Up to 20% off select tools
MSI PR600 MS-16372 Key Replacement
View statistics:
Past 24 Hours:
8
Past 7 Days:
24
Past 30 Days:
85
All Time:
916
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 4 minutes
Difficulty: Easy
Tools
Introduction
Go to step 1 ↓
This guide will help you fix a key that is not working when you push down on it. Instead of pushing down harder or repeatedly pushing down on the key, this guide will serve as a step-by-step guide to clean underneath the key.
    1. MSI PR600 MS-16372 Key Replacement, Key: step 1, image 1 of 1
      • Before you begin this replacement, make sure to turn the computer off to prevent future problems from occurring.
      • Start by flipping the laptop upside down and shake it gently to release excess debris.
      Ask FixBot
    2. MSI PR600 MS-16372 Key Replacement: step 2, image 1 of 1
      • Place flathead screwdriver underneath the faulty key.
      • Lift the flathead screwdriver upwards until you hear a click and it releases off the keyboard.
      Ask FixBot
    3. MSI PR600 MS-16372 Key Replacement: step 3, image 1 of 1
      • Gently brush off any loose particles that could be found underneath the key.
      Ask FixBot
    4. MSI PR600 MS-16372 Key Replacement: step 4, image 1 of 1
      • Align key to the center of the button and press down until you hear it click.
      • If you do not apply enough pressure the key will not fully reattach, so make sure you press hard enough.
      Ask FixBot
Author
with
Lauren Mewes
388 Reputation
3 Guides authored
UC Davis, Team S4-G8, Lore Fall 2018 Member of UC Davis, Team S4-G8, Lore Fall 2018
UCD-LORE-F18S4G8
3 Members
36 Guides authored
0 Guide Comments
Past 24 Hours: 8
Past 7 Days: 24
Past 30 Days: 85
All Time: 916
