Up to 20% off select tools
MSI PR600 MS-16372 RAM Replacement
View statistics:
Past 24 Hours:
6
Past 7 Days:
20
Past 30 Days:
58
All Time:
957
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 7 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
In order to start this process of taking the RAM out and putting it back in, you must remove turn off your laptop and then remove the battery. Follow the battery replacement prerequisite before starting this guide.
    1. MSI PR600 MS-16372 RAM Replacement, Battery: step 1, image 1 of 1
      • First, turn off the computer and unplug the power cord.
      • If laptop is not unplugged from the power cord, you could be at risk of electric shock.
      Ask FixBot
    2. MSI PR600 MS-16372 RAM Replacement: step 2, image 1 of 1
      • Flip laptop over so that you are looking at the bottom of the laptop.
      • Put your left pointer finger on the switch labeled "Battery lock" and your right pointer finger on the switch labeled "Release".
      Ask FixBot
    3. MSI PR600 MS-16372 RAM Replacement: step 3, image 1 of 1
      • Switch the tab labeled "Battery lock" to the unlocked position.
      • Slide the tab labeled "Release" to the right and hold it down.
      • While holding the "Release" tab to the right, slide the battery out with your left hand.
      Ask FixBot
    1. MSI PR600 MS-16372 RAM Replacement, RAM: step 4, image 1 of 1
      • Unscrew the four 10 mm Phillips head screws circled in red in the picture using the Phillips 00 screwdriver.
      Ask FixBot
    2. MSI PR600 MS-16372 RAM Replacement: step 5, image 1 of 1
      • Put your pointer finger underneath the tab and lift up to remove the plastic cover.
      Ask FixBot
    3. MSI PR600 MS-16372 RAM Replacement: step 6, image 1 of 1
      • Slide the RAM off by pulling it away from the fan.
      • Slide RAM back in to serve as a reset.
      Ask FixBot
Author
with
Lauren Mewes
388 Reputation
3 Guides authored
UC Davis, Team S4-G8, Lore Fall 2018 Member of UC Davis, Team S4-G8, Lore Fall 2018
UCD-LORE-F18S4G8
3 Members
36 Guides authored
0 Guide Comments
Past 24 Hours: 6
Past 7 Days: 20
Past 30 Days: 58
All Time: 957
