Up to 20% off select tools
MSI MS-1782 GPU Replacement
Views: 1.1K
View statistics:
Past 24 Hours:
4
Past 7 Days:
24
Past 30 Days:
75
All Time:
1,117
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 10 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
If your MSI MS-1782 laptop has a totally black screen, or vertical or horizontal lines on the screen, it could be your GPU malfunctioning. Check the troubleshooting page to help you identify the problem. This guide will show you how to replace the GPU.
    1. MSI MS-1782 GPU Replacement, Back Cover: step 1, image 1 of 1
      • Remove five 6.6 mm screws from the edges of the bottom cover using a JIS #1 screwdriver.
      • Remove one 5.6 mm screw from the center of the bottom cover using a JIS #1 screwdriver.
      Ask FixBot
    2. MSI MS-1782 GPU Replacement: step 2, image 1 of 3 MSI MS-1782 GPU Replacement: step 2, image 2 of 3 MSI MS-1782 GPU Replacement: step 2, image 3 of 3
      • Use an iFixit opening pick to unclip the bottom cover.
      • It is ok to run the picks along the edges since there is nothing connected to the bottom cover. It is easier to start from the sides and then work your way forward.
      • After unclipping the bottom case, pull from the back of the laptop upwards using the lip of the bottom case as a handle.
      Ask FixBot
    1. MSI MS-1782 GPU Replacement, Cooling Assembly: step 3, image 1 of 3 MSI MS-1782 GPU Replacement, Cooling Assembly: step 3, image 2 of 3 MSI MS-1782 GPU Replacement, Cooling Assembly: step 3, image 3 of 3
      • Loosen the captive screw on the left side of the left fan using a JIS #2 screwdriver.
      • Remove the 5.1 mm screw on the right side of the left fan using a JIS #2 screwdriver.
      Ask FixBot
    2. MSI MS-1782 GPU Replacement: step 4, image 1 of 3 MSI MS-1782 GPU Replacement: step 4, image 2 of 3 MSI MS-1782 GPU Replacement: step 4, image 3 of 3
      • Gently detach the fan connector.
      • Remove the fan by lifting it out of its housing.
      • Be sure to handle the wire delicately; if not it will break.
      Ask FixBot
    3. MSI MS-1782 GPU Replacement: step 5, image 1 of 3 MSI MS-1782 GPU Replacement: step 5, image 2 of 3 MSI MS-1782 GPU Replacement: step 5, image 3 of 3
      • Loosen the captive screw on the top of the right fan using a JIS #2 screwdriver.
      • Remove the 3.6 mm screw on the bottom of the right fan using a JIS #2 screwdriver.
      Ask FixBot
    4. MSI MS-1782 GPU Replacement: step 6, image 1 of 3 MSI MS-1782 GPU Replacement: step 6, image 2 of 3 MSI MS-1782 GPU Replacement: step 6, image 3 of 3
      Ask FixBot
    5. MSI MS-1782 GPU Replacement: step 7, image 1 of 3 MSI MS-1782 GPU Replacement: step 7, image 2 of 3 MSI MS-1782 GPU Replacement: step 7, image 3 of 3
      • Loosen the eight captive screws holding the heat sink in place using a JIS #2 screwdriver.
      • Be sure to follow the numbers that are next to the screws on the heatsink. This evenly removes pressure on the components when removing the heatsink.
      Ask FixBot
    6. MSI MS-1782 GPU Replacement: step 8, image 1 of 3 MSI MS-1782 GPU Replacement: step 8, image 2 of 3 MSI MS-1782 GPU Replacement: step 8, image 3 of 3
      • Gently lift the heat sink and then pull forwards towards you.
      Ask FixBot
    1. MSI MS-1782 GPU Replacement, GPU: step 9, image 1 of 3 MSI MS-1782 GPU Replacement, GPU: step 9, image 2 of 3 MSI MS-1782 GPU Replacement, GPU: step 9, image 3 of 3
      • Remove the two 5.0 mm screws holding the GPU by using a JIS #1 screwdriver.
      Ask FixBot
    2. MSI MS-1782 GPU Replacement: step 10, image 1 of 3 MSI MS-1782 GPU Replacement: step 10, image 2 of 3 MSI MS-1782 GPU Replacement: step 10, image 3 of 3
      • Gently lift the GPU and pull to remove it from the laptop.
      Ask FixBot
Author
with
Enmanuel Mota
229 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 24
Past 30 Days: 75
All Time: 1,117
