Mac Pro Late 2013 AirPort Antenna Array Replacement
    1. Mac Pro Late 2013 AirPort Antenna Array Replacement, Outer Case: step 1, image 1 of 2 Mac Pro Late 2013 AirPort Antenna Array Replacement, Outer Case: step 1, image 2 of 2
      • Slide the lock switch to the right, to the unlocked position.
      Ask FixBot
    2. Mac Pro Late 2013 AirPort Antenna Array Replacement: step 2, image 1 of 3 Mac Pro Late 2013 AirPort Antenna Array Replacement: step 2, image 2 of 3 Mac Pro Late 2013 AirPort Antenna Array Replacement: step 2, image 3 of 3
      • Lift the outer case straight up off the Mac Pro.
      • It may help to push down on the center of the fan while lifting the case up.
      Ask FixBot
    1. Mac Pro Late 2013 AirPort Antenna Array Replacement, Fan Assembly: step 3, image 1 of 3 Mac Pro Late 2013 AirPort Antenna Array Replacement, Fan Assembly: step 3, image 2 of 3 Mac Pro Late 2013 AirPort Antenna Array Replacement, Fan Assembly: step 3, image 3 of 3
      • Remove five 5.1 mm T10 Torx screws from around the outer perimeter of the fan assembly.
      Ask FixBot
    2. Mac Pro Late 2013 AirPort Antenna Array Replacement: step 4, image 1 of 2 Mac Pro Late 2013 AirPort Antenna Array Replacement: step 4, image 2 of 2
      • The fan assembly is attached to the rest of the computer by two cables on the IO board side.
      • Tilt the assembly up away from the IO board.
      • Do not try to remove the fan assembly yet, as it is still attached by two cables.
      Ask FixBot
    3. Mac Pro Late 2013 AirPort Antenna Array Replacement: step 5, image 1 of 1
      • While supporting the fan assembly with one hand, loosen the two T8 captive screws in the fan cable bracket.
      • These screws are captive in the Mac Pro. Do not try to remove these screws from your Mac Pro.
      Ask FixBot
    4. Mac Pro Late 2013 AirPort Antenna Array Replacement: step 6, image 1 of 1
      Tool used on this step:
      Buy
      • Use a pair of tweezers to pull the fan cable bracket away from the fan assembly.
      Ask FixBot
    5. Mac Pro Late 2013 AirPort Antenna Array Replacement: step 7, image 1 of 2 Mac Pro Late 2013 AirPort Antenna Array Replacement: step 7, image 2 of 2
      • Use the flat end of a spudger to disconnect the fan assembly ribbon cable from the IO board.
      Ask FixBot
    6. Mac Pro Late 2013 AirPort Antenna Array Replacement: step 8, image 1 of 1
      • Disconnect the fan assembly antenna cable from the IO board.
      • Remove the fan assembly from the Mac Pro.
      Ask FixBot
    1. Mac Pro Late 2013 AirPort Antenna Array Replacement, Fan Assembly Lid: step 9, image 1 of 3 Mac Pro Late 2013 AirPort Antenna Array Replacement, Fan Assembly Lid: step 9, image 2 of 3 Mac Pro Late 2013 AirPort Antenna Array Replacement, Fan Assembly Lid: step 9, image 3 of 3
      • Use the flat end of a spudger to pry the fan assembly lid up off the fan assembly.
      • Remove the fan assembly lid.
      Ask FixBot
    1. Mac Pro Late 2013 AirPort Antenna Array Replacement, AirPort Board: step 10, image 1 of 1
      • Remove the three 3.7 mm T4 screws securing the metal cover to the AirPort board bay.
      Ask FixBot
    2. Mac Pro Late 2013 AirPort Antenna Array Replacement: step 11, image 1 of 1
      • Lift and remove the metal cover from the AirPort board bay.
      Ask FixBot
    3. Mac Pro Late 2013 AirPort Antenna Array Replacement: step 12, image 1 of 3 Mac Pro Late 2013 AirPort Antenna Array Replacement: step 12, image 2 of 3 Mac Pro Late 2013 AirPort Antenna Array Replacement: step 12, image 3 of 3
      • Use the tip of a spudger to flip the ZIF retaining tab on the fan assembly ribbon cable connector.
      • Remove the fan assembly ribbon cable from its ZIF socket.
      Ask FixBot
    4. Mac Pro Late 2013 AirPort Antenna Array Replacement: step 13, image 1 of 3 Mac Pro Late 2013 AirPort Antenna Array Replacement: step 13, image 2 of 3 Mac Pro Late 2013 AirPort Antenna Array Replacement: step 13, image 3 of 3
      • Use the tip of a spudger to flip the ZIF retaining tab on the fan ribbon cable.
      • Disconnect the fan ribbon cable.
      Ask FixBot
    1. Mac Pro Late 2013 AirPort Antenna Array Replacement, AirPort Antenna Array: step 14, image 1 of 1
      • Remove the three 3.7 mm T4 screws securing the antenna array to the fan assembly.
      Ask FixBot
    2. Mac Pro Late 2013 AirPort Antenna Array Replacement: step 15, image 1 of 1
      • Remove the AirPort antenna array.
      Ask FixBot
4 other people completed this guide.
Andrew Optimus Goldheart
515,580 Reputation
406 Guides authored
iFixit Member of iFixit
Staff
123 Members
85,567 Guides authored
2 Guide Comments
having macpro 2013 bluetooth on issue, where is the bluetooth module locate?
Sanong - Reply Share
is bluetooth module part of (inside) airport board?
Past 24 Hours: 0
Past 7 Days: 14
Past 30 Days: 64
All Time: 6,914
