Up to 20% off select tools
MSI GS70 Solid State Drive Replacement
Views: 3.5K
View statistics:
Past 24 Hours:
3
Past 7 Days:
23
Past 30 Days:
68
All Time:
3,546
Comments: 0
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 minutes
Difficulty: Easy
Tools
Introduction
Go to step 1 ↓
Just like the hard disk drive, the solid state drive is another type of storage media for personal computers. If there is ever a moment where you need to replace the solid state drive, then this guide will show you how.
    1. MSI GS70 Solid State Drive Replacement, Solid State Drive: step 1, image 1 of 2 MSI GS70 Solid State Drive Replacement, Solid State Drive: step 1, image 2 of 2
      • Locate and remove all screws securing the back plate. Place the screws on the magnetic mat.
      • Locate one of the openings on the side and gently pull the back plate up to remove it.
      Ask FixBot
    2. MSI GS70 Solid State Drive Replacement: step 2, image 1 of 1
      • Locate the solid state drive. It is initially obscured by a connector, its okay to push away the connector to access the solid state drive.
      Ask FixBot
    3. MSI GS70 Solid State Drive Replacement: step 3, image 1 of 1
      • Remove the screw holding the solid state drive. Place the screw on the magnetic mat
      Ask FixBot
    4. MSI GS70 Solid State Drive Replacement: step 4, image 1 of 1
      • Gently remove the solid state drive.
      Ask FixBot
    5. MSI GS70 Solid State Drive Replacement: step 5, image 1 of 1
      • There are different form factors for solid state drives and so you have to pick the appropriate one.
      • The MSI GS70 will only accept 50mm solid state drives so buy accordingly.
      Ask FixBot
    6. MSI GS70 Solid State Drive Replacement: step 6, image 1 of 1
      • There is a second solid state drive right next to the first one if you want to add another solid state drive.
      Ask FixBot
Once you have secured the solid state drive, push and screw in the back plate.
2 other people completed this guide.
Author
with
Gene Abuan
310 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 23
Past 30 Days: 68
All Time: 3,546
