Up to 20% off select tools
MSI GS70 Hard Drive Replacement
Views: 18K
View statistics:
Past 24 Hours:
5
Past 7 Days:
33
Past 30 Days:
122
All Time:
17,668
Comments: 2
2 guide comments.
Go to guide comments
Completed: 12
12 people have marked this guide "completed." Will you be next?
Favorites: 2
2 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 40 minutes
Difficulty: Easy
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Needs More Images
A few more images would make this guide's procedures crystal clear.
Community-Contributed Guide
Fix Kit
This kit contains all the parts and tools needed to complete this guide.
Parts
Tools
Introduction
Go to step 1 ↓
This guide will show you how to repair or replace the Hard Drive for the MSI GS70. Replacement of the Hard Drive is fairly easy as you will only need a JIS #1 Screwdriver and a magnetic mat (Optional, but recommended)
    1. MSI GS70 Hard Drive Replacement, Remove the Backplate: step 1, image 1 of 2 MSI GS70 Hard Drive Replacement, Remove the Backplate: step 1, image 2 of 2
      • Using your JIS #1, locate and remove all screws from the backplate.
      • When all the screws are removed, proceed to remove the backplate. The hard drive will be located right next to the battery.
      Ask FixBot
    2. MSI GS70 Hard Drive Replacement, Remove the Hard Drive Spacer: step 2, image 1 of 2 MSI GS70 Hard Drive Replacement, Remove the Hard Drive Spacer: step 2, image 2 of 2
      • Locate the black rubber spacer
      • Remove the spacer by gently pulling the flap
      Ask FixBot
    3. MSI GS70 Hard Drive Replacement, Disconnect your Hard Drive: step 3, image 1 of 1
      • With two hands slide the Hard Drive to the left.
      Ask FixBot
    4. MSI GS70 Hard Drive Replacement, Remove the Hard Drive: step 4, image 1 of 2 MSI GS70 Hard Drive Replacement, Remove the Hard Drive: step 4, image 2 of 2
      • Carfully lift up the Hard Drive using your Spudger.
      • Next, pull up your hard drive from the battery end and proceed to remove the hard drive
      Ask FixBot
12 other people completed this guide.
Author
with
Matthew Tasker
386 Reputation
1 Guide authored
2 Guide Comments
The screws on my machine were Philips not torx don't know if it is different or has changed at all but all internal and external were Phillips
rambo33hockey - Reply Share
bonjour
comment accéder au disque dur msata sur le msi gs 70
Vivabzh côtes d'armors - Reply Share
Past 24 Hours: 5
Past 7 Days: 33
Past 30 Days: 122
All Time: 17,668
