Up to 20% off select tools
Mac Pro Late 2013 SSD Replacement
Views: 100K
View statistics:
Past 24 Hours:
13
Past 7 Days:
86
Past 30 Days:
412
All Time:
100,132
Comments: 9
9 guide comments.
Go to guide comments
Completed: 44
44 people have marked this guide "completed." Will you be next?
Favorites: 10
10 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 5 minutes
Difficulty: Easy
Parts
Tools
Introduction
Go to step 1 ↓
Use this guide to replace the SSD in your Mac Pro.
    1. Mac Pro Late 2013 SSD Replacement, Outer Case: step 1, image 1 of 2 Mac Pro Late 2013 SSD Replacement, Outer Case: step 1, image 2 of 2
      • Slide the lock switch to the right, to the unlocked position.
      Ask FixBot
    2. Mac Pro Late 2013 SSD Replacement: step 2, image 1 of 3 Mac Pro Late 2013 SSD Replacement: step 2, image 2 of 3 Mac Pro Late 2013 SSD Replacement: step 2, image 3 of 3
      • Lift the outer case straight up off the Mac Pro.
      • It may help to push down on the center of the fan while lifting the case up.
      Ask FixBot
    1. Mac Pro Late 2013 SSD Replacement, SSD: step 3, image 1 of 1
      • Remove the single 6.5 mm T8 Torx screw.
      Ask FixBot
    2. Mac Pro Late 2013 SSD Replacement: step 4, image 1 of 3 Mac Pro Late 2013 SSD Replacement: step 4, image 2 of 3 Mac Pro Late 2013 SSD Replacement: step 4, image 3 of 3
      • Pull the SSD slightly away from the graphics card.
      • Do not pull the top edge of the SSD more than 1/2" away from the graphics card, or you will risk damaging it.
      • Lift the SSD straight up out of its slot on the graphics card.
      Ask FixBot
44 other people completed this guide.
Author
with
Andrew Optimus Goldheart
516,617 Reputation
405 Guides authored
iFixit Member of iFixit
Staff
119 Members
72,966 Guides authored
9 Guide Comments
Will a 970 evo 512 gb pcie m2 fit on here?
Sam Yao - Reply Share
As long as the drive is not the Plus version, you may be able to use an adapter in order to use that SSD in your MacPro6,1:
https://www.amazon.com/Sintech-Adapter-U...
I have not tried this, but am, currently, researching a fix for a machine in my care.
Robert Maxwell - Reply Share
Yes—works very well with the Sintech adaptor (and even with an EK-M.2 NVMe Heatsink — use thermal paste for longevity!).
Just did this yesterday and it’s a great/fast/easy upgrade.
ericbalog - Reply Share
Do you need a heat sink in the SSD?
Cesar Cuenca - Reply Share
The stock (Samsung) drive(s) that shipped (from Apple) with these machines do not; unless the black, outer covering helps with heat. [???]
I have had both a Samsung MZ-JPU256T/0A1 (256GB) and Samsung MZ-KPU1T0T/0A1 (1TB) installed in my machine without issue.
Third-party drives may include or heatsink and/or require at least 10.13 (High Sierra).
Past 24 Hours: 13
Past 7 Days: 86
Past 30 Days: 412
All Time: 100,132
