MSI GT70 MS-1763 RAM Replacement
    1. MSI GT70 MS-1763 RAM Replacement, Battery: step 1, image 1 of 2 MSI GT70 MS-1763 RAM Replacement, Battery: step 1, image 2 of 2
      • Power off the laptop and turn it over.
      Ask FixBot
    2. MSI GT70 MS-1763 RAM Replacement: step 2, image 1 of 2 MSI GT70 MS-1763 RAM Replacement: step 2, image 2 of 2
      • Release the safety latches that hold the battery in place. The left latch will stay moved up, while the right side is spring activated and will have to be held.
      Ask FixBot
    3. MSI GT70 MS-1763 RAM Replacement: step 3, image 1 of 2 MSI GT70 MS-1763 RAM Replacement: step 3, image 2 of 2
      • While holding up the left latch, use a Jimmy and slide the old battery out of its compartment.
      Ask FixBot
    1. MSI GT70 MS-1763 RAM Replacement, Hard Drive: step 4, image 1 of 2 MSI GT70 MS-1763 RAM Replacement, Hard Drive: step 4, image 2 of 2
      • Remove all twelve 4 mm Phillips #0 screws from the back of the laptop.
      • Remove the back cover.
      Ask FixBot
    2. MSI GT70 MS-1763 RAM Replacement: step 5, image 1 of 1
      • Remove the rubber spacer holding the hard drive secure.
      Ask FixBot
    3. MSI GT70 MS-1763 RAM Replacement: step 6, image 1 of 2 MSI GT70 MS-1763 RAM Replacement: step 6, image 2 of 2
      • Slide the hard drive to the left, removing it from its bay.
      Ask FixBot
    1. MSI GT70 MS-1763 RAM Replacement, Keyboard: step 7, image 1 of 3 MSI GT70 MS-1763 RAM Replacement, Keyboard: step 7, image 2 of 3 MSI GT70 MS-1763 RAM Replacement, Keyboard: step 7, image 3 of 3
      • Using a Jimmy, remove the outer cover around the keyboard.
      • Remove the ribbon cable from the ZIF connector on the underside of the top cover.
      Ask FixBot
    2. MSI GT70 MS-1763 RAM Replacement: step 8, image 1 of 2 MSI GT70 MS-1763 RAM Replacement: step 8, image 2 of 2
      • Using a Phillips #0 screwdriver, remove the five 3 mm screws at the top of the keyboard.
      Ask FixBot
    3. MSI GT70 MS-1763 RAM Replacement: step 9, image 1 of 1
      • Flip the keyboard back and disconnect the keyboard cable.
      Ask FixBot
    4. MSI GT70 MS-1763 RAM Replacement: step 10, image 1 of 3 MSI GT70 MS-1763 RAM Replacement: step 10, image 2 of 3 MSI GT70 MS-1763 RAM Replacement: step 10, image 3 of 3
      • Flip the laptop over and disconnect the data cable from the ZIF connector on the bottom right.
      • You can now turn the laptop back over and remove the keyboard.
      Ask FixBot
    1. MSI GT70 MS-1763 RAM Replacement, RAM: step 11, image 1 of 1
      • Pull back the black film, which covers the ram.
      Ask FixBot
    2. MSI GT70 MS-1763 RAM Replacement: step 12, image 1 of 2 MSI GT70 MS-1763 RAM Replacement: step 12, image 2 of 2
      • Pull the safety latches on either side of the RAM away from each other.
      • The RAM should pop up at an angle from the motherboard when it has cleared the latches.
      • Remove the RAM, maintaining the angle at which it rests.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 20
Past 30 Days: 91
All Time: 2,481
