Up to 20% off select tools
Mac Mini Mid 2010 Fan Replacement
Views: 18K
View statistics:
Past 24 Hours:
6
Past 7 Days:
25
Past 30 Days:
130
All Time:
18,088
Comments: 14
12 comments on steps, 2 guide comments.
Go to guide comments
Completed: 23
23 people have marked this guide "completed." Will you be next?
Favorites: 5
5 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 2 minutes
Difficulty: Moderate
Parts
Tools
Introduction
Go to step 1 ↓
Use this guide to replace a noisy worn-out fan.
    1. Mac Mini Mid 2010 Fan Replacement, Bottom Cover: step 1, image 1 of 2 Mac Mini Mid 2010 Fan Replacement, Bottom Cover: step 1, image 2 of 2
      • Place your thumbs in the depressions cut into the bottom cover.
      • Rotate the bottom cover counter-clockwise until the white dot painted on the bottom cover is aligned with the ring inscribed on the outer case.
      Ask FixBot
    2. Mac Mini Mid 2010 Fan Replacement: step 2, image 1 of 1
      • Tilt the mini enough to allow the bottom cover to fall away from the outer case.
      • Remove the bottom cover and set it aside.
      Ask FixBot
    1. Mac Mini Mid 2010 Fan Replacement, Fan: step 3, image 1 of 1
      • Remove the two 11.3 mm T6 Torx screws securing the fan to the logic board near the antenna plate.
      Ask FixBot
    2. Mac Mini Mid 2010 Fan Replacement: step 4, image 1 of 1
      • Lift the ear of the fan nearest the RAM up off the standoff secured to the outer case.
      • If the fan doesn't separate from the standoff screw with a moderate amount of force, you can use a T6 Torx driver to simply remove this screw.
      Ask FixBot
    3. Mac Mini Mid 2010 Fan Replacement: step 5, image 1 of 1
      • Lift the fan out of the mini for enough clearance to access its connector.
      • Carefully pull the fan cables upward to lift the fan connector up out of its socket on the logic board.
      • Remove the fan.
      Ask FixBot
23 other people completed this guide.
Author
with
2 Guide Comments
How do you know the order of the wires when placing the 4 wires back onto the motherboard?
Communications Department - Reply Share
The connector is a snap in / snap out or more properly lift out connector. The connector goes back in only one way with the 4 pins aimed towards the wifi icon. To get it out you GENTLY lift the wires. I used my fingernail under the wires as they went from the fan into the connector.
Mike Stark - Reply Share
Past 24 Hours: 6
Past 7 Days: 25
Past 30 Days: 130
All Time: 18,088
