Up to 20% off select tools
Mac Pro First Generation GPU Replacement
Views: 24K
View statistics:
Past 24 Hours:
6
Past 7 Days:
31
Past 30 Days:
134
All Time:
24,413
Comments: 9
1 comment on steps, 8 guide comments.
Go to guide comments
Completed: 24
24 people have marked this guide "completed." Will you be next?
Favorites: 4
4 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 10 - 20 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
Accessing the GPU is easy and requires no tools. Use this guide to add or replace RAM for your Mac Pro.
    1. Mac Pro First Generation GPU Replacement, Case Panel: step 1, image 1 of 1
      • Lift the lever to unlock the case.
      Ask FixBot
    2. Mac Pro First Generation GPU Replacement: step 2, image 1 of 1
      Tool used on this step:
      Anti-Static Wrist Strap
      $7.95
      Buy
      • Remove the side panel of the Mac Pro.
      • Discharge any static electricity by touching a grounded surface prior to working on any internal components. Touching the metal PCI slot covers works great, or any other grounded metal surface. You can also wear a anti-static wrist strap.
      Ask FixBot
    1. Mac Pro First Generation GPU Replacement, GPU (Graphics Card): step 3, image 1 of 1
      • Locate the graphics card in the open panel side of your Mac Pro.
      Ask FixBot
    2. Mac Pro First Generation GPU Replacement: step 4, image 1 of 3 Mac Pro First Generation GPU Replacement: step 4, image 2 of 3 Mac Pro First Generation GPU Replacement: step 4, image 3 of 3
      • Unscrew the two thumb screws by twisting counterclockwise using your fingers until the slide lock is released.
      • Remove the slide lock.
      Ask FixBot
    3. Mac Pro First Generation GPU Replacement: step 5, image 1 of 3 Mac Pro First Generation GPU Replacement: step 5, image 2 of 3 Mac Pro First Generation GPU Replacement: step 5, image 3 of 3
      • Push up on the clip directly behind the graphics card to release it from its slot.
      • Slide the graphics card out of the slot using both hands by firmly holding the corners of the top of the card as shown.
      • Handle the card only by its edges. Don't touch any exposed components or connectors.
      Ask FixBot
24 other people completed this guide.
Author
with
Andrew Kim
1,281 Reputation
3 Guides authored
Cal Poly, Team 6-24, Maness Fall 2014 Member of Cal Poly, Team 6-24, Maness Fall 2014
CPSU-MANESS-F14S6G24
4 Members
72 Guides authored
8 Guide Comments
I have a first generation Mac Pro (1,1 – 2 x 3GHz Dual-Core Intel Xeon) that I purchased in November 2007.
I still love it.
THANK YOU for your valuable User Guides, and parts replacement guides!
David R Purnell - Reply Share
Hi, I just installed Mac OS X High Sierra in my 2010 Mac Pro. The first monitor is active with the ATI Radeon HD5770. However the #2 screen is inactive with its ATI Radeon HD3870. Should I get another HD5770 or a different card so I can use the second screen?
Robert Lloyd - Reply Share
For starters this is the first generation forum while your 2010 is a fifth generation model.
Nevertheless I had an interesting situation with the 5770 in a first gen machine that only ran under strange circumstances—a situation wroth sharing nevertheless.:
Ati Radeon X1900Xt had to be installed on bay 1 for the 5770 to work on bay 4
But for your situation, the question is: does the 3870 work standalone in its bay if the 5770 is taken out completely?
And if you swap the graphics cards into each others’ position, what’s the result?
allenwilson33 - Reply Share
Hi. My 1st Gen Mac Pro is maxed out with OS X Lion 10.7. I heard I may be able to make it a 5th Gen by switching a chip. Is anyone familiar with this?
Harold L. Watkins - Reply Share
Hi, I have a first generation MacBook Pro which is maxed out with OS X Lion 10.7. I heard I may be able to upgrade it to a generation 5 by switching out a chip. Is anyone familiar with this?
Past 24 Hours: 6
Past 7 Days: 31
Past 30 Days: 134
All Time: 24,413
