Up to 20% off select tools
Mac Mini Mid 2010 Bottom Cover Replacement
Views: 11K
View statistics:
Past 24 Hours:
9
Past 7 Days:
29
Past 30 Days:
133
All Time:
11,410
Comments: 0
Go to guide comments
Completed: 9
9 people have marked this guide "completed." Will you be next?
Favorites: 3
3 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 15 seconds - 2 minutes
Difficulty: Very easy
Introduction
Go to step 1 ↓
Remove the bottom cover to access components inside your Mac mini Model A1347.
    1. Mac Mini Mid 2010 Bottom Cover Replacement, Bottom Cover: step 1, image 1 of 2 Mac Mini Mid 2010 Bottom Cover Replacement, Bottom Cover: step 1, image 2 of 2
      • Place your thumbs in the depressions cut into the bottom cover.
      • Rotate the bottom cover counter-clockwise until the white dot painted on the bottom cover is aligned with the ring inscribed on the outer case.
      Ask FixBot
    2. Mac Mini Mid 2010 Bottom Cover Replacement: step 2, image 1 of 1
      • Tilt the mini enough to allow the bottom cover to fall away from the outer case.
      • Remove the bottom cover and set it aside.
      Ask FixBot
9 other people completed this guide.
Author
with
0 Guide Comments
Past 24 Hours: 9
Past 7 Days: 29
Past 30 Days: 133
All Time: 11,410
