This translation was generated by a machine and has not been reviewed by a person yet. Speak this language? Review it.
Community-Contributed Guide
Tools
Introduction
Go to step 1 ↓Disconnecting / Replacing the battery
Tutorial created using the disassembly video by LaptopMedia: MSI Pulse GL76 and M.F. LAB MSI Pulse(GL76)/ Katana(GF76)/ Sword/ Crosshair/ Alpha 17/ WF76 Series SSD & RAM Upgrade Tutorial
Warning: The LaptopMedia video also exists for the gl76 12Ux models
Guide written following the actual disassembly of my own device
Remove the 13 Phillips screws that secure the lower case in place (12 M2.5 x 12 mm screws and 1 shorter M2 x 4 mm screw) as indicated in the photo
Tool: Phillips screwdriver PH1
Critical safety warning: This laptop is equipped with a lithium-ion battery. Use extreme caution to never puncture, twist, bend, or damage the battery pack with a sharp tool or screwdriver. A puncture may cause an immediate fire or explosion.
Static electricity discharge (Essential precaution) Warning: Remember to discharge any static electricity from your body before handling internal components (for example by touching a grounded metal object or the ground pin of a wall socket) in order to avoid the risk of frying a sensitive component.
Unplugging the battery connector Warning: Never pull directly on the wires of the battery connector. To unplug the white socket safely, gently rock it from side to side to gradually work it out of its port without damaging the solder joints.
To reassemble your device, follow the instructions in reverse order.
