4 mm‑long screws
      • Four 2.4 mm‑long screws
      Ask FixBot
    2. Mac mini (2024) Fan Replacement, Separate the inner plate: step 10, image 1 of 3 Mac mini (2024) Fan Replacement, Separate the inner plate: step 10, image 2 of 3 Mac mini (2024) Fan Replacement, Separate the inner plate: step 10, image 3 of 3
      • Insert the point of a spudger into one of the clips' slots on the inner plate.
      • Pry up the inner plate enough so you can grip the edge along the same side as the headphone jack.
      Ask FixBot
    3. Mac mini (2024) Fan Replacement: step 11, image 1 of 2 Mac mini (2024) Fan Replacement: step 11, image 2 of 2
      • Pull the inner plate away from the chassis to slide it out from under the lip on the heat sink.
      • During reassembly, slide the inner plate back under the heat sink and press along its edges to secure it in the chassis.
      Ask FixBot
    4. Mac mini (2024) Fan Replacement: step 12, image 1 of 3 Mac mini (2024) Fan Replacement: step 12, image 2 of 3 Mac mini (2024) Fan Replacement: step 12, image 3 of 3
      • Don't remove the inner plate yet, as it's still connected to the Mac mini by a cable.
      • Lift the inner plate and flip it over to expose the wireless module cable.
      Ask FixBot
    5. Mac mini (2024) Fan Replacement, Remove the wireless module cover: step 13, image 1 of 3 Mac mini (2024) Fan Replacement, Remove the wireless module cover: step 13, image 2 of 3 Mac mini (2024) Fan Replacement, Remove the wireless module cover: step 13, image 3 of 3
      • Use one hand to secure the wireless module during this step.
      • Use a Torx Plus 5IP screwdriver to remove the four 2.5 mm‑long screws securing the wireless module cover.
      Ask FixBot
    6. Mac mini (2024) Fan Replacement, Remove the cover: step 14, image 1 of 2 Mac mini (2024) Fan Replacement, Remove the cover: step 14, image 2 of 2
      • Remove the wireless module cover.
      • During reassembly, look the bottom of the cover to find the foam rectangle. Align the foam rectangle over the wireless module press connector to find the proper orientation for the cover.
      Ask FixBot
    7. Mac mini (2024) Fan Replacement, Disconnect the wireless module: step 15, image 1 of 2 Mac mini (2024) Fan Replacement, Disconnect the wireless module: step 15, image 2 of 2
      • Insert the point of a spudger under one of the short edges of the wireless module press connector.
      • Don't insert your spudger anywhere else, as you risk dislodging surface-mounted components.
      • Pry up to disconnect the wireless module.
      Ask FixBot
    8. Mac mini (2024) Fan Replacement, Remove the inner plate: step 16, image 1 of 1
      • Remove the inner plate.
      Ask FixBot
    1. Mac mini (2024) Fan Replacement, Remove the fan screws: step 17, image 1 of 2 Mac mini (2024) Fan Replacement, Remove the fan screws: step 17, image 2 of 2
      • If you're following this guide to clean your fan, this is a good time to do so.
      • Remove the four screws securing the fan:
      • Two 2.4 mm‑long Torx Plus 3IP screws
      • Two 7.9 mm‑long Torx Plus 5IP screws
      Ask FixBot
    2. Mac mini (2024) Fan Replacement, Reposition the fan: step 18, image 1 of 3 Mac mini (2024) Fan Replacement, Reposition the fan: step 18, image 2 of 3 Mac mini (2024) Fan Replacement, Reposition the fan: step 18, image 3 of 3
      • Lift the fan out of its recess in the chassis and flip it over to expose its wire and connector.
      • Let the fan rest on the chassis and heat sink.
      Ask FixBot
    3. Mac mini (2024) Fan Replacement, Disconnect the fan: step 19, image 1 of 3 Mac mini (2024) Fan Replacement, Disconnect the fan: step 19, image 2 of 3 Mac mini (2024) Fan Replacement, Disconnect the fan: step 19, image 3 of 3
      • Use tweezers to peel back the tape covering the fan ZIF connector.
      Ask FixBot
    4. Mac mini (2024) Fan Replacement: step 20, image 1 of 2 Mac mini (2024) Fan Replacement: step 20, image 2 of 2
      • Use the point of a spudger, or your fingernail, to flip up the locking tab on the fan ZIF connector.
      Ask FixBot
    5. Mac mini (2024) Fan Replacement: step 21, image 1 of 2 Mac mini (2024) Fan Replacement: step 21, image 2 of 2
      • Use tweezers, or your fingers, to slide the ZIF connector straight out of its socket.
      Ask FixBot
    6. Mac mini (2024) Fan Replacement, Remove the fan: step 22, image 1 of 1
      • Remove the fan.
      Ask FixBot
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Mac mini (2024) Answers Community for help.
2 other people completed this guide.
Alex Diaz-Kokaisl
253,191 Reputation
1,200 Guides authored
Guide Team Member of Guide Team
Staff
10 Members
62,189 Guides authored
0 Guide Comments
Past 24 Hours: 26
Past 7 Days: 167
Past 30 Days: 820
All Time: 12,312
