Up to 20% off select tools
Mac Pro First Generation RAM Replacement
Views: 23K
View statistics:
Past 24 Hours:
4
Past 7 Days:
23
Past 30 Days:
125
All Time:
22,606
Comments: 2
2 guide comments.
Go to guide comments
Completed: 22
22 people have marked this guide "completed." Will you be next?
Favorites: 11
11 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 5 - 10 minutes
Difficulty: Easy
Featured Student Guide
This guide has been the hard work of our awesome students and is found to be exceptionally cool by the iFixit staff.
Introduction
Go to step 1 ↓
Accessing the RAM is easy and requires no tools. Use this guide to add or replace RAM for your Mac Pro.
    1. Mac Pro First Generation RAM Replacement, Case Panel: step 1, image 1 of 1
      • Lift the lever to unlock the case.
      Ask FixBot
    2. Mac Pro First Generation RAM Replacement: step 2, image 1 of 1
      Tool used on this step:
      Anti-Static Wrist Strap
      $7.95
      Buy
      • Remove the side panel of the Mac Pro.
      • Discharge any static electricity by touching a grounded surface prior to working on any internal components. Touching the metal PCI slot covers works great, or any other grounded metal surface. You can also wear a anti-static wrist strap.
      Ask FixBot
    1. Mac Pro First Generation RAM Replacement, RAM: step 3, image 1 of 1
      • Locate the two RAM trays at the bottom of the Mac Pro.
      Ask FixBot
    2. Mac Pro First Generation RAM Replacement: step 4, image 1 of 2 Mac Pro First Generation RAM Replacement: step 4, image 2 of 2
      • Pull the RAM tray out of the case by using both hands holding the edge of the ram board as shown.
      • Make sure you give enough time for the computer to cool down before you remove any internal hardware parts.
      Ask FixBot
    3. Mac Pro First Generation RAM Replacement: step 5, image 1 of 3 Mac Pro First Generation RAM Replacement: step 5, image 2 of 3 Mac Pro First Generation RAM Replacement: step 5, image 3 of 3
      • Push down on the ejectors on each side of a ram stick firmly and lift the RAM stick straight out carefully by holding each side.
      • To insert a new RAM stick, place the RAM into the slot with the correct orientation and push on the stick using both hands until the ejectors are clicked into place.
      Ask FixBot
22 other people completed this guide.
Author
with
Andrew Kim
1,281 Reputation
3 Guides authored
Cal Poly, Team 6-24, Maness Fall 2014 Member of Cal Poly, Team 6-24, Maness Fall 2014
CPSU-MANESS-F14S6G24
4 Members
72 Guides authored
2 Guide Comments
What is the name/or type of memory chip to use in the MacPro 2008.
Curtis - Reply Share
Hi Curtis, hope you found the RAM type ok.
Basically server RAM, ECC, 667Mhz, FB always in Pairs.
Retired Apple, PC etc engineer.
coopernewlyn - Reply Share
Past 24 Hours: 4
Past 7 Days: 23
Past 30 Days: 125
All Time: 22,606
