Up to 20% off select tools
Mac Mini Mid 2010 Cowling Replacement
Views: 8.3K
View statistics:
Past 24 Hours:
2
Past 7 Days:
19
Past 30 Days:
108
All Time:
8,269
Comments: 15
15 comments on steps.
Completed: 6
6 people have marked this guide "completed." Will you be next?
Favorites: 4
4 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: No estimate
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
Use this guide to remove the small molded plastic cowl used to direct cool air toward the heat sink.
    1. Mac Mini Mid 2010 Cowling Replacement, Bottom Cover: step 1, image 1 of 2 Mac Mini Mid 2010 Cowling Replacement, Bottom Cover: step 1, image 2 of 2
      • Place your thumbs in the depressions cut into the bottom cover.
      • Rotate the bottom cover counter-clockwise until the white dot painted on the bottom cover is aligned with the ring inscribed on the outer case.
      Ask FixBot
    2. Mac Mini Mid 2010 Cowling Replacement: step 2, image 1 of 1
      • Tilt the mini enough to allow the bottom cover to fall away from the outer case.
      • Remove the bottom cover and set it aside.
      Ask FixBot
    1. Mac Mini Mid 2010 Cowling Replacement, Fan: step 3, image 1 of 1
      • Remove the two 11.3 mm T6 Torx screws securing the fan to the logic board near the antenna plate.
      Ask FixBot
    2. Mac Mini Mid 2010 Cowling Replacement: step 4, image 1 of 1
      • Lift the ear of the fan nearest the RAM up off the standoff secured to the outer case.
      • If the fan doesn't separate from the standoff screw with a moderate amount of force, you can use a T6 Torx driver to simply remove this screw.
      Ask FixBot
    3. Mac Mini Mid 2010 Cowling Replacement: step 5, image 1 of 1
      • Lift the fan out of the mini for enough clearance to access its connector.
      • Carefully pull the fan cables upward to lift the fan connector up out of its socket on the logic board.
      • Remove the fan.
      Ask FixBot
    1. Mac Mini Mid 2010 Cowling Replacement, Cowling: step 6, image 1 of 1
      • Remove the single 3.5 mm T6 Torx screw securing the cowling to the heat sink.
      Ask FixBot
    2. Mac Mini Mid 2010 Cowling Replacement: step 7, image 1 of 1
      • Lift the cowling from the end nearest the antenna plate.
      • Rotate the cowling away from the outer case and remove it from the mini.
      Ask FixBot
6 other people completed this guide.
Author
with
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 19
Past 30 Days: 108
All Time: 8,269
