MSI GS66 Stealth 11UE-007 RAM Replacement
    1. MSI GS66 Stealth 11UE-007 RAM Replacement, RAM: step 1, image 1 of 1
      • Orient your laptop so that the bottom is facing up and the hinge is away from yourself.
      • Make sure to unplug device from any outlet.
      Ask FixBot
    2. MSI GS66 Stealth 11UE-007 RAM Replacement: step 2, image 1 of 1
      • Identify the nine screws around the perimeter. One screw will be under the factory seal sticker.
      Ask FixBot
    3. MSI GS66 Stealth 11UE-007 RAM Replacement: step 3, image 1 of 1
      • Remove eight 10 mm Phillips #1 screws.
      Ask FixBot
    4. MSI GS66 Stealth 11UE-007 RAM Replacement: step 4, image 1 of 1
      • Remove one 7 mm Philips #1 screw from the center bottom of backplate.
      Ask FixBot
    5. MSI GS66 Stealth 11UE-007 RAM Replacement: step 5, image 1 of 3 MSI GS66 Stealth 11UE-007 RAM Replacement: step 5, image 2 of 3 MSI GS66 Stealth 11UE-007 RAM Replacement: step 5, image 3 of 3
      • Use the tip of the blue plastic opening tool to slip between the backplate and the body of the laptop at the hinge side.
      • Wiggle the blue plastic opening tool as you slide it around the perimeter of the backplate to separate is from the body of the laptop.
      Ask FixBot
    6. MSI GS66 Stealth 11UE-007 RAM Replacement: step 6, image 1 of 2 MSI GS66 Stealth 11UE-007 RAM Replacement: step 6, image 2 of 2
      • Lift back black plastic.
      Ask FixBot
    7. MSI GS66 Stealth 11UE-007 RAM Replacement: step 7, image 1 of 2 MSI GS66 Stealth 11UE-007 RAM Replacement: step 7, image 2 of 2
      • Place both thumbs on metal tabs and apply pressure in a widening motion until RAM lifts.
      Ask FixBot
    8. MSI GS66 Stealth 11UE-007 RAM Replacement: step 8, image 1 of 1
      • Pull RAM straight out from the connector at the angle it lifted at.
      Ask FixBot
2 other people completed this guide.
Alex Robinson
1,190 Reputation
6 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 12
Past 30 Days: 64
All Time: 1,159
