Mac Studio 2023 Antenna 3 Replacement
    1. Mac Studio 2023 Antenna 3 Replacement, Prepare your Mac Studio for disassembly: step 1, image 1 of 3 Mac Studio 2023 Antenna 3 Replacement, Prepare your Mac Studio for disassembly: step 1, image 2 of 3 Mac Studio 2023 Antenna 3 Replacement, Prepare your Mac Studio for disassembly: step 1, image 3 of 3
      • Completely shut down your Mac Studio.
      • Unplug all cables from your device.
      Ask FixBot
    1. Mac Studio 2023 Antenna 3 Replacement, Flip your Mac Studio over: step 2, image 1 of 1
      • Flip your Mac Studio over and lay it down so the bottom faces up and the SD card slot and two front USB‑C ports are facing you.
      Ask FixBot
    2. Mac Studio 2023 Antenna 3 Replacement, Heat the bottom cover screw pad: step 3, image 1 of 3 Mac Studio 2023 Antenna 3 Replacement, Heat the bottom cover screw pad: step 3, image 2 of 3 Mac Studio 2023 Antenna 3 Replacement, Heat the bottom cover screw pad: step 3, image 3 of 3
      • Adhesive strips secure the bottom cover screw pad.
      • Heat an iOpener and lay it over one of the bottom cover screws for two minutes to soften the adhesive near the screw—this is where you'll insert a spudger in the next step.
      • You can also use a hair dryer or heat gun, but be careful as extreme heat will warp the pad.
      Ask FixBot
    3. Mac Studio 2023 Antenna 3 Replacement, Lift a section of bottom cover screw pad: step 4, image 1 of 3 Mac Studio 2023 Antenna 3 Replacement, Lift a section of bottom cover screw pad: step 4, image 2 of 3 Mac Studio 2023 Antenna 3 Replacement, Lift a section of bottom cover screw pad: step 4, image 3 of 3
      • Insert the point of a spudger under the pad's inner edge, near the screw you applied heat to in the previous step.
      • This may take some force. If you're having trouble, apply more heat and try again.
      • Use the spudger to lift the pad and separate the adhesive.
      Ask FixBot
    4. Mac Studio 2023 Antenna 3 Replacement, Separate the remaining adhesive: step 5, image 1 of 3 Mac Studio 2023 Antenna 3 Replacement, Separate the remaining adhesive: step 5, image 2 of 3 Mac Studio 2023 Antenna 3 Replacement, Separate the remaining adhesive: step 5, image 3 of 3
      • Insert the flat end of a spudger under the pad.
      • Slide the spudger under the entire pad to separate the remaining adhesive.
      Ask FixBot
    5. Mac Studio 2023 Antenna 3 Replacement, Remove the bottom cover screw pad: step 6, image 1 of 1
      • Remove the bottom cover screw pad.
      Ask FixBot
    6. Mac Studio 2023 Antenna 3 Replacement, Reassembly information: step 7, image 1 of 3 Mac Studio 2023 Antenna 3 Replacement, Reassembly information: step 7, image 2 of 3 Mac Studio 2023 Antenna 3 Replacement, Reassembly information: step 7, image 3 of 3
      Tool used on this step:
      Tesa 61395 Tape
      $2.95
      Buy
      • During reassembly:
      • If the adhesive strips are still sticky, you can reuse them.
      • If you're applying new adhesive:
      • Use the flat end of a spudger and your fingers to scrape up and remove the old adhesive strips.
      • Use isopropyl alcohol and a microfiber cloth to remove the old adhesive residue.
      • If you don't have replacement adhesive, you can use strips of thin, double-sided tape 2–3 mm wide.
      • Apply the new adhesive strips to the bottom cover and remove their liners.
      • Firmly press the bottom cover screw pad into its recess to secure it.
      Ask FixBot
    1. Mac Studio 2023 Antenna 3 Replacement, Remove the bottom cover screws: step 8, image 1 of 2 Mac Studio 2023 Antenna 3 Replacement, Remove the bottom cover screws: step 8, image 2 of 2
      FixMat
      $36.95
      Buy
      • While the Mac Studio uses Torx Plus screws, standard Torx bits work. Make sure to apply constant, downward force to prevent stripping.
      • Use a T10 Torx screwdriver to remove the four 8 mm‑long screws securing the bottom cover.
      • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came.
      Ask FixBot
    2. Mac Studio 2023 Antenna 3 Replacement, Remove the bottom cover: step 9, image 1 of 3 Mac Studio 2023 Antenna 3 Replacement, Remove the bottom cover: step 9, image 2 of 3 Mac Studio 2023 Antenna 3 Replacement, Remove the bottom cover: step 9, image 3 of 3
      • Insert the point of a spudger in one of the bottom cover's ventilation holes and lift the cover until you can grab it with your fingers.
      • Remove the bottom cover.
      • To orient the bottom cover, align the Kensington lock cutout in the top left corner with the corresponding one on the internal frame.
      Ask FixBot
    1. Mac Studio 2023 Antenna 3 Replacement, Remove the power supply screws: step 10, image 1 of 2 Mac Studio 2023 Antenna 3 Replacement, Remove the power supply screws: step 10, image 2 of 2
      • Use a T10 Torx screwdriver to remove the six screws securing the power supply:
      • Four 6 mm‑long screws
      • Two 7 mm‑long screws with washers
      • You may need to remove a sticker to access these screws. If you do, save it for reassembly.
      Ask FixBot
    2. Mac Studio 2023 Antenna 3 Replacement, Reposition your Mac Studio: step 11, image 1 of 1
      • Flip your Mac Studio around so the rear ports are facing you.
      Ask FixBot
    3. Mac Studio 2023 Antenna 3 Replacement, Disconnect the power cord port cable: step 12, image 1 of 3 Mac Studio 2023 Antenna 3 Replacement, Disconnect the power cord port cable: step 12, image 2 of 3 Mac Studio 2023 Antenna 3 Replacement, Disconnect the power cord port cable: step 12, image 3 of 3
      • A tight plastic latch secures the power cord port cable.
      • Firmly hold the power supply with one hand and lift up the edge near the power cord port.
      • With your free hand, pinch the head of the power cord port connector to unclip it and pull straight down to disconnect the cable.
      Ask FixBot
    4. Mac Studio 2023 Antenna 3 Replacement, Tilt up the power supply: step 13, image 1 of 1
      • Only grab the power supply by its edges. Various power components and capacitors are left exposed.
      • Carefully tilt the power supply away from the power cord port so it's at a 90-degree angle.
      • Be careful not to strain the cable that's still connected to the power supply.
      • Keep the power supply tilted up for the next step.
      Ask FixBot
    5. Mac Studio 2023 Antenna 3 Replacement, Disconnect the power supply signal cable: step 14, image 1 of 3 Mac Studio 2023 Antenna 3 Replacement, Disconnect the power supply signal cable: step 14, image 2 of 3 Mac Studio 2023 Antenna 3 Replacement, Disconnect the power supply signal cable: step 14, image 3 of 3
      • A delicate plastic clip secures the power supply signal cable.
      • With your free hand, pinch the head of the power supply connector to unclip it and pull straight away from the socket to disconnect the cable.
      Ask FixBot
    6. Mac Studio 2023 Antenna 3 Replacement, Remove the power supply: step 15, image 1 of 1
      • Remove the power supply.
      Ask FixBot
    1. Mac Studio 2023 Antenna 3 Replacement, Reposition your Mac Studio: step 16, image 1 of 1
      • Flip your Mac Studio around so the SD card reader and two front USB‑C ports are facing you.
      Ask FixBot
    2. Mac Studio 2023 Antenna 3 Replacement, Remove the internal frame screws: step 17, image 1 of 2 Mac Studio 2023 Antenna 3 Replacement, Remove the internal frame screws: step 17, image 2 of 2
      • Use a T6 Torx screwdriver to remove the eight screws securing the internal frame:
      • Seven 5 mm‑long screws
      • One 4 mm‑long screw
      Ask FixBot
    3. Mac Studio 2023 Antenna 3 Replacement, Remove the internal frame: step 18, image 1 of 2 Mac Studio 2023 Antenna 3 Replacement, Remove the internal frame: step 18, image 2 of 2
      Ask FixBot
    1. Mac Studio 2023 Antenna 3 Replacement, Remove the antenna cable cover: step 19, image 1 of 3 Mac Studio 2023 Antenna 3 Replacement, Remove the antenna cable cover: step 19, image 2 of 3 Mac Studio 2023 Antenna 3 Replacement, Remove the antenna cable cover: step 19, image 3 of 3
      • Use a T3 Torx screwdriver to remove the two 2 mm‑long screws securing the antenna cable cover.
      • Use tweezers or your fingers to remove the cover.
      Ask FixBot
    1. Mac Studio 2023 Antenna 3 Replacement, Disconnect antenna 3: step 20, image 1 of 3 Mac Studio 2023 Antenna 3 Replacement, Disconnect antenna 3: step 20, image 2 of 3 Mac Studio 2023 Antenna 3 Replacement, Disconnect antenna 3: step 20, image 3 of 3
      • Insert one arm of a pair of angled tweezers under the metal neck of antenna 3's coaxial connector (next to antenna 2's connector) and lift straight up to disconnect it.
      • To reconnect the cable, hold the connector in place over its socket and press down with the flat end of a spudger—the connector should snap into place. If you're having trouble, don't try to force the connector over the socket. Reposition it and try again.
      Ask FixBot
    2. Mac Studio 2023 Antenna 3 Replacement, Unclip the cable: step 21, image 1 of 3 Mac Studio 2023 Antenna 3 Replacement, Unclip the cable: step 21, image 2 of 3 Mac Studio 2023 Antenna 3 Replacement, Unclip the cable: step 21, image 3 of 3
      Ask FixBot
    3. Mac Studio 2023 Antenna 3 Replacement, Remove antenna 3's screws: step 22, image 1 of 2 Mac Studio 2023 Antenna 3 Replacement, Remove antenna 3's screws: step 22, image 2 of 2
      • Use a T5 Torx screwdriver to remove the two 3.5 mm‑long screws securing antenna 3.
      Ask FixBot
    4. Mac Studio 2023 Antenna 3 Replacement, Remove antenna 3: step 23, image 1 of 2 Mac Studio 2023 Antenna 3 Replacement, Remove antenna 3: step 23, image 2 of 2
      • Remove antenna 3.
      Ask FixBot
Spencer Day
201,579 Reputation
1,244 Guides authored
iFixit Member of iFixit
Staff
123 Members
86,246 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 19
All Time: 391
