Mac Studio 2023 Power Cord Port Replacement
    1. Mac Studio 2023 Power Cord Port Replacement, Prepare your Mac Studio for disassembly: step 1, image 1 of 3 Mac Studio 2023 Power Cord Port Replacement, Prepare your Mac Studio for disassembly: step 1, image 2 of 3 Mac Studio 2023 Power Cord Port Replacement, Prepare your Mac Studio for disassembly: step 1, image 3 of 3
      • Completely shut down your Mac Studio.
      • Unplug all cables from your device.
      Ask FixBot
    1. Mac Studio 2023 Power Cord Port Replacement, Flip your Mac Studio over: step 2, image 1 of 1
      • Flip your Mac Studio over and lay it down so the bottom faces up and the SD card slot and two front USB‑C ports are facing you.
      Ask FixBot
    2. Mac Studio 2023 Power Cord Port Replacement, Heat the bottom cover screw pad: step 3, image 1 of 3 Mac Studio 2023 Power Cord Port Replacement, Heat the bottom cover screw pad: step 3, image 2 of 3 Mac Studio 2023 Power Cord Port Replacement, Heat the bottom cover screw pad: step 3, image 3 of 3
      • Adhesive strips secure the bottom cover screw pad.
      • Heat an iOpener and lay it over one of the bottom cover screws for two minutes to soften the adhesive near the screw—this is where you'll insert a spudger in the next step.
      • You can also use a hair dryer or heat gun, but be careful as extreme heat will warp the pad.
      Ask FixBot
    3. Mac Studio 2023 Power Cord Port Replacement, Lift a section of bottom cover screw pad: step 4, image 1 of 3 Mac Studio 2023 Power Cord Port Replacement, Lift a section of bottom cover screw pad: step 4, image 2 of 3 Mac Studio 2023 Power Cord Port Replacement, Lift a section of bottom cover screw pad: step 4, image 3 of 3
      • Insert the point of a spudger under the pad's inner edge, near the screw you applied heat to in the previous step.
      • This may take some force. If you're having trouble, apply more heat and try again.
      • Use the spudger to lift the pad and separate the adhesive.
      Ask FixBot
    4. Mac Studio 2023 Power Cord Port Replacement, Separate the remaining adhesive: step 5, image 1 of 3 Mac Studio 2023 Power Cord Port Replacement, Separate the remaining adhesive: step 5, image 2 of 3 Mac Studio 2023 Power Cord Port Replacement, Separate the remaining adhesive: step 5, image 3 of 3
      • Insert the flat end of a spudger under the pad.
      • Slide the spudger under the entire pad to separate the remaining adhesive.
      Ask FixBot
    5. Mac Studio 2023 Power Cord Port Replacement, Remove the bottom cover screw pad: step 6, image 1 of 1
      • Remove the bottom cover screw pad.
      Ask FixBot
    6. Mac Studio 2023 Power Cord Port Replacement, Reassembly information: step 7, image 1 of 3 Mac Studio 2023 Power Cord Port Replacement, Reassembly information: step 7, image 2 of 3 Mac Studio 2023 Power Cord Port Replacement, Reassembly information: step 7, image 3 of 3
      Tool used on this step:
      Tesa 61395 Tape
      $2.95
      Buy
      • During reassembly:
      • If the adhesive strips are still sticky, you can reuse them.
      • If you're applying new adhesive:
      • Use the flat end of a spudger and your fingers to scrape up and remove the old adhesive strips.
      • Use isopropyl alcohol and a microfiber cloth to remove the old adhesive residue.
      • If you don't have replacement adhesive, you can use strips of thin, double-sided tape 2–3 mm wide.
      • Apply the new adhesive strips to the bottom cover and remove their liners.
      • Firmly press the bottom cover screw pad into its recess to secure it.
      Ask FixBot
    1. Mac Studio 2023 Power Cord Port Replacement, Remove the bottom cover screws: step 8, image 1 of 2 Mac Studio 2023 Power Cord Port Replacement, Remove the bottom cover screws: step 8, image 2 of 2
      FixMat
      $36.95
      Buy
      • While the Mac Studio uses Torx Plus screws, standard Torx bits work. Make sure to apply constant, downward force to prevent stripping.
      • Use a T10 Torx screwdriver to remove the four 8 mm‑long screws securing the bottom cover.
      • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came.
      Ask FixBot
    2. Mac Studio 2023 Power Cord Port Replacement, Remove the bottom cover: step 9, image 1 of 3 Mac Studio 2023 Power Cord Port Replacement, Remove the bottom cover: step 9, image 2 of 3 Mac Studio 2023 Power Cord Port Replacement, Remove the bottom cover: step 9, image 3 of 3
      • Insert the point of a spudger in one of the bottom cover's ventilation holes and lift the cover until you can grab it with your fingers.
      • Remove the bottom cover.
      • To orient the bottom cover, align the Kensington lock cutout in the top left corner with the corresponding one on the internal frame.
      Ask FixBot
    1. Mac Studio 2023 Power Cord Port Replacement, Remove the power supply screws: step 10, image 1 of 2 Mac Studio 2023 Power Cord Port Replacement, Remove the power supply screws: step 10, image 2 of 2
      • Use a T10 Torx screwdriver to remove the six screws securing the power supply:
      • Four 6 mm‑long screws
      • Two 7 mm‑long screws with washers
      • You may need to remove a sticker to access these screws. If you do, save it for reassembly.
      Ask FixBot
    2. Mac Studio 2023 Power Cord Port Replacement, Reposition your Mac Studio: step 11, image 1 of 1
      • Flip your Mac Studio around so the rear ports are facing you.
      Ask FixBot
    3. Mac Studio 2023 Power Cord Port Replacement, Disconnect the power cord port cable: step 12, image 1 of 3 Mac Studio 2023 Power Cord Port Replacement, Disconnect the power cord port cable: step 12, image 2 of 3 Mac Studio 2023 Power Cord Port Replacement, Disconnect the power cord port cable: step 12, image 3 of 3
      • A tight plastic latch secures the power cord port cable.
      • Firmly hold the power supply with one hand and lift up the edge near the power cord port.
      • With your free hand, pinch the head of the power cord port connector to unclip it and pull straight down to disconnect the cable.
      Ask FixBot
    4. Mac Studio 2023 Power Cord Port Replacement, Tilt up the power supply: step 13, image 1 of 1
      • Only grab the power supply by its edges. Various power components and capacitors are left exposed.
      • Carefully tilt the power supply away from the power cord port so it's at a 90-degree angle.
      • Be careful not to strain the cable that's still connected to the power supply.
      • Keep the power supply tilted up for the next step.
      Ask FixBot
    5. Mac Studio 2023 Power Cord Port Replacement, Disconnect the power supply signal cable: step 14, image 1 of 3 Mac Studio 2023 Power Cord Port Replacement, Disconnect the power supply signal cable: step 14, image 2 of 3 Mac Studio 2023 Power Cord Port Replacement, Disconnect the power supply signal cable: step 14, image 3 of 3
      • A delicate plastic clip secures the power supply signal cable.
      • With your free hand, pinch the head of the power supply connector to unclip it and pull straight away from the socket to disconnect the cable.
      Ask FixBot
    6. Mac Studio 2023 Power Cord Port Replacement, Remove the power supply: step 15, image 1 of 1
      • Remove the power supply.
      Ask FixBot
    1. Mac Studio 2023 Power Cord Port Replacement, Reposition your Mac Studio: step 16, image 1 of 1
      • Flip your Mac Studio around so the SD card reader and two front USB‑C ports are facing you.
      Ask FixBot
    2. Mac Studio 2023 Power Cord Port Replacement, Remove the internal frame screws: step 17, image 1 of 2 Mac Studio 2023 Power Cord Port Replacement, Remove the internal frame screws: step 17, image 2 of 2
      • Use a T6 Torx screwdriver to remove the eight screws securing the internal frame:
      • Seven 5 mm‑long screws
      • One 4 mm‑long screw
      Ask FixBot
    3. Mac Studio 2023 Power Cord Port Replacement, Remove the internal frame: step 18, image 1 of 2 Mac Studio 2023 Power Cord Port Replacement, Remove the internal frame: step 18, image 2 of 2
      Ask FixBot
    1. Mac Studio 2023 Power Cord Port Replacement, Remove the ethernet board cable cover: step 19, image 1 of 3 Mac Studio 2023 Power Cord Port Replacement, Remove the ethernet board cable cover: step 19, image 2 of 3 Mac Studio 2023 Power Cord Port Replacement, Remove the ethernet board cable cover: step 19, image 3 of 3
      • Use a T3 Torx screwdriver to remove the two 2 mm‑long screws securing the ethernet board cable cover.
      • Use tweezers or your fingers to remove the cover.
      Ask FixBot
    2. Mac Studio 2023 Power Cord Port Replacement, Disconnect the ethernet board: step 20, image 1 of 2 Mac Studio 2023 Power Cord Port Replacement, Disconnect the ethernet board: step 20, image 2 of 2
      • Be very careful not to scrape off or damage any surface mounted components during this step.
      • Use a spudger to pry up and disconnect the ethernet board cable press connector from the logic board.
      • To reconnect press connectors, carefully align and press down on one side until it clicks into place, then repeat on the other side. Don't press down in the middle. If the connector is misaligned, the pins can bend and cause permanent damage.
      Ask FixBot
    3. Mac Studio 2023 Power Cord Port Replacement, Reposition your Mac Studio: step 21, image 1 of 1
      • Carefully stand up your Mac Studio so the SD card reader and two front USB-C ports are facing up.
      Ask FixBot
    4. Mac Studio 2023 Power Cord Port Replacement, Remove the ethernet board cable: step 22, image 1 of 3 Mac Studio 2023 Power Cord Port Replacement, Remove the ethernet board cable: step 22, image 2 of 3 Mac Studio 2023 Power Cord Port Replacement, Remove the ethernet board cable: step 22, image 3 of 3
      Flexible Extension
      $6.99
      Buy
      • Use a T4 Torx screwdriver to remove the two 11 mm‑long screws securing the right side of the ethernet board and its cover.
      • These screws may be hard to access. If you can't insert your screwdriver properly, use a flexible extension to avoid stripping screws or damaging the logic board.
      Ask FixBot
    5. Mac Studio 2023 Power Cord Port Replacement: step 23, image 1 of 3 Mac Studio 2023 Power Cord Port Replacement: step 23, image 2 of 3 Mac Studio 2023 Power Cord Port Replacement: step 23, image 3 of 3
      • Insert the point of a spudger under the bottom right corner of the ethernet board press connector and lift up to disconnect it.
      • Don't pry against any surface mounted components.
      • Remove the cable.
      Ask FixBot
    6. Mac Studio 2023 Power Cord Port Replacement, Remove the ethernet board screws: step 24, image 1 of 2 Mac Studio 2023 Power Cord Port Replacement, Remove the ethernet board screws: step 24, image 2 of 2
      Flexible Extension
      $6.99
      Buy
      • Use a T6 Torx screwdriver to remove the two 20 mm‑long screws (with washers) securing the ethernet board.
      • Be careful not to lose the washers, as they can fall off easily.
      Ask FixBot
    7. Mac Studio 2023 Power Cord Port Replacement, Remove the ethernet board: step 25, image 1 of 2 Mac Studio 2023 Power Cord Port Replacement, Remove the ethernet board: step 25, image 2 of 2
      • Lift the ethernet board out of its recess and remove it.
      Ask FixBot
    1. Mac Studio 2023 Power Cord Port Replacement, Reposition your Mac Studio: step 26, image 1 of 1
      • Reposition your Mac Studio so the SD card reader and two front USB‑C ports are facing you.
      Ask FixBot
    1. Mac Studio 2023 Power Cord Port Replacement, Remove the speaker screws: step 27, image 1 of 3 Mac Studio 2023 Power Cord Port Replacement, Remove the speaker screws: step 27, image 2 of 3 Mac Studio 2023 Power Cord Port Replacement, Remove the speaker screws: step 27, image 3 of 3
      • Use a T5 Torx screwdriver to remove the two 12 mm‑long screws securing the speaker.
      Ask FixBot
    2. Mac Studio 2023 Power Cord Port Replacement, Reposition the speaker: step 28, image 1 of 3 Mac Studio 2023 Power Cord Port Replacement, Reposition the speaker: step 28, image 2 of 3 Mac Studio 2023 Power Cord Port Replacement, Reposition the speaker: step 28, image 3 of 3
      Ask FixBot
    3. Mac Studio 2023 Power Cord Port Replacement, Disconnect the speaker: step 29, image 1 of 2 Mac Studio 2023 Power Cord Port Replacement, Disconnect the speaker: step 29, image 2 of 2
      • Insert the point of a spudger under the speaker connector's plastic head and carefully lift it straight up and out of its socket.
      • Don't lift on the wires themselves, or you may damage them.
      • To reconnect the cable, position the connector head over its socket and press to with the flat end of a spudger—the connector should click into place.
      Ask FixBot
    4. Mac Studio 2023 Power Cord Port Replacement, Remove the speaker: step 30, image 1 of 1
      • Remove the speaker.
      Ask FixBot
    1. Mac Studio 2023 Power Cord Port Replacement, Remove the cable cover screws: step 31, image 1 of 2 Mac Studio 2023 Power Cord Port Replacement, Remove the cable cover screws: step 31, image 2 of 2
      • Use a T3 Torx screwdriver to remove the two 2 mm‑long screws securing the I/O board cable cover.
      • Use a T8 Torx screwdriver to remove the standoff screw just to the right of the cover.
      Ask FixBot
    2. Mac Studio 2023 Power Cord Port Replacement, Remove the cover: step 32, image 1 of 1
      • Use tweezers or your fingers to remove the I/O board cable cover.
      Ask FixBot
    3. Mac Studio 2023 Power Cord Port Replacement, Disconnect the I/O board: step 33, image 1 of 3 Mac Studio 2023 Power Cord Port Replacement, Disconnect the I/O board: step 33, image 2 of 3 Mac Studio 2023 Power Cord Port Replacement, Disconnect the I/O board: step 33, image 3 of 3
      • Use a spudger to pry up and disconnect both of the I/O board's press connectors.
      Ask FixBot
    4. Mac Studio 2023 Power Cord Port Replacement, Disconnect the power button: step 34, image 1 of 3 Mac Studio 2023 Power Cord Port Replacement, Disconnect the power button: step 34, image 2 of 3 Mac Studio 2023 Power Cord Port Replacement, Disconnect the power button: step 34, image 3 of 3
      • Use the point of a spudger or a clean fingernail to flip up the hinged locking flap on the power button cable ZIF connector, located on the outer edge of the I/O board.
      • Use tweezers to gently pull the cable straight out of its socket.
      Ask FixBot
    5. Mac Studio 2023 Power Cord Port Replacement, Reposition your Mac Studio: step 35, image 1 of 1
      Ask FixBot
    6. Mac Studio 2023 Power Cord Port Replacement, Remove the I/O board screws: step 36, image 1 of 3 Mac Studio 2023 Power Cord Port Replacement, Remove the I/O board screws: step 36, image 2 of 3 Mac Studio 2023 Power Cord Port Replacement, Remove the I/O board screws: step 36, image 3 of 3
      Flexible Extension
      $6.99
      Buy
      • Use a T4 Torx screwdriver to remove the two 15.5 mm‑long screws securing the outer edge of the I/O board.
      • Use a T6 Torx screwdriver to remove the two 20 mm‑long screws securing the inner edge of the I/O board.
      • Partially tighten the four screws securing the board.
      • Lay your Mac Studio down and plug a cable into one of the ports to ensure proper fit and alignment, adjusting the port as necessary—the cable should be easy to insert and remove.
      • With the cable plugged in and the board in position, fully tighten all four screws.
      • Unplug all cables before continuing.
      Ask FixBot
    7. Mac Studio 2023 Power Cord Port Replacement, Remove the I/O board: step 37, image 1 of 3 Mac Studio 2023 Power Cord Port Replacement, Remove the I/O board: step 37, image 2 of 3 Mac Studio 2023 Power Cord Port Replacement, Remove the I/O board: step 37, image 3 of 3
      • Lift the I/O board straight up and out of its recess to remove it.
      • During reassembly, lower the board into its recess, making sure the press connectors don't get trapped under the logic board.
      Ask FixBot
    1. Mac Studio 2023 Power Cord Port Replacement, Remove the power cord port: step 38, image 1 of 2 Mac Studio 2023 Power Cord Port Replacement, Remove the power cord port: step 38, image 2 of 2
      • Lift the power cord port out of its recess and remove it.
      Ask FixBot
Spencer Day
205,151 Reputation
1,266 Guides authored
iFixit Member of iFixit
Staff
122 Members
86,625 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 11
Past 30 Days: 44
All Time: 607
