MSI VR601 WiFi card Replacement
    1. MSI VR601 WiFi card Replacement, Open the back cover: step 1, image 1 of 2 MSI VR601 WiFi card Replacement, Open the back cover: step 1, image 2 of 2
      • Start by taking out the battery and charger. No power should be connected.
      • Unscrew the 4 Phillips #1 screws marked in the photo.
      • This screw is hidden under the Warranty void sticker!
      • All screws are the same length, so don't worry about mixing them up
      • Use a spudger or your finger to gently but firmly open the cover.
      • It's stuck in there with clips, so be a little careful. (Remember; If you feel like you're using too much force, you probably are).
      Ask FixBot
    2. MSI VR601 WiFi card Replacement, Identify the WiFi card and remove: step 2, image 1 of 2 MSI VR601 WiFi card Replacement, Identify the WiFi card and remove: step 2, image 2 of 2
      • The WiFi card has two antenna cables (one white and one black).
      • Use a spudger to carefully unhook the antenna contacts.
      • Unscrew the Phillips #0 screw holding the WiFi card down. (This is not the same screw as the others).
      Ask FixBot
    3. MSI VR601 WiFi card Replacement, Replace WiFi card: step 3, image 1 of 1
      • Take the old card out of the mini PCI Express slot, and replace with a new and compatible card.
      • In my case I only had a direct replacement, which only supports 802.11b/g standards.
      Ask FixBot
Geir Ove Andersen
8,388 Reputation
5 Guides authored
Master Techs Member of Master Techs
Community
335 Members
8,260 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 11
Past 30 Days: 57
All Time: 849
