MSI GS63VR 6RF Stealth Pro Wi-Fi Card Replacement
Views: 5.2K
View statistics:
Past 24 Hours:
5
Past 7 Days:
26
Past 30 Days:
111
All Time:
5,249
Comments: 3
3 guide comments.
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 15 - 25 minutes
Difficulty: Moderate
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Needs More Images
A few more images would make this guide's procedures crystal clear.
Missing Steps
Oops! This guide is currently missing one or more important steps.
Better Introduction
Improve this guide by completing or revising its introduction.
Introduction
Go to step 1 ↓
If you're having connectivity issues with your Stealth Pro, or simply want to upgrade your connectivity, this guide will walk you through the replacement process.
Parts
Tools
    1. MSI GS63VR 6RF Stealth Pro Wi-Fi Card Replacement, Wi-Fi Card: step 1, image 1 of 3 MSI GS63VR 6RF Stealth Pro Wi-Fi Card Replacement, Wi-Fi Card: step 1, image 2 of 3 MSI GS63VR 6RF Stealth Pro Wi-Fi Card Replacement, Wi-Fi Card: step 1, image 3 of 3
      • First, turn off the laptop and make sure it is unplugged from power to avoid injury or damage to your device.
      • Unscrew the 15 screws on the bottom panel of the computer using a Phillips #00 screwdriver. One screw will be hidden under a warranty sticker
      • Gently pry around the back cover off the with a plastic spudger
      • Unplug the battery cable from the motherboard.
      • Too much pressure from the spudger can break the clips that secure the back panel, but some flex is not dangerous.
      Ask FixBot
    2. MSI GS63VR 6RF Stealth Pro Wi-Fi Card Replacement: step 2, image 1 of 2 MSI GS63VR 6RF Stealth Pro Wi-Fi Card Replacement: step 2, image 2 of 2
      • Unscrew the single screw from the Wi-Fi card using a Phillips #00 screwdriver.
      • Slide a thin, ESD-safe pry tool or angled tweezers under the metal neck of the connector (as close to the head as possible) and lift straight up from the board.
      • When working with these connectors, it's key to always lift the head straight up. If pried on at an odd angle, you risk breaking the socket off of the board underneath.
      • Reconnecting these can be tricky. Use tweezers to hold the connector in place over its socket and gently press down with your finger or a spudger—the connector should "snap" into place. If you're having trouble, reposition the head and try again.
      • Using tweezers, carefully grab and remove the Wi-Fi card.
      Ask FixBot
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
3 Guide Comments
Is this a msata card or a m.2 card?
keith dragon - Reply Share
Hi, do you know where I can find some new wifi cables? I broke mine (with my WiFi card) and looking to repair it
Best regards
Bastien Allaoui - Reply Share
Hi there , the wifi cable (aux) its not connecting to the card , probaly I have bent it , what problem does it cause because right now I still can use the wifi, and most important thing , where can I buy it and how can change it ? Thanks
Adriano - Reply Share
Past 24 Hours: 5
Past 7 Days: 26
Past 30 Days: 111
All Time: 5,249
