MSI MS-1782 Cooling Assembly Replacement
    1. MSI MS-1782 Cooling Assembly Replacement, Back Cover: step 1, image 1 of 1
      • Remove five 6.6 mm screws from the edges of the bottom cover using a JIS #1 screwdriver.
      • Remove one 5.6 mm screw from the center of the bottom cover using a JIS #1 screwdriver.
      Ask FixBot
    2. MSI MS-1782 Cooling Assembly Replacement: step 2, image 1 of 3 MSI MS-1782 Cooling Assembly Replacement: step 2, image 2 of 3 MSI MS-1782 Cooling Assembly Replacement: step 2, image 3 of 3
      • Use an iFixit opening pick to unclip the bottom cover.
      • It is ok to run the picks along the edges since there is nothing connected to the bottom cover. It is easier to start from the sides and then work your way forward.
      • After unclipping the bottom case, pull from the back of the laptop upwards using the lip of the bottom case as a handle.
      Ask FixBot
    1. MSI MS-1782 Cooling Assembly Replacement, Cooling Assembly: step 3, image 1 of 3 MSI MS-1782 Cooling Assembly Replacement, Cooling Assembly: step 3, image 2 of 3 MSI MS-1782 Cooling Assembly Replacement, Cooling Assembly: step 3, image 3 of 3
      • Loosen the captive screw on the left side of the left fan using a JIS #2 screwdriver.
      • Remove the 5.1 mm screw on the right side of the left fan using a JIS #2 screwdriver.
      Ask FixBot
    2. MSI MS-1782 Cooling Assembly Replacement: step 4, image 1 of 3 MSI MS-1782 Cooling Assembly Replacement: step 4, image 2 of 3 MSI MS-1782 Cooling Assembly Replacement: step 4, image 3 of 3
      • Gently detach the fan connector.
      • Remove the fan by lifting it out of its housing.
      • Be sure to handle the wire delicately; if not it will break.
      Ask FixBot
    3. MSI MS-1782 Cooling Assembly Replacement: step 5, image 1 of 3 MSI MS-1782 Cooling Assembly Replacement: step 5, image 2 of 3 MSI MS-1782 Cooling Assembly Replacement: step 5, image 3 of 3
      • Loosen the captive screw on the top of the right fan using a JIS #2 screwdriver.
      • Remove the 3.6 mm screw on the bottom of the right fan using a JIS #2 screwdriver.
      Ask FixBot
    4. MSI MS-1782 Cooling Assembly Replacement: step 6, image 1 of 3 MSI MS-1782 Cooling Assembly Replacement: step 6, image 2 of 3 MSI MS-1782 Cooling Assembly Replacement: step 6, image 3 of 3
      Ask FixBot
    5. MSI MS-1782 Cooling Assembly Replacement: step 7, image 1 of 3 MSI MS-1782 Cooling Assembly Replacement: step 7, image 2 of 3 MSI MS-1782 Cooling Assembly Replacement: step 7, image 3 of 3
      • Loosen the eight captive screws holding the heat sink in place using a JIS #2 screwdriver.
      • Be sure to follow the numbers that are next to the screws on the heatsink. This evenly removes pressure on the components when removing the heatsink.
      Ask FixBot
    6. MSI MS-1782 Cooling Assembly Replacement: step 8, image 1 of 3 MSI MS-1782 Cooling Assembly Replacement: step 8, image 2 of 3 MSI MS-1782 Cooling Assembly Replacement: step 8, image 3 of 3
      • Gently lift the heat sink and then pull forwards towards you.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 17
Past 30 Days: 74
All Time: 801
