MSI GS66 Stealth 11UE-007 Battery Replacement
    1. MSI GS66 Stealth 11UE-007 Battery Replacement, Battery: step 1, image 1 of 1
      • Orient your laptop so that the bottom is facing up and the hinge is away from yourself.
      • Make sure to unplug device.
      Ask FixBot
    2. MSI GS66 Stealth 11UE-007 Battery Replacement: step 2, image 1 of 1
      • Identify the nine screws around the perimeter. One screw will be under the factory seal sticker.
      Ask FixBot
    3. MSI GS66 Stealth 11UE-007 Battery Replacement: step 3, image 1 of 1
      • Remove eight 10 mm Phillips #1 screws.
      Ask FixBot
    4. MSI GS66 Stealth 11UE-007 Battery Replacement: step 4, image 1 of 1
      • Remove one 7 mm Phillips #1 screw from the center bottom of backplate.
      Ask FixBot
    5. MSI GS66 Stealth 11UE-007 Battery Replacement: step 5, image 1 of 3 MSI GS66 Stealth 11UE-007 Battery Replacement: step 5, image 2 of 3 MSI GS66 Stealth 11UE-007 Battery Replacement: step 5, image 3 of 3
      • Use the tip of the blue plastic opening tool to slip between the backplate and the body of the laptop at the hinge side.
      • Wiggle the blue plastic opening tool as you slide it around the perimeter of the backplate to separate is from the body of the laptop.
      Ask FixBot
    6. MSI GS66 Stealth 11UE-007 Battery Replacement: step 6, image 1 of 1
      • Peal back metallic tape on the right side of the USB port.
      Ask FixBot
    7. MSI GS66 Stealth 11UE-007 Battery Replacement: step 7, image 1 of 2 MSI GS66 Stealth 11UE-007 Battery Replacement: step 7, image 2 of 2
      • Remove three 6 mm Phillips #1 screws.
      Ask FixBot
    8. MSI GS66 Stealth 11UE-007 Battery Replacement: step 8, image 1 of 1
      • Use the tip of the spudger or your fingernail to gently push out the white connector.
      Ask FixBot
    9. MSI GS66 Stealth 11UE-007 Battery Replacement: step 9, image 1 of 2 MSI GS66 Stealth 11UE-007 Battery Replacement: step 9, image 2 of 2
      • Remove the battery from the device.
      Ask FixBot
5 other people completed this guide.
Alex Robinson
1,190 Reputation
6 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 30
Past 30 Days: 145
All Time: 2,491
