MSI GT70 MS-1763 Hard Drive Replacement
    1. MSI GT70 MS-1763 Hard Drive Replacement, Battery: step 1, image 1 of 2 MSI GT70 MS-1763 Hard Drive Replacement, Battery: step 1, image 2 of 2
      • Power off the laptop and turn it over.
      Ask FixBot
    2. MSI GT70 MS-1763 Hard Drive Replacement: step 2, image 1 of 2 MSI GT70 MS-1763 Hard Drive Replacement: step 2, image 2 of 2
      • Release the safety latches that hold the battery in place. The left latch will stay moved up, while the right side is spring activated and will have to be held.
      Ask FixBot
    3. MSI GT70 MS-1763 Hard Drive Replacement: step 3, image 1 of 2 MSI GT70 MS-1763 Hard Drive Replacement: step 3, image 2 of 2
      • While holding up the left latch, use a Jimmy and slide the old battery out of its compartment.
      Ask FixBot
    1. MSI GT70 MS-1763 Hard Drive Replacement, Hard Drive: step 4, image 1 of 2 MSI GT70 MS-1763 Hard Drive Replacement, Hard Drive: step 4, image 2 of 2
      • Remove all twelve 4 mm Phillips #0 screws from the back of the laptop.
      • Remove the back cover.
      Ask FixBot
    2. MSI GT70 MS-1763 Hard Drive Replacement: step 5, image 1 of 1
      • Remove the rubber spacer holding the hard drive secure.
      Ask FixBot
    3. MSI GT70 MS-1763 Hard Drive Replacement: step 6, image 1 of 2 MSI GT70 MS-1763 Hard Drive Replacement: step 6, image 2 of 2
      • Slide the hard drive to the left, removing it from its bay.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 10
Past 30 Days: 47
All Time: 2,082
