Mac Pro 2009-2012 Optical Drive Replacement
    1. Mac Pro 2009-2012 Optical Drive Replacement, Remove Side Panel: step 1, image 1 of 2 Mac Pro 2009-2012 Optical Drive Replacement, Remove Side Panel: step 1, image 2 of 2
      • Lift up the latch
      • Remove the Side panel
      • The hard drives and optical drives are locked in place when the latch is down!
      Ask FixBot
    2. Mac Pro 2009-2012 Optical Drive Replacement, The remove the optical drive carrier: step 2, image 1 of 1
      • Pull out halfway
      • Disconnect the cable(s)
      Ask FixBot
2 other people completed this guide.
Ben Capehart
10,266 Reputation
18 Guides authored
Restart Project Member of Restart Project
Local Repair Groups
33 Members
2,398 Guides authored
2 Guide Comments
After adding the drive, the computer does not recognize it. If I swap the cables, the other drive is recognized. Is there a software configuration that I need to make?
wmhoover - Reply Share
Did you check the cable that won't work for debris?
Ben Capehart - Reply Share
Past 24 Hours: 6
Past 7 Days: 37
Past 30 Days: 138
All Time: 5,248
